As far as reverse goes I can put in two more switches but before I go to that trouble I'll install an override switch to bypass those micro switches when I need to make a turn or reverse it long enough to stop or give me a bit of bow room, after sea trial then I will do corrective wiring if need be. Patrick the camera is on a mount attached to the servo at the front that I made which gives me the ability to pan up and down as far as left to right goes I just turn the whole machine, the controller has a stabilizing system for cameras but I don't use it because I want to know if it is banking or turning on command.
Thank you Jparsley it's almost there I have one maybe two more servos to install that I will do once I get the chance.
Thanks for the compliments Patrick! I think they could turn on their own axis as long as the guy yelling orders gets it right. Yes I am very happy with it took a lot of time to get to this point, I can improve the stability by adding rudders and the battering ram that should smooth it all right out. I think I may actually have it done before the end of the year.
Now that is even more impressive...   Rudder control would be interesting as you wouldn't have reverse oars to make gentle turns.
Since I started building my Bireme I have wrecked one pair of shorts and about three "T" shirts by getting epoxy rubbed or dripped on them as I'm sure many of you have had a spill or two at your own work stations, my wife of course would spot my screw ups and tell me about them, so I came up with a solution. Last year I acquired a Serger and sewing machine to make samples of my night time leg cramp prevention invention that I patented in November 2014 that works very well, and I must say I have learned how to work those machines and made myself an apron or at least I think that's what you call them, so I thought I would post a picture.
Hi Ben
...how does the saying go? "Necessity is the mother of invention?"
Nice job!
Cheers
Patrick
Edited by Omega1234
I broke down and bought one of those denim aprons made for workmen.  The Admiral wishes I would wear it.
Bob
Current build:  SS_ Mariefred
Adding a strip of wood to the keel, other than help with the finished look of the ship I believe it will help to stop the pivoting the oars create when they are finding their balance stroke.
Time to make the ram! Started out by cutting templates from cardboard I cut out to fit the hull, taped them together to make sure the fit was right. With my paper templates I traced them on to brass sheeting I have, then using tin snips I cut them out of the brass sheet. I fitted the bent piece to the hull then traced around that piece on to the brass sheet below it. With that last step being done I was able to solder the rest of it together now the worst part is done but I've only half finished the ram.
Nice metalwork.. that ram looks great.
Thanks Mtaylor it went easier than I thought it would so that was a blessing, next I have to complete it and add some of my own touches!
The ram is a fine piece of brass work.  I would sure hate to see that coming at my boat.
Bob
Thanks Patrick and Bob it turned out quite well once I started using a soldering torch inside of my small electric soldering gun. I plan on dressing it up more with some very offensive looking spikes.
Hi Ben
Your battering ram made me think.....When we were kids, we used to take great delight in using our RC cabin cruisers to chase the local ducks on the lake. The ducks hated it, but the bystanders had a laugh. I can just imagine how much more entertaining the spectacle would've been if your battering rams with spikes were fitted to our boats!
Now, that's worth a thought.
Cheers
Patrick
Edited by Omega1234
Began building the hatches yesterday, used my modified tile saw to cut all 22 hatches for the rowers to pop out of and shoot arrows at the enemy. I made them out of basswood for some contrast and the handles will be brass they will be spaced as far apart as possible to allow a roped area between the hatches. The Amati model has a plush area near the stern for someone important to sit in which would be a very bad place to be in battle so I think mine won't have that. I will be checking out other styles and models to finish the deck and come up with something more suitable.
Edited by bensid54
The rudders as they are, I attempted to slot the dowels with my milling bit but only managed to split them so I used my little table saw. As I was cutting the dowels I was making a fair bit of smoke so I assumed the blade must be getting dull so I continued on. Once I had cut both dowels I checked out how dull the blade on my little saw was to find out I had been feeding the dowels into the saw the wrong way the whole time! Some days I wonder how I manage to dress myself without labeling my shoes right and left!
