HOLIDAY DONATION DRIVE - SUPPORT MSW - DO YOUR PART TO KEEP THIS GREAT FORUM GOING! (Only 64 donations so far out of 49,000 members - C'mon guys!) ×
Hi everyone
Since I have restarted my build of Le Mirage I thought it was time to resurect my build log from the ashes of the Great crash of 13! :)
This will be more of a summary rather than a detailed log. Lots of pictures, some words. You never know some of it might be interesting! :P
I started this build 3 years ago. Yes progress is slow but in my defence having two children in that time has somewhat limited build time... ;)
Comments/criticisms/etc gratefully received. Always good to get feedback of more experienced modellers.
Anyhoo enough of the intro. Hope you're sitting confortably. Popcorn ready?... Good.
A few box content pictures to get going
The box
Inside the box
This is my second build after the Billing Bluenose and I have to say I was very impressed with the quality of the materials. However the bulkhead slots needed some adjusting...
All the bulkheads in place
Unfortunately I didn't notice until way too late that the first one was higher up than it should have been. First mistake (and not the last! :D  )
The slots in the bulkheads are used to determine where the gun ports are.
and again
although that didn't stop me forgetting some gun ports (told you there were more mistakes!)
Well that's the limit of 8 photos per post reached. Until the next post...
Nick
gun port omission (see previous post) now corrected... :blush:
After that it was "just" a question of applying the first layer of planking
in progress
and voila. Finished! easy. :P
However...something was amiss at the stern...
so drastic measures were required...
and the original booboo was fixed.
At this point can I say to anyone who hesitates in making a fix. Dont! Once you've ripped up what was wrong, well, you can't leave it like that so might as well do it properly! :D
Seriously I was tempted not to fix it. But I'm glad I did.
And finally a couple of pics of the first planking filled and sanded.
That's it for now. Thanks for looking in.
Hopefully I wont keep you waiting for the next installment too long.
Nick
Evening all
The next step was to plank the bow. Not wanting to follow Corel' instructions for reasons shown below...
I tried to come up with something a bit more realistic and after getting some inspiration from the Ancre website, followed by some good tips from Danny this was the result
which you will agree (well hopefully :) ) is better than Corel's suggestion!
Next step was to mark up the frames in preparation for the second planking
followed by the stern planking
And then the second planking started...
and I'm sure you noticed on that last photo that I was still having issues with gun port location :D. Ho hum...
Only one more catch up post to follow and this log will have caught up with my progress.
TTFN
Nick
Hi Nick,
It should be about time that you do something  :D  :D  :D
I will follow you further with this !
The stem looks great with that patron !
Thanks Brian and Sjors for the comments and Aussie048 for the like. I'm not planning to go scratch build crazy (famous last words :D ) on this build but the stem I had to change!
Yes Sjors you are right I really need to catch up with you on your Le Mirage build. oh wait you've already finished it... :blush: :blush: :blush::D
Nick
No worries Nick,
I've been coming to England in June for two weeks to stay with Mobbsie and his Admiral and I don't have hostile intentions !
Only friendship !!!!!!!
A little late ,but congrats to you and the Admiral of the birth of your daughter !
A Kings couple....boy and girl.
Enjoy them, they are old before you know it  :D
Thanks Sjors!
Evening all
I decided to take the plunge and line the hull off according to Chuck Passaro's excellent tutorial. I didnt' want to use the wood supplied by Corel as I found it too light so decided to carry on with using walnut. I bought some 5mm wide planks and some 100mm wide sheets for the curved sections. All fine and well until I got both and realised the two didnt seem to be the same wood... :huh:  or more specifically the 5mm strips did not look like walnut
So ordered some more from a different source and got the same stuff... double :huh: . Given that my finances were (are... :D ) not illimited I decided to cut the 5mm planks from the 100mm sheets. Downside to that is that it takes a loooooong time to do the second planking. Hopefully it will be worth it.
First step was to break the hull down into sections:
and finally
And so the second planking of the hull started. As a picture is worth a thousand words...
and finally again
And that brings me up to date. I'm not going to be posting updates quickly from now on since I only have time to do one planking strip a week on average and I have about 35 strips left :D. I do like doing planking but I have to admit I'll be glad when it's over :D
I'll try and post some photos when I complete a section.
Thanks for looking
Nick
Some great work and some fabulous planking Nick B) Spiling the planks and laying in a contemporary model style will always look the nicest.Yes it is a lot of work cutting the planks out but the results are well worth it.I found the hardest bit to get to look right was the bow end of the garboard plank.You have to stand the model right way up and looking from the horizontal,try to get the end so it looks like it flows in a sweeping curve from the side.This dictates the radius you cut on the end.It took a couple of goes on Caroline to get this to look right.
Kind Regards
Nigel
Edited by NMBROOK
Currently working on Royal Caroline
Now, this is a nice looking ship, Nick, and I can tell you are off to make a nice build out of it.
Your planking jobs looks very clean and even. Congratulations!
There aren't but two options: do it FAST, or do it RIGHT.
Current Project Build Log: Soleil Royal in 1/72. Kit by Artesania Latina.
Last finished projectsRoyal Ship Vasa 1628; French Vessel Royal Louis 1780. 1/90 Scale by Mamoli. 120 Cannons
Future projects already in my stash: Panart: San Felipe 1/75; OcCre: Santísima Trinidad 1/90;
Wish List: 1/64 Amati Victory, HMS Enterprise in 1/48 by CAF models.
So much to build, so little time!
Thanks Nigel and Ulises for the comments and Aussie048 for the like.
I knew it was a good idea not to post any close-ups :D
Seriously it's nice to get feedback. Thanks Nigel for the heads up on garboard plank. I have found that turning the ship the right way up to check planking does help. What looks straight upside down isn't necessarily!!
Nick
Nick,
You can make close-up pictures !
Nothing wrong with it !!!!!!
That looks great that walnut .
Go on like this and your Le Mirage will end up in a museum  :D  :D
Nick,
Happy to have looked in on your Mirage. Looks excellent. Beautiful hull, bow planking. Nice.
Michael
Michael
Current buildSovereign of the Seas 1/78 Sergal
Under the table:
Golden Hind - C Mamoli    Oseberg - Billings 720 - Drakkar - Amati
Completed:
Santa Maria-Mantua --
Vasa-Corel -
Thanks Sjors and Michael for the comments although I'm not so sure about the museum one though :D
Interestingly enough Corel used to supply walnut for the second layer of planking. Says so in the instructions (still) and you can see that on the photo on the box (start of the log). Wonder why they changed to a lighter wood.
Nick
Hi Nick, very nice work on your Le Mirage :)  I am about to start the Corel Unicorn, and actually spent last evening mapping out how to modify the one-piece keel piece to add the stern post, keel, false keel, and various components of the stem.  Your approach is exactly what I'm planning to do and it's nice to see it executed in a beautiful way :)
One thing I'd note - in my limited research, it looks like the scarph joints for the keel run a bit differently - essentially run vertically, so you don't really see the long joint.  I could be wrong though.
I'm subscribing to your log and look forward to your progress!
Hi Sjors
Haha yes you can imagine it. "What no more walnut. Oh well this will do..." :)
Thanks for your feedback Mike. Interesting comments about the scarph joints. I took my inspiration from drawings I saw on the Ancre website but have to admit I didn't really research that area (or any...) properly. Maybe just two different ways of doing them I guess?
Nick
Excellent planking work Nick B)  B) It is no mean feat getting the planking to conform to contemporary style.Are you cutting the planks from sheet or edge bending normal strip?
Kind Regards
Nigel
Evening all
Thanks to WackoWolf, maggsl_01 and Aussie048 for the likes.
Thanks Nigel and Sjors for the comments.
Nigel I am cutting the planks from sheet with a X-acto knife (haven't got space or money for power tools...yet...hopefully :) ) It's not too bad but I think I could benefit from getting a ship's curve for the curved sections. I'm finding it quite difficult to get nice smooth curves.
and then the fiddly stuff  :P  :P
You mean to tell me this is the easy bit??!?! :P:D
Nick
I think even if you did have a scroll saw Nick,the walnut might be prone to breakage with those curves.Even with pearwood on caroline I had the odd few planks relegated to recycling due to breakage.Yes a set of French/ships curves is on my list.I have one of those flexy curves but could I find it :angry: It will turn up when I have no immediate need for it :huh:
Kind Regards
Nigel
  • 5 weeks later...
Evening all
Small update. Another planking section complete. Getting there despite the fact this build sometimes makes me feel like a slow snail at the bottom of Mount Everest... :)  Looking up... :D
Anyhoo enough terrible jokes. Here are a couple of progress pictures:
Nigel a belated thanks for the comment. Yes walnut can be brittle although the stuff I'm using now is far better than what I had when I planked the keel. Now that was horrible stuff.
Thanks for looking
Nick
