Very nice metalwork, Mick. If you are looking at another lathe, I've found a watchmakers' lathe with compound cross-slide excellent for model work. One can find them, often in very good condition, on eBay.
Hi druxey
Thanks for compliment. Still deciding on a lathe looks like a toss up between sherline or peatol(taig). Both available in the UK but sherline tend to be on the expensive side. May also consider an emco unimat.....seen some niceexamples on eBay recently. Decisions,decisions!!!!
Cheers....mick
Mick,
Maybe ... you should keep in mind the possible future extensions you may wish on the lathe you'll buy ...
Carl
hi all
been a little busy of late on other non ship building projects. however have managed to do a few bits and pieces.
the display case for triton has been built.
i just need to turn down two support columns from brass.
i have a pile of bits ready to go on the basic hull form.
been diverted by making a new base and some new locking handles for a recently purchased lathe.
cheers for now
mick.
Looks like a nice lathe. Which lathe is it? Bought in the UK? The reason I ask is that I'm looking for one myself.
Tony
Hi Tony
Lathe is a peatol or taig if you're in the US. I managed to find one on eBay in reasonable condition for £135. Unfortunately all the extras have to be brought separately. The one thing I didn't like was the three jaw soft aluminium Chuck supplied. Arc eurotrade sell a nice little er16 collet Chuck and collets which is what I shall use for the majority of my turning. However er16 only go up to 10mm . arc also sell a four jaw self centring Chuck and back plate which I shall get asap. Various locking points are provided but are 10-32 unf bolts......soon got fed up of reaching for an Allen key so devised some locking handles in brass using a longer unf bolt as the foundation. Overall I'm quite impressed with the machine....for smaller scale work its ideal...its also whisper quiet.
I would recommend it but be prepared to make a few modifications!
Cheers.....mick
Hi Tony
As an addendum new machines are available from peatol machine tools based in harbourne ,Birmingham,UK.
Check out their website.
Also check out the taig website in the US.
Hope this helps
Cheers....mick
Thanks, Mick. Useful info. I'd looked at a Peatol/Taig before and wondered how it would compare with the ARC models. I see it's set up for imperial units only, but suppose that's not much of a problem.
Sorry for diverting the thread!
Tony
Hi Tony
No worries about diverting the thread! The peatol is in imperial but the collets I'm using are metric!I tend to measure in metric units these daysbut will use imperial if necessary. The lathes from arc are all set machines.I have there miniature mill/drill and compound table which I can't fault. However I did have their co baby lathe which I was less than happy with. The larger lathes may be better. Personally I would prefer to buy UK/us its significantly better made and any electronics are far superior. But its down to personal choice as UK and US machines are significantly more expensive.......but you gets what you pay for!
Cheers....mick
hi all
its about time i did some more work on the cross section.
armament and breeching ropes completed.
ring bolts in place for training tackles.
gangboards in place and brackets for skid beams.
now the problems.
i was unhappy with the stropping on the training tackles so have discombobulated the lot and will start again. should be enough room to get them in!
the other two pairs of brackets dont fit! rather than mess about with them i will remake them.
apart from the gangboard railings and turning some pedastals down from brass were nearly there.
photos of current progress attached.
cheers for now.........mick
Mick,
Looks super nice.  Re-check your breeching line length.  The look short to my eye.  The gun should be able to recoil back so that the muzzle is inside the gunport.
Hi mark
I made the breeching rope three times the length of the bore of the gun as per info in swan class practicum. The guns are positioned almost behind the gun port. Still reckon it needs a few extra mm to get to its proper length? No worries there's a couple of other things that need to be redone aswell!
Thanks for the heads up
Cheers.....mick
Mick,
Run one back when your reworking and check... It might just be my eyes are deceiving me.
Hi mark
It may be that even making the breeching ropes 3x the length of the bore I should perhaps have added even more than I did to allow for the turn around the cascabel and the loop and seizing around the ring bolt. A couple look slightly shorter than the rest. Problem is I've glued the ring bolts in with epoxy resin and the trucks are spot glued to the deck with the same.I don't want too damage anything taking it apart so I may have to leave things as they are and putvit down to experience.....it can join the growing list of things to do better on the next build.
Constructive criticism and advice is always welcome....I think I will beneeding plenty when I get round to doing a full hull build!
Cheers......mick
No worries, Mick.  I'm like you.. I can use the advice, critique, and encouragement.  You're doing a super fine job on her.
Mick,
What would modelbuiling be without the helping eye and supportive criticism ... that said, where would be the fun in starting a topic ... I like the progress anyway!
Carl
Hi Carl
Many thanks ....I need thehelping eye these days....even with my glasses on!
Supportive criticism is always welcome.....lots of knowledge lurking about with our fellow modelmakers.
Cheers....mick
magnificent result, Mick, though it does have a slight blue-ish sheen with the glass ... like the display case too! versatile fellow you!
Edited by cog
Carl
Hi Carl
Thank you!its been a labour of love.....you're right about the blueish tint...strange that...looks crystal clear in daylight.
I didn't make the acrylic case I brought it from an online supplier,but not the usual company I use.....mainly because it was half the normal price!
Maybe they use a slightly different acrylic....or it could be me half asleep taking photos!
I did make the base....most core with cherry veneered quadrantmoulding and a bit of madronna burr for the base.
Cheers.....mick
Hi Nigel
Thank you.....looking forward to seeing you're finished triton cross section.perseverance is the name of the game.....I think its been about a year...ish to get to the home straight!
Cheers....mick
I am so pleased to have followed your build - lovely work
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
Hi Carl
Cheers.....mick
Probably the way the light is broken in the accryl. It does have the property to show blue-ish. Hmmm, most <=> mdf ... your mind played you tricks too ;)
Carl
Hi Carl
Once the training tackles are made up and the stanchions for the hatchway I will take some final photos for the gallery...in natural daylight not at 11o clock at night hopefully there won't be any blue tints.
Most=mdf. Predictive texton my tablet.....I will work out how to turn it offone day!
Cheers.....mick
Hi Kevin
Thanks for following along! It's been an interesting experience as an introduction to p.o.f. building.......I think I'm hooked and the dark side cometh! Thanks have to go to all the staff/moderators who did the primary research and drew up the plans and made them available on the forum. I recommend the project to any body with a couple of kits under their belt.
Next up is a fully framed hull with all those lovely frames and cants!
Cheers....mick
Hi Carl
Cheers.....mick
Yes, when you've got a new one, with a different OS ;)
Cheers mate ...
Carl
Hi Carl
New tab will have to wait....just ordered my boxwood for the next pof project...and a new 4k uhd TV.....and a delve into the past with a plastic kit plus photoetch......must stop spending money!!!!!
Cheers....mick
