Hi Dave
You are right, forgot about those echidna looking hulls. Bet you had nightmares when you were doing it.
Havagooday
Greg
Edited by Greg the peg leg sailor
"Nothing is impossible, it's only what limitations that you put on yourself make it seems impossible! "
Current log : The Royal Yacht Royal Caroline 1749 1:32 by Greg Ashwood:...
As a distraction to cutting the hull hatches, the shipyard has proceeded with the hull steps.
I have started the rudder and hinges, next post.
Dave R
Dave R
Measure twice, cut once.
Current Build: HMB Sirius 1786 - Flagship of the First Fleet to Australia (Scratch Build in the Shipyard)
Finished Build: HMB Endeavour 1768
The rudder blade was made months ago.
I made a set of basic hinges(not happy and their gone), and then made another set of longer ones, got a little bit better at bending where the hinge pin goes.
I aligned the hinges and pins(tube) with a rod and super glued the pin to each hinge. So they all are straight, well I hope they stay that way.
The hull hinges will go around the longer end of each pin.
When I get there - more pictures will tell the story.
I better sand the lower hull below the wales so I can glue the hinges onto a smooth bum(at the stern that is).
Then maybe start the main hull hatches.
Dave R
Dave R
Time for an update to the Rudder #1.
I made the hinges from strip or sheet brass metal.
The rudder hinges from 2mm brass strip.
The hull hinges from thin sheet(cut 2mm strips) with the thought the sheet being thinner, it will bend to the shape of the hull better.
Dave R
Edited by DaveRow
Dave R
Rudder #2:
I used tube for the pins, so a rod could pass through to align the hinges pins, so at best the rudder can pivot.
Pictures shows the rudder hinges - test fit for alignment.
The rudder was also tapered a little.
My attempt to braze/solder the pins to the hinge failed, so they were glued(quick dry stuff). But any twisting effect would break the bond. Problem ! See next Log.
Dave R
Edited by DaveRow
Dave R
Rudder #3:
Ready to mount hinges to the hull - at a future time ? as I know it will get knocked, maybe damaged over the many months/years of the build.
A lot of touching up of the blackening to the brass. Gets knocked about during fixing.
I added tapered infill blocks between the hinges(shown in AOTS), apart from filling in the gap, this helped secure the hinges/pins(glued all around with epoxy).
These blocks(with space below the pins) allow the rudder to be removed when mounted on the hull.
A bit of sanding to go on to smarten it all up.
Maybe I will mount the hull hinges and rudder to allow the other associated rudder work. The fixing of the hull hinges depends on what I do with hull finish. Toying up to leave as is - timber plank look, with maybe a stain applied under the waterline. Definitely no white though.
Dave R
Edited by DaveRow
Dave R
Mid deck steps:
Not real happy with the steps - they are made from the bits supplied with the kit.
The side stringers are too thick, they need to be thinner I reckon, out of scale.
and not quiet high enough, probably add a 1mm timber packing strip under the 2 legs to raise them up so top flush with rear deck.
The packing strip to act as a block to distribute the stringer load on the deck. ??
Dave R
Dave R
Rudder straps look really great Dave.  Have to agree with you on the steps, the ladders on my Snake are exactly the same but being taller the odd proportions are less noticeable.  On my Jason build, I'm committing to make my own.  Have you considered round off the top leading edge, that might make the proportions sit a little better without any packing.  Just a thought.
Cheers,
Jason
In the shipyard:
Rudder #4
Well the shipyard was eager to fit the rudder to the hull.
I am pleased the fitting all went well, though it took many hours of fitting the hinges to the hull and filing the pins to allow the rudder to come off. Yes I was keen to have it removable for the rest of the build.
And it swings P and S well.
Pics enclosed.
Dave Row
Dave R
Thanks for your comments Beef Wellington and Greg.
The mid deck steps:
I thinned the side stringers down a wee bit and added little feet under each.
Not glued in place yet.
I think I will run with this though, the proportions look better.
Dave R
Update 29/6/15: added in third Pic. The feet are bit narrower and glued onto the steps. Run with this.
Edited by DaveRow
Dave R
Doing a fantastic job mate. Keep up the brilliant work.
Regards, Scott
Completed builds:
Awaiting construction:
2 x Bow loading ports.
Change of style a bit on the ports. Using eyes/pinned to the hull, to hold the hinges. They are on the outside of each hinge.
I used a rod to align the 2 hinges and whilst the glue dries them to the port cover.
When the glue dries, pull the pin out, covers off and:
- drill fit the fake fixings(6 pins and a eye each)
- fit short pins to the hinges and hull pins
They fit pretty neat.
The pictures show up any scratch eh! Bit of touch up to do again.
Dave R
Update: added in ports after rod cut to length and all glued in place.
Touch up to come.
Edited by DaveRow
Dave R
Hi Dave,
Just catching up on your build and she's looking real good.
Cheers
Slog
_______________________________________________________________________________________________________________
HM Bark Endeavour (First Wood, On Hold)
Borodino (1:200 Card, Current Build)
Admiral Nakhimov (card 1/200)
Mazur D-350 Artillery Tractor (1:25 Card)
F-8 Crusader (1:48 Aircraft, Plastic)
Hi Paul,
I agree totally. My kit stern parts was nothing like the Parkinson's sketch, so I built if from scratch.
Made some errors along the way, did my best to rework some of the build and come up with something with 4 windows and hatches. Mie is not finished yet, still has carvings to add on.
Is it like Parkinson's ? Working in with the constraints of kit hull, maybe similar, not exact, but what is exact anyhow.? As you said "no plans of the ship"
Dave R
Dave R
Mate, if you're happy I'm happy. Good to see so many endeavour builders have joined us, even if I've flitted over to the dark side for a while.
Greg
Shipyard finally has the 3 larger hatches on the side of the hull.
90% happy :) with them, very fiddly work making them hinges.
Next is the mid size ones.
Updated Sun 26July2015:
Added pictures with starboard ports open.
Dave R
Edited by DaveRow
Dave R
Airing Ports - update
The shipyard got smart on this one. Well hope so.
We made a jig to mount the small port timber, the 2 hinges, eye bolt and temp pinion(nail).
The series of picture hopefully indicate the alignment of the hinges whilst they glue onto the timber port.
I also have a hole drilling jig that I will use to position the eye bolt holes into the hull.
Next Post.
Dave R
Dave R
Airing Port Jig.
Bit crude, however does the intended job.
I use the crappy looking hinge glued onto a scrap piece of planking, with 2 holes drilled in the brass hinge. These are same as for the previous post alignment jig holes for the 2 x eye bolt pins.
Pic:  Port Jig1
The jig is positioned into a airing port on the hull, and the 2 holes drilled through the brass holes.
Pic:    Port P1
Holes drilled above the hull hole
Pic:   Port P1 Port01
A part completed Airing Port fitted to the hull(with tmp pin).
Some more work on the pivot pins to go.
All this takes time, esp. making the sets of hinges, eye bolts, jigs etc.
And I still have the lower Airing ports to go.
Dave R
Edited by DaveRow
Dave R
