Deadeye from a kit are replaced: the bottom deadeye with a diameter of 5 and 6 mm from a pear covered with a black pigment
Best regards,
Garward
Is under construction Montanes
Ready models Golden Star Corsair San Francisco II
Bronze 24-pdr canone Le Fleuron
Bronze 24-pdr canone Le Fleuron (second version)
Deadeye are connected to chains.
Edited by Garward
Best regards,
Garward
The deadeye and chains are prepared for installation: are tried on on installation sites, are truncated, the ends are riveted.
Best regards,
Garward
In the ends openings under fastening to the hull are drilled.
Best regards,
Garward
In chains I applied jeweler mills to drilling of openings.
Best regards,
Garward
Details assembled
Best regards,
Garward
Garward,
I'm amazed at the improvements you make, time and time again. I can re-read your build log and each time I find something else I forgot, and remind me to keep it in store for when I'll need it - since it will be vaporised from my mind, I'll be reading your log again ...
Carl
Hi, Carl, thanks for the comment!  :)
Best regards,
Garward
The bottom deadeye and chains fok-masts, the left board are established.
Best regards,
Garward
Cable - "template" for the direction of installation of chains.
Best regards,
Garward
The bottom deadeye and chains mainmast, the left board are established.
Best regards,
Garward
The bottom deadeye and chains fok-masts, look along a board.
Best regards,
Garward
The bottom deadeye and chains mainmast, look along a board.
Best regards,
Garward
Hi, Keith, thanks for the comment! Work on replacement in itself not difficult, but long and tiresome. There is a lot of these channel deadeye  :)
Best regards,
Garward
You couldn't use the instructions if you wanted to, as some chains dont even meet at their bottom deadeye in the instructions.
Like the 3 on the left.
Looks like you had to more the whole channel sternward also.
Yes, we had to focus not on the instructions, and the finished model, such as this http://www.modelismonaval.com/galeria/category/100-navio-qel-montanesq-salvador-pallares-ruiz
Best regards,
Garward
There's a NICE patina on the copper on that one.
Beautiful, its good to have models for reference over instruction.
This model shows Montanes in the state since 1805, when its bottom covered with copper plates. From 1794 to 1805 years Montanes in the bottom of the copper plates was not.
Best regards,
Garward
As assembly plates, and also anvils, etc. measures of hardness for Brinell (НВ), applied to calibration (checking) of devices well are suitable for measurement of hardness of metal: steel tiles of the set hardness with one polished (non-working) and one polished plainly - parallel surfaces. After the working polished surface is used (it is covered with very superficial prints of balls), measures become unsuitable to application for the intended purpose and jump out scrap metal. Some such used measures with a hardness about 400 НВ (for steel very high hardness) and well ground non-working surface, I "lifted" literally from a floor and I use for construction of models (see, for example, photo on the previous page). Possible sources of measures of hardness - all industries where devices are applied to measurement of hardness of metal: various laboratories of mechanical tests of metals other.
Best regards,
Garward
Garward,
I can't find those blocks on the floor anywhere ...
Carl
Hi, Carl, I too found them not in any place, I was lucky: at institute where I work, devices for hardness measurement are used  :)
Best regards,
Garward
Installation bottom deadeye and chains mizzen-masts, left board.
Best regards,
Garward
Bottom deadeye and chains mizzen-masts, left board are established into place.
Best regards,
Garward
Hi, Keith, thanks for an assessment!  :)
Best regards,
Garward
The bottom deadeye and chains mizzen-masts at day lighting, the finishing covering isn't put yet.
Best regards,
Garward
Bottom deadeye and chains mizzen-masts, look along a board.
Best regards,
Garward
General view of the hull (the left board) around a mizzen-mast with the established bottom deadeye and chains.
Best regards,
Garward
General view of established deadeye and chains of a foremast, mainmast and mizzen-mast (the left board).
Best regards,
Garward
