Charles Notman by Jond - FINISHED - radio - 1:48 scale Downeast Schooner 4 mast built by Percy Small 1894
The joy of living on the Maine coast is I have not too far to go. Actually I will not be able to get it in to my suv with masts and jib boon, as we are just @7 feet. A friend has a van and a dock. I also have a rough path through the woods to a pond behind the house.
, but a long walk up and down hill.
It will be a challenge. I plan to build a wagon like the pond yacht guys...but much to do beforehand
Cheers
Link to comment
Share on other sites
oops I hit reply too early
The owls head Transportation Museum near Rockland, Maine has a models' show the last weekend of March each year.  The various local clubs and other individuals and a few working craftsmen all come to share . The variety includes shipmodels, several more active RC clubs with Lobster and other working boats a big item.  Military modeling both static and operating, cars , HO scale construction cranes and barges as well as furniture miniatures were there.  The airplanes are amazing and the engineer society included all kinds of historical and adventurous made steam engines and moving tools etc.
Our group the Downeast Ship modelers Guild out of the Maine Maritime Museum in Bath was well represented both at our own table and three other areas where members had their own show. FYI the Dark Harbor 17 sail boat in the photo chasing the schooner like a pilot fish is one of my older models.
I felt I needed to have at least basic covers and houses ready before showing of the model.  I made up the basic fore and removable middle cabins  and committed to the dark green top color that was popular for an add. The books say a new boat was launched with oiled deck house tops, but after a few years they would be painted out.  I am trying to show this model several years out, because the hay day of these ships was 20 years after this early one was launched.
There were a few tables of miniature furnishings near us at the show, and a craftsman was there who specialized in the proxxon table saw. He makes amazing small scale picture frames and furniture. I shared my experience of difficulty working with the small wood and he was great.  He showed me after market saw blades that he happened to sell and showed me how to fix my fence and few other hints.  When I went home I installed the new blade, filed and reset my fence and I am confident I can lower my dimension limit from 1/8 to 1/16.   That means I can rip down the decking.  I will need more practice to get to 1/32, but isn't that the point?
anyway a great mid point break.
Link to comment
Link to comment
Patrick
Thanks I got lots of comments at the show where the interest is in the sailing. Oops I hope she works
I am into the decking now and getting ready to start learning to solder so I can make fittings.
I am also going to experiment with wooden hoops. The copper is a safe workable solution,but one of our guys at the show made them from real oak shavings. Got to try at least
Cheers
Link to comment
Hi Jond
Thanks. No doubt the feedback you would've received from the display, would've been very positive and only served to motivate you even further.
Also, I've said it before, but I'll say it again....this is one ship that I can't wait to see underway. Four masted, powerfully built, all sails fully controlled, not to mention, big! All of these ingredients will ensure that your schooner will be a crowd pleaser on the water.
Well done and Happy Easter.
Cheers
Patrick
Link to comment
Well it's time for some more fun
I started decking using 3/32" by 1/16" to replicate the 4"x4" decking on this older schooner.  I typically use black permanent marker for one side to show the caulking.  There is a little inconsistency in the intensity of the line with this approach, which I prefer.  I will likely stain the deck later but need some time to think about it and see more images. Decking takes a long time, so I need to work on other things at the same time. Thus it takes longer to deck, but remains fun
Time to build the wheel:
  • I studied several approaches through other building logs and came up with the following concept.  Cut three rims of thin plywood for the rims, turn a hub and use simple mortise between rims for the spokes
  • proto type or practice...see photos
  1. I started by taking 1/32" birch plywood and cut three holes 1" diameter.
  2. I then used sander and files to get shape of on center large and two outer smaller.  I then took 1/16 dowel and used small square file to cut mortise on either side. I added a pin to fit the hub and tapered them a bit.  I took a 5/16" dowel and shaped the hub on a lathe and drilled 12 holes for spokes and center hole for shaft
  3. I did a glue up
  4. My crew of scale construction workers showed up, so I put them to work on the decking
  5. One of guys was a sailor and seemed upset about the mess of lines on the foc'sle deck
  6. After sizing the mock up and checking both the plan and several photos, I set my size to be based on a 3/4" ID for the rim.  I repeated the process in a smaller size and stained the parts.  I tried ends of toothpicks with their natural taper and liked the look.
  7. second glue up
  8. I set the wheel into the wheel house and with the figures think I got the size right.
I am trying to put picture in the text and think I need to post then edit ...here goes
it did not work so I try to attach them as a batch
Edited by Jond
Link to comment
Hi Jond
I love the detail work that you're doing. There's no doubting the skill you have and the quality of your craftsmanship, that's for sure.
What's more, those scale figures that you've put on the deck, are so lifelike, that they bring a whole new dimension of reality to your ship.
Well done!
Cheers
Patrick
Edited by Omega1234
Link to comment
Patrick
thank you for your encouragement and kind appraisal.  I have so much to learn.  turnbuckles under way....wow
The scale people are great.  I got them from the inet and they are Lionel train figures which happen to be 1:48.  I wish I could find some mariners.  These guys  will work just fine.   I will cut the hack saw and he can be pulling a line, the welder can visit a cleat etc.  They are incredible to help me understand the size.  example, I need to put in a few boards[ steps] on the side bulkhead for the crew to climb up to the foc'sle deck.  Having that guy there in the photo helps decide that three boards 3/16" by 1/2" are just right.
I am getting more excited as the weather turns in the right direction. so much work to do if I can get to the water this year, but also many coming distractions.  I only have three days this week then off to see the kids
cheers
cheers
Link to comment
good news and oops
We had our monthly meeting at the Downeast Shipmodelers Guild and Don a member brought in his Bluejacket kit of Charles Notman 1:96 . He is doing a beautiful job and it was enjoyed by all of us.  We discussed different aspects of the coloring of oiled mast and decks, paint on waterways, roofs, hatches and shear planks. I came away feeling good about some decisions and relieved that I could use a yellowish tan as I had planned for the shear line and not figure out how to do gold....save gold for the navy
If anyone out there is also building the Bluejacket kit give a shout.
Every once in a while we need an oops to bring us back in line as students of this art.  Jim,  a long time expert on Maine schooners and a neighbor returned from a  southern winter.  He has several articles to his credit on these exact schooners.   He came to the house to see my progress and we went off to the meeting.  During the ride home he told me I had the wrong rake in my masts.........oops.  I said [ the student] but I took them off the plans....he smiled and said perhaps I could check again.
I found that when I calculated the rake I had set the masts at their correct position on the deck and pushed a brass pin one inch forward on the top riser [ mast step].  that was my oops..... when I rechecked the 1:96 plans it was still one inch at the cross trees to the vertical up from the step [ some how I used this measurement]    I drew a new line down from the deck to the top riser and it was 1/4" forward to the step   going to 1:48 that means my pins should be only 1/2" forward.
For three of the masts this was no big deal.  I had access to the step and with an extension on a hand drill could drop through the finished mast holes and drilled new pins 1/2 back to the right location. A little sanding on the blocking under the deck and all three went into line.  The foremast was more difficult because of the completed deck house.  I removed a center section of that roof and had to redo its hole as the main deck was the right position.  I could not get a drill down through both house and deck, so I beefed up the blocking at the deck house roof and shimmed the mast to align. I shall also add a sharp pin in the bottom of the foremast when I step it permanently.
In the photo I have turned the boat on its side to paint the yellow shear plank and you can see the rebuilt deck roof.
Jim had recommended I add to my library a book called Fly Rails and Flying Jibs.  It is published by Mystic seaport and contains an incredible annotated collection of photos of coastal schooners of the period.   While looking through these added images it was plain to see that the small 4 degree rake Jim suggested is correct and the side view of the model schooner is much better now after the fix.
so all is well and we are  moving forward
Edited by Jond
Link to comment
Link to comment
Patrick
Spring is here in Maine.  I am outside more and more.  tomorrow off to see the kids......time does fly
Sailing these schooners?
From all I have read and been told, none of big schooners sailed well.  The bigger ones, 5 and 6 master and another 100+ feet long  could hardly come about at all and often would only jibe.  Apparently to go from Maine to North Carolina they would often sail out to Bermuda, jibe 270 degrees and sail into the coal docks.  Then coming north they could almost make it on one tack with Southwest winds summer and north east winds winter
in real inches, the mainsail is about 2 feet tall.  I have some 50 inch Marblehead pond yachts with 6 foot masts.  they are made to sail!     I will be happy to sail and turn at all.
cheers
here is photo of old 4 master leaving Boothbay harbor about 1930.
Edited by Jond
Link to comment
The posting below was done while I was under the microsoft Windiow Explorer 11 trance.  After reading tech posts in this forum, I decided to try free fire fox and guess what.....it works. :D    I went ahead and fixed the long posting of photos by putting them in the right order with a little text.     much clearer
As I said before........
well it was time to start production of perhaps 70 turnbuckles as well as to 'begin' completing and staining the deck; which means a few more bitts and things.
turnbuckles.  I set up the photos to track my trial and error approach.  I am sure after this boat I will be better prepared to start the next.  I also hope to get more comments.  here we go
  1. post-9397-0-99694500-1429133627_thumb.jpgset up: after watching several videos, you tube etc. I bought some tools and things and mixed it in with what I had.
  2. post-9397-0-98344800-1429133639_thumb.jpg  here I made one up;  I used a jump ring instead of a shackle.
  3. post-9397-0-39507100-1429133649_thumb.jpg here I put  1/16" rod in  3/32" tube for strength and filed away to make the side openings
  4. post-9397-0-62655400-1429133665_thumb.jpgstep 2 I used a tiny file to clean up the opening as we want to see threaded bolt inside
  5. post-9397-0-94987900-1429133675_thumb.jpgstep 3 I drilled three small holes through 3/32" x 1/64" brass. I then reamed out the middle hole by hand and then tapped it for 0 by 80 brass cap screw. It then threads on making a strong connection possible.
  6. post-9397-0-44833100-1429133684_thumb.jpg I filed the head down on a 0 x 80 brass cap screw and tightened it up, and t hen bend it to make the clevis.  small pin is to be soldered in ...not in photo. sliding the bolt into the barrel I crimped it. after crimping it still turns but will not pull out.
  7. post-9397-0-08561300-1429133692_thumb.jpg   I took a second cap screw and filed the head to a v groove and soldered in a jump ring. I am experimenting with copper brass and " mystery white metal" rings as eventually I need to make them look like galvanized. here I have a large failure rate as I am learning the skill.
  8. post-9397-0-73149700-1429133704_thumb.jpg  I made up shackles with 24 gauge copper wire  and added the pins and soldered.
I need help here
I plan to dip all in blackener. The chain plate and schackle are to get black, but all above that is to become galvanized. Well we shall see how this goes; I have no plan yet other than possible silver paint for the galvanizing process.  That will go for chain too when I get ready for the bow sprit.
Deck completion:
 there is lot to do here, so I wanted to advance different areas so that I can keep up the variety of daily tasks.
  1. post-9397-0-05418900-1429133718_thumb.jpgI experimented with stain color and opted for a little darker as I completed the foc'sle deck.I like the " motley look"
  2. post-9397-0-02882800-1429133732_thumb.jpgthe main deck is done, lots of detail let on the house.
  3. post-9397-0-03385100-1429133761_thumb.jpg I started to trim out the hatch covers. The hatch frame is black and the tops shall be oiled plank. Lots to do to make the doors and windows and and etc :huh:
  4. post-9397-0-11632500-1429133791_thumb.jpgreading the detail, I found that the aft bitts were totally sheathed in brass and like the bow have  bronze caps. After installing I am wondering how to get the top brass to look more like bronze. I think I would like the look of a foil here and at the bow bitts too.  not sure where to get brionze foil.
  5. post-9397-0-80256200-1429133772_thumb.jpgI cut some tube to wrap the bitt tables.
  6. post-9397-0-66610600-1429134078_thumb.jpgoverall shot of the condition of the deck as we take another break to visit the kids in Arizona.
I am now 'wicked' happy as I learned how to post pictures with annotations....good by to MS EXPLORER
jon
Edited by Jond
Link to comment
Hi Jond
That's some really nice metal work you've got there, especially the aft-bit that's sheaves in brass. The turnbuckles also look nice but fiddly; so I take my hat off to you for your perseverance at getting them done.
I also really like the colour of the deck. It has a warmth and richness to it that's really welcoming.
All the best as your progress continues.
Cheers
Patrick
Link to comment
We got back from a week in Arizona to find our Maine spring trying to get under way.   This was a short week, but I got a few things done.
I got back on the turbo cad and transferred offsets to create a 1:48 set of sail  template drawings.
I used my wifes' large format printer that actually gets to  13" x19" that allowed one sheet templates for all but the spanker.
setting up these templates one can see that pretty though she may be, sailing quality will be a challenge since the centers of effort are so low at the model size.
I used details from Douglas Lee that I found interesting.  On the starboard side of the standard sail there is a 1 foot liner and the rope and on the port side a 2 foot liner on the leach and luff and what could be a 3 foot liner on the port foot.  This two sided lining led me to an old trick I learned by trial and error of taking  a 7/8" oyster bias tape and cutting it in half.  I then glued it to the edge giving a rough ¼” on the one side and just under ½” on the other.  For the sail foot I cut the tape to give me a three foot liner.   I also have ¼” bias tape and I fabric glued that for the reef band.
Then I got into trouble as I snuck up stairs to sit at the sewing machine. This nice machine is auto set for tension and things, but I can set the length of the stitch.  One of the troubles with 1:48 scale is the seams are only ½” apart and puckering is the name of the game.  I did the foresail in the standard set of 2mm and it looks like a big lemon was nearby.   Today I tried 1.5 MM stitch length on the mainsail. [ my logic of small means less]  You really can’t tell until it is too late.   I plowed through and got done and was again disappointed.  I tried ironing after, but reality is these will not be ironed in place.  When I showed my dear wife, she told me that of course a larger stitch and not a smaller one would apply less tension.  So the Jigger is next and the first pass will be 2.5 mm or even 3mm.  I also may change and reduce the size of the thread, though I am not sure that is relevant
if this one ends up as a first attempt and I fix this problem, then I won't mind leaving this one behind
this partial main sail will likely become a great rag
I also have some jewelry supply hemp string and again I tried to use it for the bolt rope, adding brass jump rings for the four connections and 4 reef points. I am supposed to stop the rope, seizing it at each side of each reef band ring.  I am looking for more demerits  as I likely will bypass that detail by simply adding the rings at the end of the reef bands for looks.
Sail material and advice:
I know Lextin said ...use suplex….  And Jerry Todd used it as well in his build, and before this is over I might just do that too. I went to the vendor web site and color was either snow white or what I might say a selection of modern colors. I love the natural color and defects in old fashion muslin when trying to be ugly old canvas.  Gluing bias tape to the sides then sewing is easier than fold - glue and sew. it is the seams that I am fighting.  Also this boats is to be able to sail, not race.
I will show more when I get further into and solve the puckering or give up and go modern.
deck and stain
As to the deck, it is like a child…..I love my children and like my deck.
I am not sure if the constant change in color is good, I used two different stains and like what I have….it is not furniture. I imagine there were spills and many issues after the shake down cruise. it was oiled [ some say pine and some say other] and a bit messy I believe.
I darkened all my masts after review with others and reviwewing the photos in the new book to me Fly Rails and Flying jibs
it shows a bit in the next photo
I show the fore top with the newly installed futtocks shrouds. I am proud that the collar is my fist ever blackened brass.  I made those along with the three gaff block bands in 1/16" x 1/64" brass.   Drilling the little holes is a challenge and to take on so many is all new to me.    I did not make the three fittings that go from rod to hook to a  pass though- double eye. Running the precoated copper wire through the cross tree and making the eyes to receive 16 more turn buckles was enough for me.  I am adding gaff blocks and fitting out the spars as I need them ready to sew on the sails before installation. I love Patrick’s characterization of my new task in turnbuckles as fiddly. it is a bit overwhelming and I need to get back to it.
Link to comment
Link to comment
Link to comment
Patrick
I am not a RC sailing expert, but as I have followed it along over the years, I have watched several type boats sail. Many discussions come up on hull speed to scale, ability to come about etc. Here are two images of popular and traditional designed pond yachts.
post-9397-0-31420100-1430233420_thumb.jpg This is a recently designed 50 Inch Marblehead class with 76 inch masts and tall [ 70 inch luff] slim sails called the Naskeag. My son and I started one each some 15 years ago and I finished them up last year. They have yet to see the water. This photo is a regata....see how high the sails are with respect to the hull length. The COE scales about 26 inchs above the deck or just > 1/2 hull length.
post-9397-0-88584100-1430233390_thumb.jpg here is a classic 1936 design Gus Lassal that I built 15 years ago. I rebuilt it from copying a broken antique [ that I have partly restored and plan to complete some day] and bought the sail in marblehead, so I could properly size the mast. It was a classic design and its COE is a few inches lower but still not much less than 1/2 the hull length.
post-9397-0-00937500-1430233971_thumb.jpg here you can see the Downeast frieghter with the sail templates .... the lower masts average 22 inches above the deck and COE is roughly half of that . Lets say 11-12" and when I add the upper sails I may gain a few inches. Being generous lets say 15 inches all in above the deck. The decks of the Marblehead and this schooner are similar above the waterline. Therefore we have a similar calc comparison of COE to be 1/4 of the hull length above the deck. So the question is....will I be able to come up into the wind?......we are going to find out .... i sure hope so, or I may have to get a better chase boat.
Edited by Jond
Link to comment
I'm not a native English speaker, nor familiar with the abbreviations. Could you please explain COE and LOE, so I might understand your explanation ...
Carl
Link to comment
Carl
The abbreviation COE is center of effort. It is the center of area of the sail. It creates a moment force relating to the waterline. Because the sail area of the schooner is similar to the pond yachts it is interesting to notice their moment will be much less. Thus the ability to force the boat to come about (bow crosses the wind to go from starboard to port tack by example) could be a problem.
Cheers
Link to comment
Hi Jond
Many thanks for your explanation and the photos, which I found very interesting. If there are inherent shortcomings in the ship's sailing charchteristics, then I hope they don't detract too much from your enjoyment of her. Incidentally, just looking at the profile shot of the template sails on the yards, I couldn't help but think that she did look slightly underpowered, for such a big hull, but I'm sure that's not the case.
Regardless, I'm really looking forward to seeing your ship underway. I hope, if possible, that you're able to post a video of the ship underway.
Cheers.
Patrick
Edited by Omega1234
Link to comment
Jond, I did not know that about the schooners,  But when coming about, as you turn farther into the wind the sails quit pushing and you start coasting.  The drag of the water on the hull and the drag of the wind on the sails slow you down.  If you do not have enough speed prior to coming about you will lose too much momentum for the bow to pass the point of the wind and push you on over to the other tack.
Bob
Current build:  SS_ Mariefred
Link to comment
Well I am finely back at it.  Spring clean up does take away lots of our time!
I am now focused on production in two areas, sails and fittings/ turnbuckles as well as general progress on the hull, spars and deck
Sails:
  • I continued the trial and error process and made all four sails. I then decided that three of them are for the trash bin.  The best approach to the puckering I found  is to stretch the cloth while sewing the seems.  I learned to tolerate reality when I remade the spanker. It was my best sail yet and looked great with very little puckering.  I set it on the table ready for applying the rope etc., and after one night it looked like all the others.   Of well. the color and texture are OK, sailing quality of muslin is likely down a bit I am sure, but I need to move forward.  Remember this is a proto type  ^_^
  • For the production cycle on 16 sails I have decided to do one step on each sail each session, so that I have many activities going on.  The list includes, turbo cad drawing and trial design of each new sail; layout and marking for first machine sewing;  gluing and machine sewing bands; hand sewing the rope and rings; hand sewing to the mast and spars.
  • post-9397-0-86448800-1432050552_thumb.jpg  Here I am laying out the spanker
  • post-9397-0-39759600-1432050554_thumb.jpg Here I have glued on all the bands [ bias tape]. I since learned it is better to sew the seems and then add the reef bands over them.
  • post-9397-0-75317600-1432051101_thumb.jpg Here I took the dimensions from the small scale sail plan and plotted it on my 1:48 plan. It printed it out and  actually came pretty close. I did have to move the clew a bit forward and raise the tack.
  • post-9397-0-62169700-1432051103_thumb.jpg Here I took the completed new foresail,  laid it out and placed the cut out gaff topsail to trial fit before machine sewing.
  • post-9397-0-83955900-1432051105_thumb.jpg Here I have accumulated a back log of three sails ready for hand sewing on the ropes and rings . I am doing that work upstairs while watching night time TV.  The Red Sox , however are not doing very well.
  • post-9397-0-82358900-1432051107_thumb.jpg Here is the foresail  sewn onto the spars.
It took some time to go through and trim out the spars. I needed to make the bands, add on the blocks and get everything ready to go. I hope to have each one fully complete before installing.   This also gives me more time to work on the hull and deck fittings.
  • post-9397-0-95881700-1432051860_thumb.jpg Here  I am ready to sew the main sail to the mast and spars. note the topmast shrouds are in place.
  • post-9397-0-70040900-1432051865_thumb.jpg Here I have cut out and have waiting 2 gaff topsails. It is now two steps to sew seems and the add reef bands over the seem lines and machine sew.
  • post-9397-0-23899300-1432051869_thumb.jpg here each session I need to draw another sail. I have conflicting information on the seem direction for the staysails.  I chose the Bertha Brown design with the seems parallel to the luff. I need to add reef bands.
Fittings:
  • I mentioned above lots of work making many eye bolts and bands for all the spars. I also taught myself how to blacken as an alternative to paint.  I asked for outside advise and found paint is the only likely way to simulate galvanized metal where applicable.
  • It is possible that the change over from dead eyes to turn buckles was coincidental with this schooner.  There is in fact a drawing that shows 8 foot chain plates and dead eyes on this early 1894 design.  However  they would not have been very practical and typically all schooners of this era used turnbuckles and steel cable.  Therefore as I have stated before I am using 5 foot chain plates and 4-6 foot turnbuckles as this represents the era.
  • post-9397-0-03873400-1432052599_thumb.jpg  I experimented with using silver paste to connect several 3mm jump rings to the heads of the cap screws.  I had beginner's luck, but quickly found my process not giving me the strength.  Here I went to the old fashion flux and silver solder process and got a stronger joint, Unfortunately only 2 at a time.
  • post-9397-0-33030600-1432051873_thumb.jpg for the rest of the turn buckles, I make 4-6 pieces at a time. My small drill press is priceless to drill all these many holes in the 3/16 brass for clevises and the 1/16 brass for spar bands. We all know that drilling brass is tricky and with a hand held dremel would be very difficult.
other stuff:
  • I went to our monthly meeting at Downeast Shipmodeler's Guild and learned several things from a real fiberglass expert.  As a result I went to the local auto parts store and got Ever glaze finish putty that fills in the pit holes form Bondo and other minor defects.  I was also advised to not fear and be rougher on an under sanding. After rougher sanding use the filler putty and get a smother finished hull.  The result is learning how to make a better finish and even though that means a step backward, this is be the last real time to do it. I will try to get that done in the next several days. part of the recommendation was to also use auto body filler primer. Unfortunately it only comes spray. I  need to go all brushed paint from now on and especially in the future any damage would be repaired by brush.  so no filler primer on this model.
  • I will next lay out the 60 ish chain plates and other connections for standing rigging and over 100 belaying pins for running rigging.  I have chosen brass 5/16 belay pins as I have so many lines and need to actually connect them. I am not sure if I should paint them silver.
  • I need to think about a float test.  the sea water is only up to 50 degrees, and our pond a little warmer.  I am thinking the first week in June I should sneak it in to make sure she floats.
  • The lead keel... i really need to get this figured out. I think for this year it will be temp until I really know the right weight.  then next winter I can consider to get a nice cast bulb.
So there it is. I wish a session was each day but too many other things.  I will be lucky to get the sails done in June.  I suspect more than that as the weather warms.  To get a sail in this year I need to leave a few things out, so I may leave off the top staysails for this first stage.  I also want to delay much of the deck detail until next winter.   we'll see what make sense.
Link to comment
Maine spring is quick and fickle. We hit a new record low yesterday 42. Anyway I need to get ready for a float test Friday so I have made progress in several areas.
Sails rigging and masts
For sails I simply need to continue chipping away so when the hull is ready I can put in complete masts and rig up the running rigging right away. I remain unhappy about puckering but sais le vis
  1. post-9397-0-15940300-1433369002_thumb.jpg as I complete sails and get them sewn onto the spars I need to start the running rigging.
  2. post-9397-0-26211800-1433369004_thumb.jpg as i said last time I take the machine sewn sails upstairs so I can work on them off hours.  I find early morning works best and those in the photo are all done now.
  3. post-9397-0-65121600-1433369011_thumb.jpg after much consideration, I now believe proper blocks would have been galvanized metal straps and oily,dark and almost black wood.  As on other models for economics I have used the inexpensive bass or walnut made blocks they dont look like galvanized!  I started with them and found another problem.  pre-made blocks stop at triples and they are too delicate to add beckets.  These schooners actually used quads with a single drop to the deck because they used engines to raise the sails.  Gloucester and similar schooners had lines coming down port and starboard out of the top block and bottom. They had one direct to get close and then a whip on the opposite side with double or more blocks as needed to get it tightened up or trimmed.  For this first go i decided to put triple up and double down as that what was available.  I did not like this solution
  4. I started to install all of the belaying pins and deck staples.   These staples mostly take stropped blocks to receive sheets that go up to pins on the rail.  The open main deck has seven blocks on each side that will be very difficult to install in the narrow area beside the fore cabin.  So after much thought, I decided to bight the bullet
  5. post-9397-0-55254100-1433369013_thumb.jpg I went to Bluejacket and bought their beautiful stopped blocks all with beckets.  This allowed me to correctly rig the gaffs with the becket above and triples top and bottom.   yes they should be quads but I don't see any in the market at 1/4 inch.  I chose black to paint out the 'wood part' leaving the side strop, sheaves  and tabs  galvanized.
  6. post-9397-0-81179700-1433369005_thumb.jpgI installed all of the chain plates and have repainted this after the photo.
  7. post-9397-0-54908200-1433369007_thumb.jpg I dry fit a turn buckle and continue the long production.
  8. post-9397-0-49326200-1433369009_thumb.jpg After asking on this forum for feedback the responses i got were for paint as the standard galvanized solution.  Model expo had a 50% sale, so I bought one each aluminum and silver paint to try them out on brass.    They are very close.  I like the aluminum, as there is a little more warmth to it and slightly less shine. I plan to use both.
  9. To get ready for the float test, I needed to get some more lead. amazing, I looked on the web about 3 PM Friday and ordered 20# for normal shipping.....it arrived Monday  wow.  I completed the sailing keel; painted it out like the hull and added two 5 pound weights as a start.
Here is the hull with its new smooth bottom [ I used gloss paint to see the look and I don't like it...next coat back to satin fiesta red which is more like brick red and perhaps red lead.  I made up the strapped stand that holds the weighted sailing keel under the hull.  when ready it lifts up and bolts to the hull and I can lift both out and head for the water.   I have several hand weights in 2 or 3 pound to use to trim.  the current hull is 15#
Link to comment
We we had a great first launch and float test.
I asked a friend to use their fresh water lake site for this first test and it worked out just great.
  • post-9397-0-24444700-1433592071_thumb.jpg here we are loaded into the car. Unfortunately this won't happen with the stepped masts and I am working on that problem.  The stand carries the weighted keel and several weights if I want to try increasing ballast to get lower into the water.
  • post-9397-0-47833200-1433592074_thumb.jpg here we are attaching the sailing keel.
  • post-9397-0-07077800-1433592078_thumb.jpg it was easy to lift and carry a few hundred feet to the lake front dock.  The combined weight is about 28#
  • post-9397-0-82825200-1433592080_thumb.jpg it takes two people to launch and comments were of concern as what to hold onto.   I need to consider some easy to hook on launch lines.
  • post-9397-0-27982400-1433592083_thumb.jpg today there is a little wind and rip of a few inches.   Looking at the action along the waterline I was very happy where at rest the waterline is about 1/2 to 3/4 above the water.  this is safe for saltwater harbor sailing.
  • post-9397-0-93448400-1433592085_thumb.jpg turning away from the dock into the wind, the waves came above the waterline, so I think the current weight is fine. I believe adding the masts and batteries etc are another pound or so and that should be fine.
  • post-9397-0-20248800-1433592089_thumb.jpg  here we are at rest after about 10 minutes. Inside was dry as a bone, so all is good
wow what fun
Link to comment
Link to comment
next stage....bend the sails argh.
I have found the real dilemma here as I tip toe through new territory. How to build at 1:48 but be rugged enough to sail. examples.
  • While moving the boat in and out of car and in and out of shop for the float test....oops there goes the rail. This oops is without masts even being stepped. post-9397-0-00410500-1434574793_thumb.jpg.
  • as I tie off blocks for halyards, I kept pulling them off. I changed two of the throat halyards triple blocks to wire staples up through the cross beam and bent over. A little over kill. I left the others thread as they did not break....yet
  • Yes I am using thread...not lines. mostly 70% poly and 30% cotton from Joann. I bought better for stays.
  • There is also no way I have a vehicle that can move this boat. I do have a small boat trailer for my 12 foot sailing dinghy but really. I will need a friend with a pick up hopefully with a cover
As I go forward I smile and remind myself of my goals. I want a 1:48 scale schooner in most things. I want every line that functions. Yes the major sails' sheets are a little big, but so far that is all. I just need to to do my best and get in the water. If I can build it, I am sure I can fix it, so here we go setting the sails bent. :(
I have moved the boat to my study.....only about 10 feet away from the shop. It has nice daylight and overhead task lights that help with vision. I can work on all sides, and using the strapped stand I can also tilt either way for port or starboard tack. That way gravity helps move the sails out of the way if I need to see the deck etc.
  • post-9397-0-00983700-1434574795_thumb.jpg here we are starting the process. most of the work was done off board to sew the lower sails in place and trim the spars. The stay sails are held by jack stays and are done in place.
  • post-9397-0-70158600-1434574796_thumb.jpg before we can work forward I needed to trim out the bowsprit and jib boom details
  • post-9397-0-26784700-1434574800_thumb.jpg I found from the details on the CORA CRESSY plans on all block sizes, chains and lines. The light chains were either 3/4 or 7/8 and like the stays us lashing with dead eyes. i used light wire to make all the strops with shackle connections for pinning to eye bolts. the larger chains get turn buckles.
  • post-9397-0-95214200-1434574806_thumb.jpg This was fun for me. After turning the martingale I had to do more real soldering. The bottom cap needed a double band forward and single aft.. I also fully soldered the band holding the jib boom down to the end of the bowsprit. It worked but boy I am really new at this task. I used 24 gauge copper for the shackles and painted the chain in place to get it to look like galvanized chain. The turn buckles are a bit shorter, and the two unconnected ones needed longer clevises to allow pinning to the bees. I held up on installing their chains until I run the upper stays that hook to the sides of the martingale and run to the prepared lashing dead eyes. I just want to hand fit the line of the chain and then drill the eye bolts....yes i am chicken
  • post-9397-0-46066900-1434574805_thumb.jpg finally here is the attached foresail. It's a big milestone for me. The sails are threaded up the stay that you can see is lashed to the staple forward of the bitt.
I found a new problem with the top sails. they each have clew lines that raise the clew up and over the brace stays [ not yet installed]. they are like the tack lines [ also up and over the brace stay] and sheets that run either to port or starboard pins. All three sets have one loose to leeward and one tight to windward. For RC schooners the stay-sail rides with the gaff and is like an extension to the lower sail. [ I shall add little lines for that function too] Thus these lines can never be tight; what to do.
post-9397-0-21310100-1434574802_thumb.jpg here you can see the clew lines that run from tack up through the the block held through ridge line boss ring through the sail [ see picture] and then further through a lizard to the peak block and down.
post-9397-0-29111600-1434574808_thumb.jpg here you see the three attachments for each side. the two lines on the side rail are peak halyard and clew line. the two lines at the mast rail are sheet through the leader block aft and the tack to the middle pin.
My plan is to run the tack and sheets continuous through the rings and then leave a bit loose. the clew must just be loose because there are separate peak blocks. After sailing is over I can tighten them up.
  • post-9397-0-63644200-1434574803_thumb.jpg here one can see the tight fit for lines where the lower main deck carries the leader blocks for the foremast beside the forward deck house. I believe using the Bluejacket pre-stropped blocks makes this doable and rugged.
  • post-9397-0-53907200-1434574798_thumb.jpgfinally here we are for progress.... 9 sails on and 6 more to go
cheers Edited by Jond
Link to comment
Hi Jond
It's great to read your update above. First of all, can I just say, wow! The last photo of your ship with the nine sails set, is truly impressive for a number of reasons. Firstly, just the physical size of your ship and, secondly because she is one hell of an attractive ship. I can see why she must have attracted you in the first place!
Can I also just say that I sympathise with you about your transport issues and the potential for breakages along the way. I had enough problems transporting my RC yachts and they were only 4 foot long (LWL). I guess that's something that may have to be accepted in your case as any attempt to move such a ship would be problematic....not that that makes breakages any easier to accept.
On the flip side, it's fantastic that you're reaching the stage where it won't be long before the sails are bent and your ship will be heeling into the waves as she moves serenely across the water.
All the best and I look forward to your next update!
Cheers
Patrick
Edited by Omega1234
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
