STS Leeuwin II by tallshiptragic - 1/56 as she is today 2015
Poop deck is starting to look very busy now. I was putting the helm station off for awhile, though now it's almost done. On the dash are four repeaters showing, depth, wind angle and wind speed, speed over ground and course over ground. Next to these are the displays for each engine showing, rpm, engine temp plus shut down buttons and ignition keys - these keys are only a second step as the engines are actually started below. Also in front of the helm on the dash is a gyro compass repeater - the actual gyro compass is in the chart house. I'll use decals to show these on the helm station.
The other item I've made is the megnatic compass.
Anton T
Current build
1/78 Sovereign of the Seas - Sergal - kit bashed
1/72 Arleigh Burke class DDG flight iia/iii - Sratch built RC - no log
Waiting for further inspiration
STS Leeuwin II 1/56 scratch built (90% completed)
Previous builds - completed
1/72 HMAS Brisbane, Airwarfare Destroyer 2014 -Scratch built RC - completed
1/64 HMS Diana 1796 - caldercraft kit - completed
1/75 Friesland 1668- mamoli kit - completed
1/96 HMAS Newcastle FFG 2011- scratch built RC - completed
1/75 Vasa - Billing Boats - completed
Link to comment
Share on other sites
Just wanted to see how the masts would look :)
All lower masts are steel and only the top masts are wood. The foremast is a little different as compared to similarly rigged vessels, the fore lower and top masts are one single mast, with the t'gallant mast a separate piece. The first futtock is still just above the fore course yard but the mast continues up to the base of t'gallant.
Anton T
Current build
Link to comment
Hi Anton
I knew that you'd be itching to get the masts in place, even it was only as a trial fit!!! I'm exactly the same as you, in that regard.
In fact, being able to temporaily install the masts is really one of those milestone moments, that, more than anything, really gives you a true indication of the dimensions of the model. Will you be putting the sails on as well?
Cheers and all the best
Patrick
Edited by Omega1234
Link to comment
Hi Patrick
Yeah I couldn't resist :) still a long way off fitting them proper but like you said, it does give a good indication of the final size of the model.
I will be including sails - a tall ship model without sails, unless it's in an admiralty style with exposed planking etc just doesn't look right to me. Obviously sails are bent off especially during refit... But still looks odd.
I've yet to decide whether or not I'll have them set or have them with harbour furls.
Anton T
Current build
Link to comment
Hey Anton,
You're making a very nice ship over here - with some remarkable fine details!
Personaly I should fit her with furled sails - as this still give you a nice view on rigging and decks (although it makes it a bit more difficult as the fabric is often to thick to make realistic furled sails).
Hans
Owner of Kolderstok Models - 17th century Dutch ships.
Please visit www.kolderstok.com for an overview of the model kits available
Link to comment
Hey Anton,
She's coming along very nicely!
John
Thanks Hans, I am leaning to having furled sails. I might set the mizzen sail as if she is at anchor. In very light winds we set the mizzen to keep her pointed into the wind. I've also decided to show the port davit rigged outboard with one of the dory's attached with the starboard dory secured on deck, again just to show how it all works. I won't be using fabric for the sails - as you say it always looks over scale and our sails when furled are very very tight fuels so most likely will be using tissue paper or the like.
Thanks very much john. We're back in a couple days from this voyage to do a few day sails and prep for our run up north of WA, so hopefully get some modeling in before we head off for that stint.
Anton T
Current build
Link to comment
A bit of déjà vu for our chief mate yesterday morning. His last ship the Queen Mary 2 passed us. He was the chief officer on the Mary before coming to us.
The first photo, we tried to replicate an old Cunard poster from the 30's of a sailor on the bowsprit of a tall ship while the first queen Mary steams past. Think we did a good job of that one. The second one I took aloft on the foremast.
Edited by Tallshiptragic
Anton T
Current build
Link to comment
Back ashore, so thought I'd get some more deck detailing done.
There's a few wooden deck boxes to still be made up, anchor windlass and bollards but first I wanted to get the life raft containers made up.
I used plastic tube as the basic structure, covered the ends with sheet and strip and half rounds for the supportive bands and seal. So far only the basic structure are done but all 6 have been started. Making them together one step at a time is far easier than only making one full container at a time.
Leeuwin has 6 25 person liferafts, one aft, one forward and four midships. These are all SOLAS so completely enclosed offshore life rafts with individual epirbs.
Anton T
Current build
Link to comment
All six canisters made up. The four midships are slightly smaller than the ones forward and the one on the poop deck as there different makes but still 25person rafts.
The black straps are the packing bands which I used black coated copper wire. The tie down straps are artist tape which is glued down but colour wise match the real straps perfectly. The hydrostatic release is just plastic tube painted orange to match what we have on Leeuwin - does the job I think. The weak link on our canisters are attached to the shackle which holds the strap and hydro release so the painter is attached to this and the left side of the canister.
Also the canister on the poop deck is fixed slightly off centre on purpose as the real one doesn't quite sit perfectly :)
All that's left is to add decals, I'll make these up on my next print run of decals.
Anton T
Current build
Link to comment
Added bollards today and also made up the rescue boats bow line. This is attached to the port aft spring bollard. A lanyard is attached to the bow line to one of the stantions on the poop deck - this is for easy and quick retrieval after launching to keep the line away from the port prop. At the end of the bowline is a spliced eye. On the rescue boat itself there is an attachment spliced on to an eye on the bow with a wooden toggle- this toggle goes through the eye of the bowline attached to the ship. Again this is for an easy release and not having to worry about untying knots in an emergency. Another lanyard is attached to the rescue boats toggle to the inside of the rescue boat. One to easily pull the toggle out and pull the line into the rescue boat without leaning over the side.
A mouthful, so have attached a sketch to show it clearly I hope :)
Anton T
Current build
Link to comment
Hi Patrick, thanks.
Yeah I never built her in the past because of it. Problem is we'll be in refit in two months so some deck fittings at change. The rig always changes depending on which set of sails we have on. Currently we have the oldest set of sails on her, some from the 90's and some from the early 2000's. While the sails are technically the same size - depending on who was the sail maker at the time, they may be cut differently so positions of buntlines etc are not always in the same spot :) the joy of a real ship!
Anton T
Current build
Link to comment
Roughed out the pin rails both on the bulwarks around the fore and main mast shrouds and the pin rails around all masts. You will see there are extra rails where the fore and main shrouds will be, these are purely steps to help step onto the shrouds.
The rails are just pinned in place at the moment. Final cleaning up and of course addition of the pins still needed.
Anton T
Current build
Link to comment
Wanted a couple less cluttered pics so pulled the model out into better light.
Anton T
Current build
Link to comment
Thanks very much guys. I'm quite happy with how she's coming about. Still a lot to do on her decks before I look at making up the masts - inlets for water, fuel, deck lights electrical outlets and ship to shore power connection. Not to mention the two dorys, which will be models in themselves!
And for those of you who only like ships with guns, I've decided to mount the two signaling swivel guns on each quarter.
Anton T
Current build
Link to comment
Started work on the anchor windlass. Main drum housing, gypsies - what the chain actually runs over, warping drums, and hand brakes for the gypsies. The only thing left really are the hand winding brakes on the ends of the warping drums- these disengage the gypsy while the warping drum still rotates.
There's a sort of 'a' frame over the front of the windlass which the sea chains are attached too as the fore bell. These aren't actually part of the windlass as such so I'll make them up separately.
Anton T
Current build
Link to comment
Anchor windlass and belfry completed.
Anton T
Current build
Link to comment
Thanks Patrick, but you can't use the windlass without the controller :)
That's the yellow thing with the cable coming out and looping around haha
This plugs into a socket on the hatchway next to the windlass, beneath the on/off switch for the windlass.
Anton T
Current build
Link to comment
Had a little fun with something different tonight. Hull draught numbers. I've used a rub on dry decal white number set for this, which requires patience but looks much better than a decal in my opinion as it's just the numbers straight on the hull.
If you're not familiar with draught numbers, the metric system which I've only encountered on the ships I've sailed on are numbered in 20cm positions. 1M or 10, followed by 2, 4, 6, 8 - 20cm,40cm etc until the next metre which would be 2M or 20. The numbers themselves in the metric system are 10cm in height as standard which works out to 1.7mm in 1/56 scale. Around the stern, as the hull slopes significantly compared to the bows, the numbers increase to a height of 18cm on the hull - this of course will be different on all ships as the angle a stern slopes will be different to the next. This is done as to look at the numbers from the waterline they are still at the correct levels. The stern numbers are also in line with the props. On naval vessels the draught numbers would change here and show the draught of the projected item from the hull (eg: props, stabilisers etc and would have 'proj' at waterline level as to not confuse anyone about the actual hull draught. A separate stern hull draught would then be shown on the centerline of the transom. Leeuwin doesn't luckily, and even though the stern draught numbers are inline with the props show the hulls actual draught as the props don't project below the keel.
Pic 1- bow draught numbers
Pic2 - stern draught numbers using larger font
Pic 3- side profile showing how the numbers are inline on the hull when looking at them from the waterline.
Anton T
Current build
Link to comment
Link to comment
Finally had some time to take a good look through your build log; and a what a pleasure to see your progress through this model - a very nice build indeed.
cheers
Pat
Link to comment
Hi Anton
Nice! It's the little details such as this (hull numbering) that makes your ship so authentic.
Certainly looks like you're not far off from the finishing line.
Cheers
Patrick
cheers
Pat
Thanks Patrick and Pat for checking in. She has come along easily and quickly though it helps knowing the ship as intimately as I do. Sometimes I find it difficult also to just study the plans without knowing certain things. This ship is quite an easy build for me in that respect. Though even once the hull and deck is complete which you're right, probably won't be long... The masts and rig are just as complicated. Luckily though, I've de-rigged this ship, removed sails, bent on sails, taken off yards, repaired turnbuckles, tarred stays and shrouds, replaced running rigging on the real thing, it should come together again quite easily, and I'm the chef! Haha
Anton T
Current build
Link to comment
... and I'm the chef! Haha
I was wondering just exactly what your role was, Anton !!
Seriously. You've a stunningly beautiful build going there.
But, y'know, I'll just have to be sure to compare your work to the real thing ... next time I'm down in Fremantle !!
(Purely so as I can inform the rest of MSW of your build accuracy, o'course)
:cheers:
Edited by CaptainSteve
CaptainSteve
                        Apostol Felipe (OcCre)
                        HMS Victory (Constructo)
Link to comment
Hi Steve, haha yeah officially I'm the chief catering and supply officer. So I look after the catering and store supplies for the ship as well as the voyage budget. So I'm the hardest worker on board! But I'm also a ticketed officer, keeps my options open plus I can stand in as bosun/second mate.
Anton T
Current build
Link to comment
My average day onboard, baking bread to running the foredeck :)
Anton T
Current build
Link to comment
That's one heck of a career, Anton.
(I envy you !!)
:dancetl6:  :dancetl6:  :dancetl6:
CaptainSteve
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
