18th Century Longboat by Nirvana - FINISHED - Model Shipways - 1:48
Mike,
Many thanks for the looping plier idea, I have looked them up and seems to be a Very good investment.
Thanks again
Respectfully
Link to comment
Share on other sites
Creating the downhaul ring for the boom was harder than I anticipated.
The first one (top) came out to large
The second one (bottom) to much CA, which is revealed in the picture but not with the naked eye...... go figure...
And the bottom one is not in the shape of a circle.
However this is the one I am going with.post-967-0-28308200-1451108748_thumb.jpg
Respectfully
Link to comment
There is a way you can make good rings with brass wire.
First take something round which is the same diameter as the ring you want to make, a screwdriver for instance. Then wrap the wire around it in a spiral keeping it as tight as possible. Once done, slide the spiral off the object you chose to wrap the wire round and cut it in the place i have highlighted in the second picture, you can cut off as many as you need all the same size and perfectly round. Note in the pictures the spiral was not tight as it was only to be used for reference purposes.
Edited by Cobr@
Link to comment
  • 7 months later...
As I stayed Sunday with intention of heading home Monday morning, this allowed me and Floyd to work on our longboats. So, yes I made the oars for both of us. A set of for each. post-967-0-47470000-1471881702_thumb.jpg
Respectfully
Link to comment
Can anyone shed some light regarding the oar locks as these are supposed to be made out of 26 gauge black wire.
The material list only shows 24 and 28 gauge. Which size has been used on others longboat?
Respectfully
Link to comment
Thank you Chuck, I appreciate your fast answer. I was suspected the 24 but wanted to be sure.
Respectfully
Link to comment
  • 2 months later...
Hurray!
Well, no saw dust but painting instead.
And I am back in the right enviroment and in front of the longboat.
I dediced to go with white blades on the oars.
The oars look so smooth prior painting but obvious not.
I think a light touch of 600 grit and another two coats and the fuzziness will be gone.
Respectfully
Link to comment
The oars are coming along. I think you are right- more fine sanding should do the trick. Glad to see you back at this build. I'm currently doing some tests before I paint the cap rail on mine. Did you do any masking inboard before you painted or freehand?
Steve
Link to comment
Thank you Steve for the nice word.
Yes, the oars turned out much better after another sanding and another two layers of white.
The inboard is all freehand painted, I found it trickier to mask than paint directly.
I looked at other long boats online of various styles and decided to go with a "three pair setup" six rowers.
Going with eight made it look cramped. I also decided to exclude the windlass and I have a surprise up in my sleeve for the long boat.
So, the oarlocks are in place and painted.
Respectfully
Link to comment
I am cursing myself, because I have lost plan one along with a box with material for the longboat.
Have no idea where it all is, so I am working from plan two and the instructions.
Respectfully
Link to comment
The rudder is now shaped and so is the tiller.
I predrilled the whole for the tiller and then used a flat pointed file to open up for the insert.
Respectfully
Link to comment
Lots of progress today.
Rudder is ready for painting,
It was tricky to get the pintles and gudgeons right, but after some work I got it right.
But getting the eyebolt done was a pain.
Respectfully
Link to comment
Even though I don't have much of pictures to present at the moment, I have been working on the longboat.
One thing that happened was the tip of the gaff got broken. It was an easy surgery.
Respectfully
Link to comment
Well, I used my five minutes this day (turned out to be fifteen but still), and made the iron rings for the top blocks.
Another step forward.
Respectfully
Link to comment
Well, it's called trial and error.
I'm currently working on set three of rings and bands.
It's the drilling that destroys some of them.
Getting there anyway.
Edited by Nirvana
Respectfully
Link to comment
The instructions tells me it is time to consider type of pedestals and base.
Considering the size of the longboat, I am making the base small, and using brass as pedestal. Pictures will follow.
Picked up the material from Hobby-Lobby.
Edited by Nirvana
Respectfully
Link to comment
Link to comment
Well,
It's amazing how small things can "disappear".
I think I have re-made the bands three times because of their capabillity of "flying".
Had another made yesterday.
Meanwhile I seized the line on the gaff.
The line will get shaped with a light touch of glue before the peak halyard is seized in place.
I am starting to enjoy the seizing even though it is very fiddly and small work to do.
I bought a poly/cotton line from a fabric store, stronger than regular cotton but still easy to work with.
Respectfully
Link to comment
Very cool. I'm interested to see how the line is that came with the kit. I cant imagine its easy to work with. Not even close to that stage yet!
Steve
Link to comment
Steve,
I bought rigging and running lines from Chuck. Such better quality.
Respectfully
Link to comment
Progressing. Working on several areas at the same time . Stayed up wayour to long last night.
Respectfully
Link to comment
Steve, the base is too small for a glass cover. This is the first part of the display. But thank you.
Wish there were bigger ones to hold the model, could had been a fun way to show her.
Respectfully
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
