Posts posted by Mark P
Congratulations on such a lovely model; well done indeed.
Thanks Allan;
This is too wide-ranging a field for us to know all of it. Belaying pins were certainly used from the Tudor times, but in combination with many other belaying points. As ships developed, and rigs became more and more complicated, the number of ropes needing to be belayed multiplied, and it is easy to imagine that racks of pins in the bulwarks rationalised the forest of ropes coming down the rigging.
In addition, pin racks on the inside of the shrouds were definitely in use by 1750.
One day I hope to produce a typical English belaying plan for the early 17th century and late Tudor period. Just have to live long enough!
All the best,
Mark P
Good Afternoon Allan;
Sorry to say this, but please check your memory, as Phil is actually correct; and this subject has been discussed at least twice before. Belaying pins were used in the early 17th century, and can be seen on early models (granted that the earliest surviving models date from the mid seventeenth century)
Henry Mainwayring, a noted seafarer of the times of Elizabeth and James I, described belaying pins in his nautical dictionary, which he wrote around 1623. I am not sure, but I believe that they are also mentioned in a treatise on rigging which R C Anderson believed dated from around 1620 (must check that)
So carry on Phil; all I would say is do not place racks of belaying pins inside the bulwarks everywhere, as this might well be not historically accurate. In this respect Allan is correct, and it is this configuration which did not appear until later in the era of sail.
All the best,
Mark P
- mtaylor, GrandpaPhil and Canute
- 3
Good Afternoon Brunnells;
I have a large selection of English boxwood (I know it is because I cut the branches from the trees myself, or got them from gardeners who had cut them down, with the leaves still on them)
This has a good range of colour, and some of it is indeed very noticeably yellow. Some is very pale yellow, more of a cream colour, and there is a whole variety of inbetween shades.
Some of it has no grain visible at all; some is prominently marked, with the end-grain looking like pine softwood; which of course it isn't, it is much too heavy, and must be the result of some growth rings being very close together, with others which are more dispersed.
The main characteristics are that it is heavy, hard, and extremely fine-grained.
Below is a picture of a model made with boxwood planking, which is very yellow; presumably sealed with something, but the colour looks lovely.
All the best,
Mark P
Thank you Morgan;
That is a really interesting picture. My immediate reaction is that it is 17th century, for two reasons:
Firstly, the underside of the floor timbers have notches in each timber for the limber passage.
Secondly, the futtocks appear to stop short of the keel, which is strongly indicative also. However, more photos would make it clearer. I will see if I can contact the chap who took the pictures.
The closeness of the timbers would also seem to indicate a warship, although I would not state that with any certainty.
I don't think it is a particularly large vessel, as the outer planking appears to be quite thin: 2-3 inches.
All the best,
Mark P
- thibaultron, Canute, druxey and 6 others
- 9
Good Evening Markus;
Your question touches on several separate topics; not being knowledgeable concerning American ships I cannot perhaps answer with full authority, but I can tell you the equivalent English practice.
Firstly, all timber used in ship-building was classified in various categories, according to its size and intended use. For planking, this comprised 'board', 'plank' & 'thick stuff'. Board was around 1" thick, and was used for bulkheads and partitions. Plank was up to 4 or 5" thick, and was used for most of the hull covering, in and out. Thick stuff was used where extra strength was needed, and was up to around 9" thick. Generally, anything over this thickness was only used (in larger ships) for the keel and related pieces, along with deck beams.
Compass timber was anything curved, the main use of which was for forming the curves of the frames.
The thicker strakes of deck planking, which are flush with the main deck coverings, but are let down into the top of the deck beams, are known as 'binding strakes', and their purpose was to stiffen the ship's structure. They were also often used to fix the ring-bolts for the train-tackles for the ordnance.
Lord's survey is obviously a very thorough one, and much attention has been paid to detail. I would be very dubious that he shows anything that was not there when he carried out his work.
In the 17th century, the central portion of the deck was normally raised above the planking outside this strip, and was delineated by timbers known as 'long carlings'. See photograph below from a model of the 'Boyne'.
This practice continued in the 18th century; see photograph of a model in the National Maritime Museum, dating from the early 1760s.
Thanks for posting an interesting drawing.
All the best,
Mark P
- rybakov, druxey, Keith Black and 6 others
- 9
As a piece of interesting trivia, the earlier name for these items was 'dead men eyes'. This was especially apt when they were triangualar rather than round, making the resemblance to a skull face more obvious.
All the best,
Mark P
- allanyed, Roger Pellett, Gregory and 2 others
- 5
Good Morning Linda;
To help you understand what is happening in the rigging diagrams you show, a simple rule can be applied:
The mast and sails on the left show the 'sheets'. All sails shown on the mast need a rope to keep their lower corners from flying up in the air, in which event the sail would hold no wind, and the ship would not move. The sheet performs this function, and is essentially the same on all the sails shown.
The right hand mast and sails show the ropes which are designed to do the exact opposite to the sheet, and to raise the lower corner of the sails to the yard when it is time to furl the sail. These are known as 'clew-lines'. To haul on the sheet opens the sail; to haul on the clew-line furls the sail. When the sheet is hauled, the clew-line must be 'paid-out', or slackened so that it runs free.
By far the best reference book I know of for ships of this era, which covers the rigging of such ships in great detail, is the 'Masting and Rigging of Clipper Ships and Ocean Carriers', by Harold A Underhill; first published in 1946. He was a very skilled modeller and draughtsman, and knew many of these ships personally. He also wrote several other books dealing with simiilar vessels, and produced a wide range of plans for such ships, which have very good masting and rigging details on them.
If you are building your model without sails, then the ends of the clew-line and the sheet would be shackled or tied together, so as to be ready in position when time came to fit the sail back to the yard.
(edit) I have just checked and the book is available online from £16, with many copies listed by different sellers, with different qualities and prices.
Wishing you all success with your modellling!
Mark P
To be fair to Mike he does say he is not sure if those two are in the Rogers Collection or not.
Vol III covers fourth to sixth rates. Presumably the brig is unrated, and so is too small to fall into this category; and must wait for the next volume, along with any single masted vessels. However, as a frigate one would expect that the Shannon would be in vol III if it was part of the Collection; something I know not. Unless it is intended to produce a separate volume of American vessels?
All the best,
Mark P
Good Evening Mike;
Thank you for posting your reply. If it is the spam filters, yes please, sort them out, as customer communications are a vital interface for us all.
However, regrettably, this still does not answer my original query:
Will it be possible to order a copy of the Rogers Collection Vol III? Which is marked up on the website as sold out. Is this an error? Or if it is correct (in which event I am very surprised not to have received any notification of the book being available for pre-order) will you be increasing the print run? I would really like to order a copy of this book, as well as the Fubbs volume, and my query being continually left unanswered is rather frustrating.
All the best,
Mark P
Thanks Mike;
I did indeed read along with the topic you link to, whenever there was a new contribution. It seemed best to post this under a new topic, though.
I would expect that if there is any problem, that someone somewhere, closer to SeaWatch than most of us are, would know of it and post an update to keep potential clients informed, as was the case with both Jim Byrnes' business, and SeaWatch itself under the previous owners.
There are two books listed as forthcoming, one of which has already sold out, seemingly. So it seems that things are ticking over as usual. Maybe there are difficulties behind the scenes; but my main gripe is that a business which does not respond to two separate emails for a period of over a month in total, needs to do a lot better; that is unarguable; and the doing better category would include letting people know if there is a reason for such delays.
All the best,
Mark P
- Roger Pellett, Canute, mtaylor and 1 other
- 4
I don't know what's happening over at Seawatch Books, but I have twice sent them a message via their contact us page, and on neither occasion have they deigned to answer my query.
I looked through their catalogue in December, and saw that vol III of the Rogers Collection was now available, but that it had sold out.
I therefore sent a message asking if they had any plans to increase the print run to allow for later orders, and to have a number in stock. I don't know who's monitoring their incoming messages, but they need a large rocket up their backsides, especially if other's messages are eliciting no more response than mine have.
On top of being rather upset that I had received no notification of this latest volume being available, despite being on their mailing list, to then have my valid queries completely ignored is adding insult to injury.
Just to assist, I will advise you of the three possible answers, none of which take long to write:
1) Yes
2) No
3) We are considering this
WHERE ARE YOU!!!????
Mark P
Good Morning All;
The main point when discussing any possible set of plans for a model of a ship from this period is that there is no 'true' draught, or picture, of any vessel which can be used as a reliable basis for a reconstruction. Any draughts wich exist are modern, or relatively modern. If we are lucky we know the length of the keel, the greatest breadth, and the depth in hold. Using these, and following known conventions and methods of the times, it is possible to make a reasonable reconstruction. Lengths of masts and yards are available to anyone who knows where to look, and it is even possible to know something of the decorative works applied to some ships. However, these measurements are only recorded for warships, and there is often some variation between various sources.
But overall, the information is far less than that which is required to be certain that any draught drawn is a true representation. Accept this, draw a draught if you can, or use the one available in Peter Kirsch's excellent book, which is probably as near to the truth as it is possible to get, and make the best quality of model which one can. Or use a draught from a reputable kit/plan supplier which is at least based on some level of research (if it is possible to find this out; other members here may know more in this respect)
Opinions of the finished result's verisimilitude may vary, but if you have done the best possible, using the avaiable resources, no-one can say that it is not a true likeness, as there is no comparator to set it against. Contemporary engravings look like caricatures, or cartoons. Certainty is unachievable.
Enjoy the research, enjoy the build process, and admire the finished model, with the words we all know in your head: 'I wish I had done that/those bits a little better', and use the lessons learned in your next model.
All the best,
Mark P
Good Morning Michael;
By a Navy Board order of 6th May 1777, ships' sides were to be 'paid' with Stockholm Tar mixed with yellow or red ochre; except flagships which could be painted with bright colours at the Commander's request. This was due to the difficulty in obtaining sufficient quantity, and high price, of supplies of Rozin and Turpentine.
The same order directs that the bottoms of ships are to be paid with Pitch & Tar mixed with Brimstone, which makes the common brown stuff, to within nine feet of the load draught of water, and the remainder with Tallow and Lime, with a shallow skirting with Tallow and White Lead [this presumably meant that the 'brown stuff' was normally invisible below the water]
The same order directs that masts removed from ships under repair, or those ready to be placed in new-built ships, all of them whilst in storage in the mast house, are to be treated with Tallow. Whereas for ships going to sea, the lower masts are to be painted [unfortunately no colour is stipulated here]
These orders probably remained in place until Nelson's time, when his preferred mode of yellow with black stripes and chequered gun-ports became copied through squadrons, and then fleets (although recent analysis of paint remnants on the Victory has led to claims of her being some shade of red/pink I believe)
All the best,
Mark P
Good Morning Dave;
Contracts from the period stipulate the following for the cook room:
I have added the words in square brackets for clarity.
'To lead [meaning the metal sheet material] and lay cants for the fireplace, to line the underside of the deck & forecastle beams [meaning the ceiling overhead] with lead & double tin plates all round within the compass of the heat of the fire, to cover the upper deck [within the area outlined by the cants] with lead 7lb to the foot square & to put up such convenient dressers and lockers as shall be necessary.
Cants are timbers laid flat on the deck to create a kerb, or upstand, around the area of the cook room.
All the best,
- mtaylor, druxey and Thukydides
- 3
Good Morning Allan;
The essential difference between 'white stuff' & 'black' was the cost. The ingredients of the black variant were cheaper, and its use was apparently widespread. However, the white was considered more efficacious, and was used for ships designated to serve in warmer, tropical seas, where the risk of worm attack was higher, and presumably fouling was worse due to longer time out of the dockyard before the ship could be graved again.
However, as a black-coloured hull is not as attractive to look at as a white one, artists and modelmakers invariably use white to colour this part of the ships they depict. Artistic licence is the deciding factor in what we see, not a strict adherence to reality; understandably so, I would say.
All the best,
Mark P
- druxey, Ryland Craze, allanyed and 8 others
- 11
And everybody here will appreciate your doing so, I assure you. Theft of another's work undermines the whole ethos behind developing a kit in the first place.
All the best,
Mark P
- Keith Black, mtaylor and allanyed
- 3
Good Morning Allan;
This is an excellent book. It is based on the author's reconstruction of a galleon using the 'Salisbury Treatise', which is an early 17th century work on designing ships. This is a detailed treatise, and is in some places hard to understand (it does not help that some of the sentences here and there were lost in copying) I believe that there are one or two errors in Mr Kirsch's reconstruction (I cannot remember who told me this, it was some time back) but overall it is certainly a good buy.
He uses a surviving votive model from Denmark, I believe it was, as a general guide to what he is trying to achieve. However, the treatise is written in English, presumably by an Englishman (the original has not survived, which was certainly larger than what we now have, with tables, now lost, included) and to the best of my memory, it can only be assumed to refer to English practice.
All the best,
Mark P
Good Evening Allan;
This kind of detail is quite common on draughts of the later 18th century, certainly. I have always been of the opinion that such things represent the joining of beams by scarphs, seen from the end, and cannot conceive of it representing anything else. The location and spacing make it certain.
The use of scarphs was not so much dependent upon the whim of the shipwright in charge, but rather was driven by the timber available. As good timber became harder and harder to obtain, it became necessary to use ever shorter pieces. I have read of deck beams being formed of two, three, or even four separate sections, all scarphed together.
The scantlings of timbers used in early 17th century ships, which were much smaller than those of the later 18th century, are much larger in size than the corresponding timbers ever were in the later period. This presumably reflects the need to make the most of the timber available.
Deck planks were both spiked (nailed) and treenayled at various times. Generally the butt end of a plank would be fixed with a bolt for extra security, or if a wider plank, with a bolt and a treenail, if my memory serves me correctly.
All the best,
Mark P
- Thukydides, allanyed, druxey and 1 other
- 4
Good Morning Everyone;
Some interesting thoughts are being added to this debate. However, although some are correct, and some somewhat less so, nobody has yet stated the truth regarding the reasons for adding wales to a ship. They were structural members, yes, and important ones; and they evolved over time from a number of single, relatively parallel strakes of timber into broader bands made up of several strakes together.
However, the main intention and function of wales was to counteract 'hogging', also called 'reaching'. This was the perennial problem of timber construction, wherein as a wave passes under a ship from end to end, the stern and bow in succession are left unsupported, and tend to droop. Over time, this led to the butt joints of the planking opening up, and to the keel becoming curved downward at each end. Warships were especially prone to this, due to the weight of the ordnance carried at bow and stern.
The wales were separate strakes of heavier timbers, inserted in the planking, running parallel to the external planks. Although not always specified, they were often bolted to the timbers, not treenailed, for additional strength (remember that iron bolts were expensive, and were not used lightly)
In order to achieve the maximum benefit of this method of strengthening, the curvature of the wales was exaggerated relative to the sheer of the deck, so that the ends of the wales were higher relative to the line of the deck, than was the case amidships.
The main wales were always sited so that they gave strength to the main deck, being in line with it at the midships, and above it at the bow and stern.
As Druxey states above the decks were, in earlier times, stepped downwards at the end, in order to avoid the need to cut gunports through the wales, thereby weakening them. However, it was realised that this significantly weakened the resistance of the deck planking to hogging, and it was already recommended in England that steps should be avoided, by 1612.
The internal planking, though, did follow the sheer of the decks.
The essential principle of internal planking was that at every location where there was a line of overlap in the ship's timbers, between floor timbers and futtocks, for example, and different ranks of futtocks, this overlap was strengthened with a much thicker band of planking, in many locations, and with quite a variety of names: for example, what in later times was known as 'spirketting', that is the run of thick timbers between the waterways and the gunport cills, was originally known as the 'spirkett wale'. This is because the spaces between the ends of the timbers were known as 'spirketts'.
Others were 'sleepers'; 'middle bands'; and 'footwaling'. In later times these became known under the more generic term of 'thick stuff over the futtock heads'.
In order for the wales of the model which started all this to look realistic, it is necessary that they must follow the sheer of the planking.
All the best,
Mark P
Was the working shipyard dock's bottom flat or sloped? (18th century)
in Nautical/Naval History
Posted · Edited by Mark P
Good Evening Masa;
In the Eighteenth century most ships of any size were built or repaired in a dry dock. An existing ship would be floated in on a high tide, and as the water receded, the hull would be propped up with a large number of shores, whilst her keel would settle on a line of timber blocks. The base of the dock sloped towards the river, both to allow the water to drain away thoroughly, and to facilitate launching on a slipway. Once the dock was empty, a pair of gates would be shut across the entrance to keep the water out. In earlier periods, the dock would be closed with a bank of clay and stones.
The floor of the dock was made of stout timbers, called the 'ways' which were set in like railway sleepers. The blocks to support the keel, and the shores, would be nailed to these ways to prevent them moving.
A new built ship could be launched by opening the gates and allowing the dock to fill with water; this was best done with extra high tides. On the other hand, if there was no high tide soon, the ship could be launched down the ways; this was done by setting down timbers like a railway track, called a slipway, running into the water. The ship was fitted with launching cradles at the bow and stern, which sat on the slipway, and the blocks under the keel were knocked away. The ways were well-greased. Sometimes the ship would slide down the ways easily, other times she needed a good pull to get her moving.
The book 'Building the Wooden Fighting Ship', by James Dodds and James Moore, describes the build process in detail, with a large number of hand-drawn, good quality illustrations, and also covers the launch. There are several models of ship on the ways ready to launch, including the well-known model of the Bellona, and the Victory of 1765.
All the best,
Mark P
