Mark P
Everything posted by Mark P
  1. Hi Andrew; Thank you for the additional information. I hope that your spans are done in a short time-span! In the 19th century there are quite a few manuals designed to teach junior officers about the ships on which they found themselves. They are interesting to read, and the differences as things change over time are quite noticeable. I don't know how many are available as online copies, so any mention of something you find is probably helpful. All the best, Mark
  2. Hi Andrew; The illegible word is 'span', which was a length of rope with a block or thimble spliced into each end. It was normally fitted by simply wrapping it vertically around the cap (over the top and bottom) and, in the Royal Navy, was used for the yard lifts. However, in your case, the span seems to be fitted to bolts or shackles in the sides of the caps. The cap seems to be very weak all round, not made of much material. If it was wooden, I would expect to see the rectangular hole much smaller, as the top of the mast was normally cut with a tenon, to reduce the amount of material removed from the cap, rather than putting the whole thickness of the mast through the cap. Is the cap bound with iron? In which case maybe the span was fixed to lugs; but then of course you wouldn't need the span, as the lugs could be placed where required. Perhaps a fellow modeller who knows more about US Revenue cutters can tell us more of this. Thank you for a thought provoking post. All the best, Mark P
  3. Greetings Druxey; Thank you for the additional tip. I will keep this in mind. All the best, Mark P
  4. Hi Bob; Thank you for the long and informative post. I wasn't aware that proportional dividers could be had with such a fine adjustment. I'll keep an eye out for a set. It is also kind of you to let us know what to avoid. All the best, Mark P
  5. Hi Jingyang; The gammoning slot looks fine to me. I would round off the upper edge a bit, though, where the rope will otherwise lie against a sharp corner; and the same for the hole for the mainstay collar. I wish you all the best progress in your project. If you ever need a second opinion on any part, please feel free to ask. I cannot say that I will know the answer, of course! One other source of information, which you may have already tried, is Navy Board contracts. When pressures of wartime needed a large number of vessels to be built, some of them were built at the yards of merchant ship builders. Normally there would be a contract drawn up, very detailed, specifying the scantlings of nearly all the timbers, and the number and size of bolts, to ensure that the builder would adhere to Navy standards of construction. With best wishes, Mark P
  6. Hi Jingyang; Research in contemporary sources is certainly the best way to find results, and is wonderfully interesting at the same time. Your draughting shows that you already have a deep understanding of Pandora's construction, and if you have read such good authors' works then you have a good breadth of knowledge also, and I can add little. From what I have seen, the construction of the knee of the head was largely the same for all vessels, it just varied in scale and the number of chocks used. All the best, Mark P
  7. Greetings Gentlemen; Druxey: thank you for the thought; but don't worry, I went off the idea of an all single framing pattern quite a while ago. All my more recent work has been on the basis of an all double construction. Jaager: thank you for listing the various room and space and timber combinations. 10 x 10 is obviously the size of choice for most shipwrights working on these. All the best, Mark P
  8. Hi Jingyang; Thank you for your reply. The level of your draughting skill continues to amaze me. I am competent with 2D CAD, but I could never achieve what you make look so straightforward. To answer your queries: The taper of the standard as compared to the knee of the head below it is now shown correctly above. However, the shape of the standard needs to be revised. It actually curves upward at its forward end, and is scarphed into a thin, curving extension piece, which extends up behind the figurehead. The upper edges of both the standard and the extension are given a small chamfer. The rounding over I was referring to is to the timber right at the front of the knee of the head, below the figurehead. This should be virtually semi-circular. The cambered cladding piece which you show attached to the forward edge would not have been made so. Such thin wear pieces are attached lower down, where the leading edge is a hollow curve. One last point is that the gammoning slot is cut in the head of the gammoning piece, which extends well down, and is the principal timber of the knee of the head. There would not be a horizontal joint below the gammoning slot, curving up as it goes forward. If you can, take a look at one of the excellent practicums by Ed Tosti or David Antscherl; or study a build log here looking for a part of the framing plan showing the knee of the head. They know far more about this than I do, and have illustrated it very well. Again, if you are already aware of this, and it is just because I am looking at a work still in progress, please accept my apologies. All the best, Mark P
  9. Thank you Druxey, that is a good comment! Rob, thank you also. Do you have any other instances of this number of filling frames, this would be interesting to know more about. For Royal Caroline I don't think this would have been the case, though, as the filling frames, whilst similar in midships to the main bends, and so perhaps not requiring to be numbered, would certainly be different at the bow and stern. This would seem to indicate that they would have to be individually numbered, and the numbering system on the draught only allows two stations between each main station. Also, I have the scantlings of her timbers (10 1/2" & 9 1/2") and her room and space (5' 5 1/4") and at six times filler frames and a floor and futtock from the main frames, this will not fit into the available space. It does fit with four filler frames, but only with a very small gap between them (1", just over) So four is a possibility, but I think the numbering system works against this, as set out above. Nonetheless, thank you for your suggestion, and I would certainly like to know of more examples of this number of filling frames. Everything I have seen previously has had a maximum of three filling frames (I have no knowledge of merchant practices, though, where it may have been more common) All the best, Mark P
  10. Greetings Gentlemen; Thank you Jaager for searching so many plans to try and find out more. If the long/short alternating arm does not seem to exist, then I will return to my earlier hypothesis, that all the frames are double. Thank you Druxey for your thoughts; I checked out framing plans for some sloops and a brig, and these mostly showed the double frame with two filling frames. However, as you say, Royal Caroline was a non-fighting vessel, and may well have been framed differently. As a Royal yacht, she was certainly a special case, and would undoubtedly have been of a high specification. All double frames is presumably a much stronger construction than one with filler frames (if similar spaces between them are maintained) I think that I will accept this as the method used (which would be just as well, because I have drawn most of the disposition of frame plan already, with double frames throughout) Thank you again for sharing your thoughts. All the best, Mark P
  11. Hi Jaager; Thanks for your reply. I have the Bellabarba/Osculati book, it was this which inspired me to build the model. But from a very early point in my own research I have discovered that the book is absolutely riddled with errors, some of them very basic, and cannot be used as a basis for any historically accurate model of the yacht. I think I have not made the frame disposition clear: there are normally 2 filling frames for every double (known as a bend) If this is assumed for Royal Caroline, then every pair of filling frames has a floor timber in both frames. I cannot see how this would be done, except if the floors are made with long and short arms, alternating to Port & Starboard. It is this method of construction, if it does exist, which I am trying to find out more about. From what you say, this may be shown in Marquardt's Beagle book, but unfortunately I don't have a copy of this. I will keep an eye out for a copy if it is not too expensive. Does he show floors projecting alternately to Port and Starboard, or are they both centred on the keel, but made at different lengths. Can anyone post a picture from this if it might help answer my query, please? All the best, Mark P
  12. Hi Maurys; Interesting query you have posted. With regard to the rigging of the shrouds, I cannot add anything, except to speculate as follows: The hoy was presumably only used in sheltered anchorages, to lay out permanent mooring bouys for ships in ordinary, or something similar. This might mean that a limited swing of the boom was acceptable, as speed was presumably not critical to her performing her duties, as long as she could move fast enough to give effective steering. This would limit her points of sailing, though. This idea is purely based on my limited understanding of an anchor hoy's duties, and may well be so far wrong that it is off the scale of probabilities. However, as it might be relevant, here it is! All the best, Mark P
  13. Greetings everyone; Here's one for the technical experts amongst us. I am constructing a framing plan of the yacht 'Royal Caroline' of 1749. The original draught has station lines drawn at every third frame: 3,6,9,12 etc. The double frames (bends) will be on these lines. Between these would normally be the filling frames, one with a floor, and one with first futtocks. However, I have a letter relating to her construction, written by the master shipwright, which says that they are having difficulty obtaining suitable timber for the floors at stations 8, 10, 11, 13 & 14. These are all filling frame stations, yet they are adjacent, with the exception of 8. It would seem impossible that there would be floors at both stations under a standard arrangement. My interpretation of this so far has been that it means all frames are double, but I have never been truly comfortable with this hypothesis. My doubts have now increased, as I seem to remember a framing pattern in which the floor timbers were made with one arm long, and one arm short. These were fixed to alternate from side to side with each other. This would then also provide floor timbers at each filling frame station. I have been unable to find any proper description or illustration of this method. Goodwin mentions it, and says that it is shown in one of his illustrations, but I cannot interpret his drawing in this way (it just shows a standard arrangement of symmetrical floors and first futtocks) Can anyone out there point me to a clear description of how this might have been done, or better yet, a decent illustration, applicable to this period. Many thanks! All the best, Mark P
  14. Hi Brett; That probably depends upon the era of the ship in question. If you are making a 19th century ocean-going grain carrier or similar, they would have been very much the same. Although the after-most mast (the jigger, I think it is called) was normally rigged the same as the mizen mast on a three-masted vessel, with the other three square rigged (there were, of course, many alternative rigs, but I am thinking of ships which were mostly square riggers) In the late Medieval and Tudor period, the aftermost mast, called the Bonaventure mizen, was rigged with a lateen sail, similar to the mizen mast, but normally smaller. These two aftermost masts were different to the forward two, which were square-rigged. All the best, Mark P
  15. Hi Brett; Take a look at some of the build logs on this site. Ed Tosti, in the scratch-build forum has some really good tips about transferring measurements from draught to model. All the best, Mark
  16. Greetings gentlemen: Patrick O'Brian was certainly not nearly the first author in this genre, whatever he may rank by quantity. Leaving aside the Marryatt mentioned above (who also write 'The Children of the New Forest', once a children's classic) C. S. Forester, who died in 1966, wrote the Hornblower series between 1937 & 1962. It was only after Forester's death in 1966 that an American publisher suggested to O'Brian that he should try writing historic fiction set in the sailing navy era; which was obviously a great success. All the best, Mark P
  17. Hi Pat; I would be very dubious that shrouds were ever led through a fairlead. The stress on the fairlead would be quite high. I have never seen a shroud led in any other way than straight to a dead-eye, without anything inbetween. My interpretation is that the diagram above shows a plan of the shrouds (4 of them) and two topmast backstays, with a pin rail inside the bulwarks, or possibly on the shrouds themselves. There are then also fairleads on the first two or three shrouds through which ropes 100-102 are reeved. All the best. Mark P
  18. Hi Herask; thank you for posting this. It is another example of something I will never be able to do! I am okay with 2D CAD, but all this 3D stuff is beyond my experience. You seem to have made a good start. I will watch with interest. All the best, Mark P
  19. Hi gentlemen; A bit off topic, so I'll keep it brief: I wonder if the name Crothers is derived from the English name Carruthers, which sounds very similar (I have a bit of an interest in English names for people and places) All the best, Mark P
  20. Hi ronkamin; Every illustration I have ever seen of ships with studding sails (normally abbreviated to stun's'ls or similar) shows them rigged out on both sides. However, one slight point to watch if anyone is showing them set: the sails overlap in sequence. In other words, port and starboard stun's'ls are not both set abaft, nor afore the square sail they join. If the port one is abaft the sail, the starboard one will be afore it, and vice versa. The one the most to windward was set behind. This was done to ensure that the wind did not pass through the overlap of the sails, but had to pass behind all three. When the ship changed tack, the stun's'ls were shifted to the other side of the square sail. Must have been a lot of work to shift them all on a large vessel. All the best, Mark P
  21. Hi Vossiewulf; In the decades just before the French Revolution in 1789, Royal Navy contracts with merchant builders (ie not Royal Dockyards) specified a minimum plank length of 24 - 25 feet for hull planking on large vessels, sometimes stating that no plank should be wider than 12". I am not sure how much this latter point would be applied to un-rated vessels such as cutters, though. One reason for a maximum width could be that if they were wider, they would not fit well around the curves of the frames, unless the inside face was hollowed. Which would be a lot of extra work. Another could be that unless very well-seasoned, all planks shrink across their width; and the wider the plank, the greater the distance it will reduce itself by as it dries out. Under the demands of war-time needs, with greatly increased workloads, the proper seasoning of timber probably became less important than getting the ship off the ways and into the water as quickly as possible. A similar thing happened with the 30 ships programme in the late 17th century: many of these rotted rapidly at their moorings, needing major re-builds within a year or two of launching. This was widely attributed to the use of un-seasoned timber, made necessary by the sudden increase in demand for seasoned wood, which rapidly exhausted available stocks (although it was also found to be due to those supposedly taking care of the vessels not actually living aboard, with the result that the gun-ports were not opened as they should have been, to allow air to circulate) I would not use planks any larger than the 12" width given above for the bottom planking, or shorter than the length given. However, on the upperworks some planks were wider: the sheer strake, for example, being specified as 15" wide, or 'as wide as may be got'; so around 15" was probably the maximum available most of the time. All the best, Mark P
  22. Hi ppddry; Absolutely wonderful draughting work. The level of detail incorporated is something that would reward many hours of studying your drawings, and there would still be more to find. One very small point, given by someone who knows he can never equal what you have done here, but I hope you would like to know it, is that the knee of the head tapered forwards, and was much narrower below the figurehead than where it was bolted to the stem, which you show correctly. However, the standard in the head, at the top of the knee, was narrower, and almost parallel sided, and did not follow the taper of the timbers below it, leaving a ledge where the standard sat on the knee. The leading edge in the upper part of the knee was also rounded over, quite noticeably at the top, diminishing to nothing as it went down. If this has been left as a chamfer deliberately, apologies for raising it before you have finished. All the best, Mark P
  23. Hi Timboat; Have you got the AOTS volume on Blandford. It has loads of information you may need, but unfortunately there is nothing there that deals with sweep stowage, not that I can see. However, I might have missed something lurking deep within the text. All the best, Mark P
  24. Hi Tom; Just one note of caution. The 1745 establishment might be a better guide to Liverpool, as this listed mast and yard lengths and diameters for various sizes of vessel. Steel is about 40 years later than Liverpool (unless you are modelling her after a refit) and there were quite a few rigging changes in those decades (the widespread use of royal sails, for example) This establishment only lists a 24 gun vessel, not a 28, but Lees will give the formula which applied during this period for calculating main mast length, and which can be used to work it out for Liverpool. You could then check this against the establishment, and work out the proportion for the difference, if there is one. The result could also be compared against those listed in Steel. They may well end up being similar, but they may not. I would check, if only for peace of mind. All the best, Mark P
  25. Hi Doc; From what I have seen whilst researching among the NMM draughts of masts and spars, pole masts were used as much as possible until around 1780. After this date, New England (American) timber was no longer available, due to the loss of the American Colonies, and built masts were required to make up the shortfall. For small vessels, pole mast timbers could still be imported from the Baltic, but it would appear that these were not available in such long lengths as the New England timbers, and far more Naval vessels therefore needed built masts than had been the case previously. I cannot quote any record that states this, but there are quite a number of mast drawings from the late 1770s, which show masts for all sizes of ship, and how many blanks were required to be joined to make the built mast. Based on the sudden appearance of a complete range of drawings, it would seem reasonable to assume that prior to this, built masts were much less required due to larger timber being available. Wooldings were used on larger pole masts to strengthen them against splitting, but bands were only used on built masts. All the best, Mark P
