usedtosail
Everything posted by usedtosail
  1. Sorry for the delay in updates. I was working on getting the sails installed and rigged but then had to take break when the weather got really hot here for a few days, then my son got married weekend before last and we had guests staying with us last week. Now I am back at it with the lower sails and fore topsail all rigged and the main topsail in progress.
  2. So one more change on those anchors. Instead of the line you see tied to them, which came with the kit and is a bit too loosely wound for me, I made my own anchor line. As per Chuck Passaro's excellent instructions, I put 4 strands of MARA 30 thread on all four hooks of the rope machine and wound it for a very short time, as the machine couldn't continue to wind it anymore because of the tension. The resulting rope was .076" diameter which was perfect for the anchor lines. I was skeptical that this technique would work but I was pleasantly surprised when it did. As for the ship I have been busy rigging the various running rigging lines on the sprit sail and fore sail, including the sheets, tacks, clew lines, and lifts. I have also added the bowlines to the fore sail, which I have never rigged before. All of the lines are not fixed to the cleats or belaying pins yet so I can continue to adjust them as needed. I also have not trimmed the excess on most of these lines yet either.
  3. Your Beagle looks great and the figures really add to that look. I too have reactions to CA but more allergy than cold symptoms. Claritin-D clears it up though.
  4. Oops. I was wondering why something didn't look quite right. I was able to fix that without too much trouble. Thanks.
  5. In between sail production I decided to take a look at the supplied anchors. They are in two pieces, both black plastic. The anchor shaft pieces weren't too bad, just some depressions that I filled with putty, then painted the whole thing with flat black paint, as the plastic was very shiny. The stock pieces were terrible however, so I made new ones from 3/32" square basswood which I cut and sanded to shape. I had to file a square hole through them but that was not too hard with some small square files. I stained the new stock pieces then used some black shrink wrap tubing that I sliced into thin rings for the iron bands. I made rings from wire and wrapped them in rope, using lacquer to hold the rop in place. Here is how they came out.
  6. Here is the back of the fore sail with the reef points removed and the blocks, halyard and tie line added to the yard. I put the straight pin through the tie line to hold the parrels on the line while I add the yard to the mast. Here are the fore sail and sprit sails on the model but without any other running rigging yet. I rigged the fore yard tie around the mast and added the second seizing to hold it in place with the parrels. I started rigging the fore yard halyard by threading it through a hole in the mast and seizing a large double block to the end. I also seized the tackle line to one of the sheaves in the fore bitt and will put these together after the seizing lines are fixed. The other sails are in various stages of production so this series of steps will be repeated for them as they are ready. The main sail is next and I have already started adding the blocks to the main yard.
  7. You guys convinced me to not show them on the sails. I was able to remove a few easily this morning so I'll take the rest off. Thanks for the info.
  8. Kirill, they are shown on the plans that came with the kit. They are also mentioned in a book I am using called Rigging in the Age of the Sprit Sail 1600-1720. I like the look so I am going to keep them. Here is the fore sail tied to the fore yard, as promised to show the chain stitch I am using.
  9. Good news on the tool front - I received a replacement cuticle cutter in record time so I was back in business quickly. I also ordered a second one as a back up. I finished up the lower shrouds and ratlines, then added the topmast shrouds and stays. It was a bit tricky threading the lanyards through the deadeyes in the crows nests. I am now finished with the standing rigging. As you can see I have started making the yards and sails, starting with the sprit yard and sail under the bow sprit. I am using the sails supplied in the kit, which are a bit heavy material so not to scale at all, but that is OK for this model, as there are lots of simplifications elsewhere too. I start by gluing a bolt rope around the edge of the sail before cutting the sail from the material. I make a loop in one corner with a seizing and fix that seizing, then add loops for the other corners but do not fix those seizings yet. I start gluing the bolt rope with acrylic matte medium starting at the fixed corner, and adjust the other loops and seizings as I get to those corners, using the matte medium to fix those seizings. Once the bolt rope is attached I cut along the outside of it with a sharp X-Acto blade. Here is the main sail with the bolt rope glued on. The main, fore and mizzen sails have reef points, so for those I use a needle to pull a piece of thread through the sail and tie and overhand knot on the back side of the sail. I then use some matte medium on both sides to "fix" the tops of the reef points so they hang down the sail. To trim them I place a metal ruler over them at the right length, then pull them up with tweezers and cut them off at the ruler with the cuticle cutter. Here is the fore sail with the reef points trimmed on one side. The next step will be to tie this sail to the fore yard. i first punch a series of holes inside the bolt rope along the head of the sail, then use a beading needle which does not have an eye to thread line around the yard through those holes, using a chain stitch. After the sail is attached to the yard, I'll add the various blocks to the yard for the running rigging. Here are all the stropped blocks needed for the yards.
  10. Well it did cut very well on the first try and very flush but somehow I managed to break off one of the jaws. I guess I pressed too hard. I will be returning this set to Amazon and will order a different brand.
  11. Thank you Kirill. As for the shroud loops, they are placed as first the two starboard shrouds have a loop at the top that is looped around the mast head, then the first two port shrouds, etc. The fore mast only has five shrouds so the last shroud on each side is connected to each other with a cut splice that is looped around the mast head. I do believe this is the correct way to do odd number shrouds. I think what you are seeing is that I put the first shroud pair through a different hole in the crows nest than the other pairs, so they are shifted forward. I wasn't sure i could get all the shrouds through one hole. Here is my new favorite rigging tool, a cuticle cutter. I used it to cut the ends of the ratlines and it did a great job, making nice flush cuts.
  12. Here are the starboard ratlines after tying and fixing the knots. I ordered some cuticle cutters which I will use to clip the excess line when they arrive. Port ratlines are coming along and I have started making the futtock shrouds.
  13. Thanks for the likes. I have been making good progress on the standing rigging. I have all the shrouds and stays installed, as well as the crows feet, and have started adding the ratlines. Here is what she looked like as of this morning. I am happy with how even the deadeyes came out. Here is how I do ratlines. I make a template for each set of shrouds with the shroud lines and ratlines on a piece of manila folder material. I set the template behind the shrouds and sitting on the channel. I first tie all the ratlines for that set but leave the knots a bit loose. I then tighten every fifth ratline moving from the bottom to the top and fix those knots in place. I try really hard to not pull the shrouds when I do that but I am not always totally successful. I then do the same for the rest of the ratlines. I usually use a "luggage tag hitch" for the end knots but I find some come loose as I do other parts of the build, so I am experimenting on this build by using two overhand knots for the end knots. I think for my next build I will try Ed Tochi's method of making loops at each end and lashing them to the shrouds. In this picture all the knots are still loose.
  14. Outstanding job as usual Dan. How you dealt with that decaying rigging is just amazing.
  15. I checked the chains and they pretty well follow the shrouds. The aft ones could be more angled I suppose. I added the fore crows feet today and this is the first time I have put crows feet on a model. It was tricky getting the tensions right and they are probably a little loose but if I tighten them more it pulls the stay out of line so I am going to go with this. The line behind them is just the excess that I haven't trimmed off yet.
  16. Thank you Kirill for your nice comments. I have used templates in the past for setting deadeyes but was not always happy with the results. The deadeyes in the photo above are just held with a single sliding seizing. I can then adjust the heights of the deadeyes later and fix the seizings in place when I am happy with the heights. I have used this method since I built the Constitution and I like it much better as I can adjust everything on the model. As for the chains I will have to check them as they do look of in the picture. Here I have added the real fore stay and fixed the deadeyes with a second seizing on the fore shrouds.
  17. Thanks for the likes guys. I placed the lower masts with the mast coats and added the shrouds to the fore mast. I first seized deadeyes into the shrouds and set the initial heights but did not fix the seizings yet. I will add the lanyards then recheck the heights and fix the seizings then. I added a temporary fore stay to hold the mast at the correct angle, which for this ship is actually tilted forward. The quad hands are new for me and I really like them for holding lines that are on the ship for seizing. They are a lot easier to use than the usual helping hands with the two alligator clips.
  18. Thank you Patrick and Popeye. I have been working on making rope for the rigging and also stropping blocks for the masts. I added the deadeyes for the topmast shrouds to the main crows nest. To strop them I used rope instead of wire, mainly because the holes in the crows nest were pretty small. I first seized a loop into a short length of line then dipped both ends into thin CA to stiffen them. I passed the ends through the holes one at a time and then tied an overhand knot using both ends. I put a deadeye in the loop and pulled the ends tight, then fixed the knot and trimmed the ends. Overall it worked very well. I'll either use small hooks or tie the futtock shrouds to these loops. I also made euphroes and threaded the crows feet through the holes in the crows nest but that won't be finished until the main stay is added.
  19. Here is some of the progress from today. Dingy is now tied down to the deck with the oars. And I added the gammonings to the bow sprit with polyester rope that I made yesterday. I also made the knight heads for the fore deck and the euphroes for the crows feet, as well as a bunch more rope for the standing rigging.
  20. The dingy is finally compete. I finished painting the hull today, so now I just need to lash it to the deck. I have also finished the oars for the dingy and the topmasts and flags poles. Here is the bow sprit with the collars for the main, fore, and fore topmast stays. Next will be adding the gammoning lines to hold it down. Since I took this picture I have actually replaced these collars with new ones made with new polyester rope (see below). I had made all the rope I need for the standing rigging, which was mostly made from nylon thread, but I recently bought some polyester thread that Chuck Passano suggested to use and I made some rope with it today. It came out so much better than the nylon rope that I decided to use it for all the rigging on this model. I have started making the rope I need for the standing rigging and will soon start on the running rigging. It's mud season up here in New Hampshire so I have lots of time on the shop these days, so I have been able to make a lot of progress.
  21. Thanks Popeye. I almost made it to the vaccination before I got sick. Since then I have gotten both shots so I have a lot of immunity now. How about you, did you get the Fauci Ouchi yet? Thanks for the kind words on the crows nests. They are far from perfect but I am OK with that. Yes, the vacuum formed ships boat hull was supplied in the kit. Based on the scale it just looked too small to me, as did my first attempt on the dingy. The Cutter kit from Vanguard was fun to build, even though I did not use any of the interior parts because they were the wrong scale, but the hull seemed just right for a dingy at this scale. Here is what I have been working on. The dingy interior is just about done, with the floorboards and seat support installed and the interior stained. The seats are cut and are drying after staining in the alligator clips, along with the cradles that came in the mini kit. I also made oar locks from brass rod that I soldered and blackened. Here I have touched up the solder with some black paint. I made oars which will be painted white on the shafts but the blades are stained. Finally I have been cleaning up all the blocks supplied in the kit, first with a file to round them, then a block tumbler to soften all the edges. Here I have stained them all. I have also gone through the plans and developed a rigging plan, which is basically a list of all the standing rigging and running rigging lines in the order to add them, along with the line and block sizes needed. I find this makes it a lot easier to keep track of the rigging as it progresses.
  22. She looks great. Nice job and have fun with the rigging. It was my favorite part.
