Everything posted by fnkershner
Well Mike My advice is to make sure there is no one laying on the sheets before you try to cut them up into rags for ship building.
- 421 replies
- granado
- bomb ketch
I did much the same thing on my R/C sail boat. And when it got to the point of installing the deck. I made my epoxy the consistency of Pudding. Then laid a heavy bead along the sides of the hull, installed the false deck, and turned it upside down. Over night the epoxy ran into the crack and did a wonderful job of sealing the joint. the deck was 1 solid piece.
Tony! I am in tears with Laughter. Wait till you get caught. :D
- 421 replies
- granado
- bomb ketch
I think you got the scale just perfect! Not too large but still noticeable.
- 209 replies
Thanks for remembering me. Just in case you want a comparison. Here in Seattle today we currently have a temp of -5 degrees C and the forecast says the high today will be 1 or 2 degrees C. On and by the way it is snowing. I might just have to mix up some epoxy as a hand warmer. Keep up the great work. I will try to feel warmer when I look at your log.
Gil - I like it. no one will know the difference when you are up close. And I want to see those clouds. PS I still have the blue cloth from that class.
- 753 replies
- finished
- caldercraft
Gil - Judy is a saint. I can't wait to show Carol these pictures of your work table. She keeps telling me it has to be outside.
- 753 replies
- finished
- caldercraft
How long are the 2nd planking strips? are they longer than the 1st layer. What pattern do you intend to use for the 2nd layer? and when will you plank the deck?
- 162 replies
This is a excellent example of coloring with wood. And a great result.
- 421 replies
- granado
- bomb ketch
Just remember - one of the reasons we do this hobby is to justify more tools!
- 421 replies
- granado
- bomb ketch
Rusty - I was just about to suggest something very similar to what Rob mentions above. Do you have a Drill Press? I picked one up at Home Depot for $150. It can be used as a poor man's lathe. And I have seen others use a Drill press to make cannons.
- 421 replies
- granado
- bomb ketch
After running the rigging thru the beeswax I also drag it quickly over a 40 watt bulb. This tends to melt the wax into the line. I think it is much better method than using an open flame. I use Beeswax on all my rigging and I like the result. I have models with rigging that has been treated this way about 10 yrs ago and have not noticed any deterioration.
I am going to suggest that you will need even more ballast than I do. My T37 is a sloop with one mast and the mast is approx. 5 ft high. she carries 635 sq inches of sail. She has a long fin keel with approx. 2 lb of lead ballast on that keel. The hull is just shy of 1 meter in length. I am guessing your boat will be bigger and carry more sail. Therefore I am also guessing you will need more ballast than I do. I know it doesn't look good but I am afraid you will also need a fin keel. I know that my T37 will turn turtle in a split second if the ballast was in the hull. It would be a shame for such beautiful work to end up upside down.
Jud - As I mention above. It is a very common activity in my R/C sailing club to seal both inside and out with Epoxy. We race our boats every other weekend. I know of a guy who has been racing his boat for more than 6 years and has never had the problem you describe. In fact it has been my experience that if the model is well built very little water gets inside. If you plank the hull properly and then seal with Epoxy I really doubt there will be any problems. one of the approaches that some of our club have discussed is that they seal all of the wood first with Epoxy on both sides. This leaves only the edges to join during assembly. Also on my T37 I used Epoxy exclusively as a filler, sealer and adhesive. Jud I noticed that you live in my favorite state. Did you know there is a very good Modeling club in Portland? PS I grew up in Eugene. And I am a proud Duck, Class of 81.
I am going to go over in the corner and cry. Never mind me. I will never do such wonderful work! Thanks for sharing Rusty.
- 421 replies
- granado
- bomb ketch
I am familiar with your WA. We have a GPS for the Car that has your choice of voices to give you verbal directions. My wife's favorite voice is an Aussie man. When he pronounces the name of our State Highways you can guess what he says. At first it was confusing now it is just a laugh. I can solve your problem about unsuitable weather for launching. Send her to me! I will gladly pay postage.
