Thank you Christian, good to hear from you. I have seven square rigged models in my house, four of them fairly large. I've sort of reached the stage now where it's time to move away from such models which really need casing to protect the rigging, and house room is becoming an issue. These smaller fore and aft rigged vessels still have a lot of interest particularly if you delve into the detail and history, and importantly they take up far less room on completion. 🙂 Regards, B.E.
- 195 replies
- lady eleanor
- vanguard models
Hi Steven, your mention of 50 figures on my Fifie log aroused my curiosity and led me to your build, and I'm glad it did. Love what you're doing with the figures, and I can see that you also love to delve into the research aspect of model building. I've got 43 pages to go thro' now and I'm looking forward to the journey.🙂 Regards, B.E.
Thank you Bob and Richard, for me researching a project is a major part of the pleasure of a build. @ Steven, Thanks for your input. - Re the sails, I am rather reluctant to ditch the expensive but beautifully made sails provided for the kit. The material used is so fine, and the stitching so neat, the best I’ve seen for sail material @1:64 scale. It is a slight disappointment that the stitching stands out quite so much, but the permanent marker route seems to work. Perhaps Chris could discuss the stitching thread with his supplier, given that these sails are traditionally coloured, rather than left undyed. I don’t think the Skipper will make the final cut on the model, but I do find such figures useful for scale purposes. He’s a chopped about plastic figure built up using modelling paste. Regards, B.E.
- 195 replies
- lady eleanor
- vanguard models
Post 24 A little backtracking. I have been having another look at the ships wheel. 3435 It is of the same dimensions as the kit provided wheel but whilst looking at a photo of a figure standing next to the wheel on Reaper I have come to the conclusion that it is somewhat overscale. I came across a description of the wheel dimensions as relating to ‘True Vine’, another 70’ Fifie of 1905. A wooden wheel, 20” outside diameter., with a 2” rim, 6” boss, 2½” thick, has six spokes 4” by 1”, and is connected by a worm gear. 5897(2) I did a scale mock-up in card to these dimensions, and this is the result, quite a difference. The scale wheel measures 14mm o/a diameter including the spokes. Amati do a 14mm wheel which I ordered as a suitable replacement. 5971(2) A much better scale fit I think. 5978(2) I have also created a Skipper for my Fifie. 5990(2) Willie Buchan is a little rough around the edges, but he is a good 1:64 scale to help me judge relative size. 5991 5995 5994 A re-think on ring bolts Having gone to some length to make ring bolts for the hatch boards, I’m now undecided whether I like the look, or indeed if they are an authentic fitting. I’m beginning to think from looking at mostly unclear old photo’s, that the boards didn’t have such fittings. 3492 This is re-enforced by this finely detailed model of a Zulu. The cover boards as seen both on the hatch and stacked up behind the coamings are free of such fittings. 5984 I remade the boards from Pearwood sheet and they suit my eye better. 6007(2) B.E. 09/07/2020
- 195 replies
- lady eleanor
- vanguard models
Thanks Richard, That's what I did, the stitch lines don't show up in reality as much as on the photo's, but I'll go over them again with the permanent marker before use. Used carefully I didn't get any bleed onto the sails. I can't answer the photo size question, but for me you can't beat a nice large photo.🙂 The Isabella Fortuna is a smaller Fifie, but a beautiful boat. Note the white painted mast tops, yard tips, and blocks. This is an old tradition, not a modern decorative effect, made them easier to see in the dark. I will probably use that scheme on my build, but not sure about painting the blocks white. B.E.
- 195 replies
- lady eleanor
- vanguard models
I thought that may be the case Steven. The Dye blurb says add salt for cotton, rayon, or linen, and vinegar for nylon, silk, and wool. Not sure how these additions aid the dye process, but perhaps I will add a little vinegar to the mix next time. Cheers, B.E.
- 195 replies
- lady eleanor
- vanguard models
Post 23 Colouring the sails This is the description as given in the Sailing Drifter book. Sails were ‘barked’ a rich, dark brown, almost black colour. They were seldom tanned the warm Red of the English drifters. This is the sort of look I was after. To replicate this effect, I am using Rit brand (cocoa brown) dye powder, as mentioned and used by James in his ‘Zulu’ log. One issue that arose for me, new to this process, is that the quantities given relate to articles of clothing, not two smallish cotton sails so the question of proportions comes to mind. The recipe’ and procedure I used was as follows. Into a plastic bowl I poured 4 pints of hot water. 4 teaspoons of dye powder (virtually the whole packet) were dissolved in a 1pint jug of near boiling water from the kettle. This was added to the bowl followed by a sprinkling of salt. The mixture was well stirred, and the sails added. I stirred them around for approx 20 minutes which gave me the depth of colour I thought was ok. The sails were then rinsed in a bowl of cool water three times, until the water ran all but clear. They were then hand washed in warm water with a mild detergent added, rinsed and put to dry flat on an old towel. 5916(2) The completed sails set out to dry, a slightly lighter hue should ensue. 5922(2) I think this is as close as I will get to the shade I was after, so I can put them aside now until needed. For some reason the sail stitching and bolt ropes remained stubbornly white. I used a fine point waterproof marker to colour these and take the starkness out of the white. An interesting snippet I came across during my subject reading: Early in the 20thc two men, each sewing for a 9-hour day completed a Foresail in a week, a Mizzen in 4 days, 2 jibs in 6days. Finished price – Foresail £30, Mizzen £15, Large Jib £10. B.E. 06/07/20
- 195 replies
- lady eleanor
- vanguard models
You’re well placed to get some first hand detail on Fifie’s Richard, I’m 324 miles from Anstruther where the Scottish Fishing Museum is based, and the Fifie Reaper is berthed. I hope to get up there one day.🙂 B.E.
- 195 replies
- lady eleanor
- vanguard models
Hi Richard, thanks for looking in. I just use sandpaper to taper, with regular checking of progress with a gauge. I’ve not experienced any whipping between the centres, I just use my hand to steady the stick as I work along it. I am careful not to put too much lateral pressure on the stick. Cheers, B.E.
- 195 replies
- lady eleanor
- vanguard models
Hi Bob, I bought a bed extension piece for the lathe which adds just shy of 18" to the working length. I've never needed the full length, but I have often used beyond the original length of the lathe, including for the Foremast of the Fifie. The advantage is that the full length of the mast can be worked without having part of it within the jaws of the lathe chuck. B.E.
- 195 replies
- lady eleanor
- vanguard models
Thanks Dave, I think an unintended consequence of the new system is that as more time is spent in our current build era, the other eras tend to get overlooked, and unless I spot something in the latest posts section that catches my eye, things are missed. Under the old system I tended to see more as I scrolled down the build section looking to find my build to update. One of the objectives of the new system was apparently to reduce the incidence of the same old builds hogging the limelight. Well I'm now on a guilt trip as my current build seems to be nearly always towards the top of the list, simply because I am progressing quite quickly, and the pond I'm in is so much smaller.🤔 On with the build, and I may I request that folks don't turn my log into a pro's and cons discussion forum on the new set-up. Post 22 Looking at the masts and booms The Foremast on these large Fifie’s seem almost over-scale but are very stout timbers, necessary to withstand the pressure from the enormous lug sails carried. The kit mast represents a height above deck of 52’6” with a 15” square section at the deck, and 9”ø at the masthead. This is fairly modest by comparison with recorded dimensions given by Edgar March. The True Vine also a 70 ft Fifie had a foremast with a 22” square section at the deck, tapering to 9”. This would equate to 8.75mm at 1:64 scale, something that would not fit on the ‘Lady Eleanor’ Time to get the lathe out. 5848 Walnut square section (6mm) is provided for the mast. Walnut is a good choice I think, as the masts do seem to have been of a dark hue, apart perhaps from a white section to the Mast head. To make the mast I roughly take off the corners above the square section using a micro plane and a ‘V’ jig. 5847 I then use the lathe to create the taper. I use a gauge at marked points along the length to check progress. The Mizen mast more closely follows the given dimensions of the True Vine (15” at deck, tapered to 9” at masthead.) 6mm Walnut dowel is provided. The Mizen boom is a length of 3mm Walnut dowel slightly tapered. This looks a little thin to my eye by comparison with the boom on Reaper. Altho’ I have given lengths of this boom I have not found details of relative diameters as yet. 5853 The Mizen mast was set with a forward tilt, and wooden wedges were used to trim the angle of the Foremast to suit the preference of the Skipper. I intend to display my Fifie with the mast vertical. This seems a common arrangement as seen in a large number of the old photo’s I have looked at. 5850(2) The yards need only a little adjustment to the 3mm dowel and are shaped by hand. 5852(2) What a pleasure it is to only deal with a simple lug rigged two master, no tops, crosstrees, or mast caps to consider. 5900 The masts are a snug fit and I won’t need to glue them in. A wedge aft of the mast will be required to hold it firmly against the baulk. (not necessary if you prefer some rake aft) 5904(2) The kit provides brass etched ‘mast rings’ which perform two purposes, the first to gauge the mast taper at the mast heads, and the second where one of the six eyes that form the ring are the attachment point for the Burton stays of the masts. A hole is also drilled thro’ the mastheads to take the yard halyards. I feel a slight enhancement coming on to this arrangement. I now need to familiarise myself with the rigging set up and attachment points before I proceed further. B.E. 05/07/20
- 195 replies
- lady eleanor
- vanguard models
I was pondering with Mrs W the other day about how to dye the sails, I've no experience of dyeing anything, except perhaps standing rigging in wood dye. I have the Rit stuff which reckons one packet dyes two large tee shirts, but to double the dye for a deeper colour. How this equates to two small sails I've no idea. I guess it's a case of suck it and see. I certainly won't be doing the hot cook method on Mrs W's induction hob, that could end in divorce, in fact I'll probably sub-contract the job to her and keep well away from the whole process. My Scottish reference work says that north of the border a deep brown colour was the tradition, whereas the English preferred a reddish, dare I say even pink hue, as favoured by James.😉 Movin' on... B.E.
- 195 replies
- lady eleanor
- vanguard models
Mark of a good modeller Glenn, fortitude and persistence, and yours has paid off handsomely, well done. 👍 B.E.
- 778 replies
- cheerful
- Syren Ship Model Company
Cheers Guys, Thanks Bob, and Michael, I’m pleased you like what you see. @ Glenn Thanks BE, that makes sense. I wasn’t thinking like a fisherman 😊 It’s nowt to do with me Glenn, a few weeks ago I’d never heard of a Fifie, but I’ve done a load of speed reading.😉 @ Richard – ask away no problem. To some extent it depends on the tightness of the bend, but I tend to use cold water for a few minutes only, and then use a hair dryer on max heat to fix the shape I formed. I don’t think Chuck even bothers with water, just bends by degrees and uses heat alone to fix the shape. Regards, B.E.
- 195 replies
- lady eleanor
- vanguard models
Wow Guys, a lot of questions. Glenn said Nice work on adding the nets. The location of the chimneys seems peculiar, seems like all the smoke would blow right in the helmsman’s face. I don’t think it would be an issue Glenn, the Capstan boiler and galley were not in use during the sailing of the boat. The capstan was used to set the large fore lug and hauling in the nets, when the boat was in drifting mode. The Galley would only be used once the nets had been cast. The only relative rest period for the crew was during the night whilst the boat was drifting. As I understand, once fishing began, the Foremast was lowered, the Mizen removed, and also the rudder, (I don’t know how) to prevent excessive movement. Chris said And I had (finally) my Zulu sail set order arrive today, so all that ordered sail sets for their Zulus will be receiving them within the next week, and anyone who now orders a Zulu and sail set can be shipped together. Nice work of the Fifie, BE, I see these models as a 'blank canvas' for the more experienced, who like to stamp their own mark on the kit. Thanks Chris, I very much look forward to building this iconic Fishing boat Richard Said There is one thing that sort of bothers me with the modification you have made to the wheel. Where does the helmsman stand. Normally he would want to face forward, behind the wheel. The mechanism would sort of prevent this & plus he would have to stand on the thwart (further from the boat's center of gravity, a bit more unstable). As you can see from the photo’s of the Reaper, Richard, there is not much room. The Skipper didn’t stand on the thwart he sat on it, to the starboard side. The port side was cut off by the Mizen boom. Some boats had a stool instead of a thwart. What did you make the nets from ? I used a soft Tulle net fabric, in the shade Peat Brown. It is cheap to buy, I got mine from a company called Minerva crafts, but there are a lot of online sales for this stuff. Are you going to add a fish smelling perfume to the open hatch ? I don’t think Mrs W would appreciate taking realism that far, Richard.😃 I've had to hold up on my Eleanor since I'm spending some unscheduled time in the hospital. As soon as I get put I'll be starting the 1st planking. Did you start in the middle for that and work towards the bow and stern and pin as you went along? Did you also soak the lime planks to get them to fit better? When pinning the planking I always start from the bow, but before that I have dry fitted the plank having tapered and shaped it where necessary using water and heat. Rusty Said Great workshop B.E. Really enjoying your build. I'm also interested in the Lady Isabella and may have to breakout the cc. Cheers, Rusty, I think there is a lot more detailed information on Zulu’s out there to assist a build. Bob said A chimney is easily made, from some 3mm ø aluminium tubing. Did you solder the aluminum chimneys? No, I just used ca to make the bond The nets are awesome! How did you make them? See my reply to Richard, above. I have the Lady Isabella and would like to find out more about these Zulu fishing vessels. Do you have any good resources that you could recommend? The good news about Zulu’s is that there is a lot of information on the net, including history, plans, excellent build photo’s, and historic photo’s. I have used the net extensively for my research, but I do have an excellent long out of print book – Sailing Drifters by Edgar J. March. Still in print is a useful book called Inshore Craft – Basil Greenhill & Julian Mannering. Doug said I was just gifted with a set of blueprints for the Zulu Muirneag. Plans were drawn by Harold Underhill in the 1950's. His book "Plan-on-Frame Models" has reduced version of three of the plans. I can't use the blueprint set so they're listed in Traders... One source of detail. Underhill’s plans are still available on the net at around £10 each. In relation to the Zulu kit there are some that would be more useful than others, eg; deck layout, rigging plan etc; B.E 02/07/20
- 195 replies
- lady eleanor
- vanguard models
Thank you Grant and Bob, your interest is much appreciated. Post 21 Taking stock I felt this was a good point to review progress thus far. This is also a good point to set out the remaining deck fittings to ensure there are no unwanted surprises. 5825 I have made a couple of additions to the deck furniture, in the form of Chimneys, to service the steam capstan, and Galley stove. Such pipes are shown on the plans I have seen, and Reaper also has one. A chimney is easily made, from some 3mm ø aluminium tubing. A smaller second pipe was also fashioned for the galley stove. Because of my modifications to the steering I had to reposition the Mizen boom stop slightly. 5823 The cover boards for the Fish Hatch have been fitted with ring bolts in preference to the provided items, and only a portion of the cover boards are in place. 5839 The hatch is left partly open to reveal the nets that would usually be kept in that area. 5836 The nets were cast over the Starboard side and there should be a net roller running along the hatch coaming to assist the process. I don’t have sufficient detail of the arrangement to fit one yet, but I am looking. Such boats also carried seven 22’ sweeps stowed on the Foredeck and shipped into crutches socketed into the Timberheads. I don’t know if I will represent these at present. 5830(2) 5818(2) 5819 5822 5826 5829 Since I have started researching fishing boats I have been amazed at the sheer hard manual work, hazardous conditions, and danger involved in working these boats. The seamanship required to work the lugger rigs seems extraordinary given the harsh conditions they had to work in. It is hard to believe that contained within the hatch were some 60/70 nets, 60 yards long, and when strung together produced a drift extending some 3300 yards from the boat. The invention of the steam capstan must have been a very welcome addition to aid the exhausting process of hauling in the nets. So much am I enjoying this build, I couldn’t resist doing a follow up of the Zulu. 5843 Ordered yesterday, arrived this morning; great service Chris.👍 Shame to waste all the research I have done, and they will make a fine pair, but I won’t start the Zulu until the Fifie is completed. B.E. 01/07/20
- 195 replies
- lady eleanor
- vanguard models
Thank you Rusty and Tim.👍 Post 20 Completing the tiller attachment. The final part is the attachment of tiller and worm drive. I have been hampered in my efforts by the lack of a detailed plan and I have had to rely on a visual interpretation from photo’s of the restored Fifie Reaper, and indistinct drawings and plan of the Fifie True Vine. Reaper What I am sure about is that these late 19th/early 20th century large Fifie’s did have the wheel close to the stern with some sort of mechanical attachment to work the rudder. It would be reasonable to run a shaft from the wheel to the stern post, covered by a narrow longitudinal box with a rod or stiff wire from the rudder, entering the box on the aft starboard side. True Vine Plan This is as much detail as provided on the True Vine plan. There is also a small drawing of a ‘boxed’ worm drive with dimensions in the book Sailing Drifters by Edgar J. March. 5798(2) The rod is 0.9mm ø micro brass tubing with a couple of etched brass eyebolts (PE2) from the kit inserted in the ends. 5800(2) The connecting ‘Bolts’ are formed from brass wire which hold the set up together. 5812(2) My interpretation is based on the Reaper set up. If further information comes to light I can make further modifications but for the present I am content to leave it at this point. B.E. 30/06/2020
- 195 replies
- lady eleanor
- vanguard models
Post 19 The Rudder. Chris has created a simplified arrangement that takes out all the fiddliness usually associated with fitting a rudder. 5720 This has tenons on the rudder that slot into mortices on the stern post and hold the rudder in the correct position. Syren mini kit. I decided to fit a slightly more mobile set up using Chuck’s mini pintles and gudgeons kit. 5722 The gudgeons are shaped to suit and fitted to the stern post. I use a length of wire to align the holes for the pintles. 5725 First trial fit; pins have been inserted into the rudder to represent the pintles. With the rudder set I can now follow through with the paint lines. 5749 I decided to re-paint the lower hull Vallejo Matt Red, Mrs W said she preferred it, and that tipped the balance. On reflection I do think it suits the Pearwood contrast better. 5752 At this point I can trial fit the tiller iron on the rudder and the rod connection between rudder and worm drive. The finished version will hopefully be a little more detailed than a length of bent wire. 5783 One of the things I like about Chuck’s little rudder fittings kit are the boxwood and fibre straps. So much less fiddly than messing about with brass strip and looks good for scale. I represent the bolt heads with blobs of pva. 5791(2) The tiller arm now blackened is glued into place on the rudder. 5777(2) 5789(2) There is some remedial cosmetic stuff to do following my modifications, but I’m fairly satisfied with progress to date. B.E. 29/06/20
- 195 replies
- lady eleanor
- vanguard models
Great looking model Kevin, such realism, and I love the subtle weathering. ps every ship modeller should have a spaniel assistant.😉 Cheers, B.E.
- 337 replies
- finished
- mountfleet models
Post 18 The Capstan Elliott and Garrood steam capstans had been used on Fifie’s and similar since 1885, and one is provided in the kit. This is the most prominent and striking fitting on the deck, a real eye catcher, and beautifully presented by Chris. A combination of laser cut wooden parts and brass etch, which makes up into a fine little model. My most difficult decision; what colour scheme to use. 5730 The suggested scheme of red and green reminded me fondly of my old lawnmower resplendent with green casing and red cylinder blades, so I opted to go with that. I am using Humbrol enamel paint, Matt 80 (Green) and Vallejo Matt Red. Most time-consuming part is painting the whelps of the capstan. These eight fine etched parts required painting before assembly. The manual suggests that the drums be attached to the whelps without glue when assembling. I found that without glue the whelps had a tendency to fall out during the alignment so I resorted to a spot of ca to hold the whelps in one drum whilst I fiddled to align the other. The box atop the capstan fits over the end of the central spindle that runs thro’ the capstan body, (aka 3mm walnut dowel) 5729 A nicely turned brass warping drum is secured to the side of the box. I drilled mine to take a pin to secure it to the box and gave it a chemically blackened colour. 5732 Note:- there are two small holes in the side plates, I’m not sure what they are for, but they are not for securing the warp drum. 5731 The central spindle of the capstan is in reality a steam pipe. 5736 When fitting the small hand wheel atop the box I found it best to put a spot of ca on the connecting pipe and press it down on the wheel. B.E. 28/06/2020
- 195 replies
- lady eleanor
- vanguard models
Before you glue everything down Tim, worth checking that the Bowsprit fits ok between the standards, and runs true thro' the securing ring. B.E.
- 436 replies
- vanguard models
- alert
Fascinating subject, and a great job you're doing Keith. I love projects that require loads of additional research, frustrating at times, but adds to the build satisfaction no end. Regards, B.E.
Thank you Grant, Jason, and Bob. @ Bob - The brass mechanism was chemically blackened, I always prefer to 'blacken' rather than paint metals, where possible. However, the wheel which is also brass I painted using Vallejo Hull Red, I didn't prime before painting. Regards, B.E.
- 195 replies
- lady eleanor
- vanguard models
Post 17 Modifying the steering. The first thing to consider is the wheel and the worm drive. I’m not using the provided wheel but another of the same dimensions. For the worm drive and fittings, I obtained a length of M1.4mm threaded brass rod with associated nuts, Hex and open. 5641(2) I.4mm ø looks about right and importantly is a good fit for the centre of the wheel. The brass will be chemically blackened before fitting. Before I proceed too far a bit of de-construction is required. 5644 Replacing the deck planks where the holes for the wheel standards were cut. Not a great issue and quickly done. 5648 Once scraped they should blend in just fine. At this point I also put together the Companionway cover as this has a bearing for positioning the relocated wheel. I did make a minor modification to this altering the sliding canopy arrangement and using a proper ring bolt for the door handle. 5670(2) Next up I had to fabricate a thwart and a knee at the stern, both important for the addition of the steering gear to follow. An important item is the section along the worm to which the steering arm is attached. 5685(2) I made this from styrene tubing with nuts ca’d into each end thro which the worm will pass. One half of the provided tiller arm is slotted into this. 5680(2) At the aft end of the mechanism the worm screws into a supporting nut silver soldered to a plate. These are tiny and it took several goes to make the bond. 5689(3) One of the consequences of this modification is that the rudder needs to be tweaked to suit the revised steering mechanism. I added a small section to the top of the rudder and filled in the slot provided for the brass etched tiller arms. The mechanism is fitted into place after blackening and painting. Note one half of the etched tiller arms is used on the worm housing. 5711(2) The wheel is attached, and the rod trimmed to length. 5710(2) 5707(2) This is as far as I can take it at present, I need to complete the rudder before the connection can be made. B.E. 25/06/20
- 195 replies
- lady eleanor
- vanguard models
