Everything posted by Chuck Seiler
Doris, I am glad you reconsidered building the CONSTITUTION as your first build. Very often when people start out with something like that as their first build, it ends up being their last build. It is quite a challenge. I agree with Gary in that models like SULTANA, NEWSBOY or BEN'j LATHAM make good starter models. IF you have experience, SYREN might be good, but it is still something more than a starter kit. I like SULTANA. It is very basic and lets you work with all the skill sets you would need to do a CONSTITUTION, but in an easier format. SULTANA is a solid hull. I found it difficult to work with, but it is easy to make a better hull by using the body/sheer plan that comes with the kit and making the hull using bread and butter method, or making your own bulkheads (or a combination as I did). If you don't have the skills to do that, in my opinion you don't have the skill set to tackle the CONSTITUTION. Just sayin'. I believe that if two people with the same skill level started building (1) SULTANA and (2) Model Expo CONSTITUTION, the SULTANA builder would be pretty much done by the time the CONSTITUTION was planked. If they were beginner modelers, the SULTANA builder would be planning his/her next build while the CONSTITUTION builder would be thinking about getting into model railroading. Anywho, my 2 cents worth.....
Mike, I recommend using rubbing alcohol (isopropyl) for the un-gluing process. It works as good as water (maybe better) but does not seem to affect the wood. Use in a well ventilated area.
Red Paint or Red Ochre
Chuck Seiler replied to davyboy's topic in Painting, finishing and weathering products and techniques
I'm staying with quinacridone red (see post 18) -
I am curious as to why they didn't have lids on the gunports in the waist. I understand that area is open to the weather, but it still provides some protection against the seas slopping in.
- 2,191 replies
- confederacy
- Model Shipways
J11, Take a look at the Lumber Yard. They have a larger variety of guns than Chuck (Syren). The downside is that Dave (co-owner) is out of circulation for awhile and getting the guns quickly may be an issue if they are not already made. I need to check my plans to refresh what scale and which size guns. As I recall, there was a mishmash.
How come when you add white to blue it becomes light blue, but if you add white to red it becomes pink. Doesn't seem fair. -
Hipexec, Do you want to paint your wales red or your bulkheads? -
At any rate, your interpretation of the wind is as good as any. Most people who look will not even notice. They will be impressed with the overall diorama itself.
- 30 replies
- philadelphia
- diorama
(and 3 more)
John, I have a copy of the thesis "The Continental Gondola Philadelphia-A Dissertation by John Raymond Bratton" from Texas A+M University. It can be downloaded from the following site: http://nautarch.tamu.edu/Theses/abstracts/bratten.html It goes into detail about the recovery, but I'm not sure it gives heading. He does indicate both anchors were found in the mud directly under their respective catheads, indicating they were onboard when it sunk, eventually dropping off when the cables rotted.
- 30 replies
- philadelphia
- diorama
(and 3 more)
John, I got the impression that they secured the anchor cable to bits in the stern so that 'downwind' had them facing the enemy. I'm not sure where I got that from, but I know in my days with the navy were moored to a pier like that once or twice. Since the cable was coiled up on deck, it would not have been hard to re-run it. There are 2 bits aft, one either side just aft of the rear cockpit. You are correct, however, since both anchors were with the wreck it is probable that it was not anchored when it sunk.
- 30 replies
- philadelphia
- diorama
(and 3 more)
Joel, Wouldn't their heading be ship dependent? The galleys would have been as you said so as to present a broadside to the enemy, but since the gunboats mounted their heavy gun in the bow I would think they would have been facing the enemy...south-eastish.
- 30 replies
- philadelphia
- diorama
(and 3 more)
Superb work!!! When I looked at photo 4 and 5 of post 12 I thought the rescue scene was taking place next to the beach. I now see that what I am looking at is not the beach from the diorama but the actual ground.
- 30 replies
- philadelphia
- diorama
(and 3 more)
You also asked about sizes... Given that you have a table saw, I would go with sheets. I like to go with 3 inches wide where I can. Eeking out that last plank on the sheet is a pain and you have to do it less often with 3 inches rather than 2. Thickness? I recall a discussion somewhere that talked about 1/16" vs 3/64" thickness for planking at the scale you are working. I have found 1/16" to be good.
Eddie, I think a scroll saw is essential for this project in order to cut the frames/futtocks. I have a crappy-assed Dremel scroll saw that I used to cut the frames for the WASHINGTON (before I shelved it). It was okay,but not great. I have the MS RATTLESNAKE kit and plan to replace the basswood with hardwood...so I have given the question of 'which woods' some thought. I am a big fan of boxwood. I was going to use boxwood above the wales, with a natural finish on the 'yellow/buff' area and paint the black area black. In the pasted I have either used or experimented with ebony, ebony stain, black wood dye and black paint. I was not a fan of black paint until I started using the 'coachman method' Chuck P. talks about in either his CONFEDERACY or WINCHELSEA build log. When done right, it is exquisite. I love boxwood,however, based on some recent discussions,I might try Alaskan Cedar from Wood Projects Resources. For decks I usually use holly, but that is getting harder to come by. My next project may involve maple. You won't be planking much below the wale, but where you do, I would use holly or maple.
There goes one now!!!! Model Expo/Model Shipways regularly has sales. Get on their mailing list and they will let you know when they are. Figure out what you want to do for your next project (or maybe the one after that). When it comes up on sale, go for it.
Gus looks out of focus. I need another beer.
- 449 replies
- sultana
- model shipways
