Everything posted by Landlubber Mike
Thanks Andrew - I've always thought the Finnish scheme looked really cool. Generally they are black and dark olive on the topside, but one of the three camo schemes includes white in it for a winter scheme, and I might try that one. I've always liked winter schemes, though spraying that much white always scares me given how tough white can be to get the right coverage and opacity.
Here's where I am today. Managed to get painted the interior of the fuselage halves and remaining interior items to install. I'm pretty happy with how things are looking. I went ahead and used Vallejo's Metal Color Duraluminum. It sprays very well. After using mostly Mr. Color paints on my 1/48 Buffalo, it's been nice to go back to acrylics for ease of preparing the airbrush and cleaning. I'll still use Mr. Surfacer for the exterior primer and either Mr. Color or Tamiya for some of the harder to paint colors like the yellow on the cowl and wing tips, but I might go back to using acrylic elsewhere. Thanks for looking in!
With the fit issues on getting the fuselage closed up, I thought it would be better to add as much of the interior as possible to one of the fuselage halves, rather than trying to install what are three or four separate assemblies into the fuselage halves and then trying to get it closed up. Taking this approach allows me to position the sub-assemblies on one half of the fuselage, and while the glue is drying, test the fit and get the final location by dry fitting the other fuselage half over it. Takes quite a bit of time, but I think it will be less painful in the long run. Instructions are ok I suppose - generally there are no locating marks, pins, etc., so you have to sorta guess where the instruction arrows point you. Thankfully there are other builds out there on the web to doublecheck yourself.
While waiting on parts to dry on my Walrus for otherwise just needing a break from it, I started the Buffalo 239 Finnish version from Special Hobby in 1/32. Since I just finished their 1/48 Buffalo kit, I figured I might as well tackle this one given I know what to look out for. Unlike the 1/48 kit I just finished, this one I will be building mostly out of the box with considerably less aftermarket. The kit is like the 1/48 kit (and probably most SH kits) in that in addition to the plastic, you get resin and PE details in the box. It's been interesting comparing this to the Airfix Walrus that I'm working on. The Airfix kit has great fit but a lot of flash and injector marks and other cleanup that you need to do. This Special Hobby kit needs much less cleanup, but the fit is not the greatest. I can tell already that I'll have a big gap closing up the fuselage forward of the cockpit 🤬 But, so far this has been an enjoyable build over the last week or so.
Hi neighbor, welcome to the site. You'll find a great bunch of people here. Thank you for your service!
Very cool!! Great job on this. I love builds that are unique!
- 16 replies
- Higaki Kaisen
- Woody Joe
Finally got through assembling most of the interior. The Eduard interior PE set is pretty intense with a ton of pieces (close to 100 if not more if I remember correctly). Probably took a good 3-4 evenings of work to get in, and my guess is 95% won't be seen. But, good practice I suppose. I've gotten a little better with some of the types of PE that have vexed me in the past, including circles/rounds. Had a few to do here with the two gun cockpits, and improved my skills there. Here are the pieces with the Eduard interior, minus most of the pieces from the colored PE fret that will go on after I paint these interior pieces: That little piece in the middle of the bottom row is actually the ship/boat's anchor - interesting! After taping the various edges, I ended up priming these pieces and a few other interior pieces this evening. Then it's onto painting the interior green, adding the remaining Eduard pieces, and a bit of weathering. Thanks for looking in!
Thank you Christian! I agree, would be a lot more complicated to accurately represent the damage if it extended below the water line. I could not find any pictures of the damage to the Asashio, only reports that the damage was light and that the ship continued operations until it reached Truk. So, I assumed that the damage was limited to above the waterline - artistic license I suppose
I'm in too! Great pic of your son! Looks like a very detailed kit. My first Airfix kit was an old Citroen kit which was a bit underwhelming. I wasn't sure what to think of Airfix after that one, but my current Walrus kit from Airfix is really impressive. Looks like your Airfix kit is similarly very detailed and well done.
The MDF used in these kits is very hard - much harder than plywood. At least that was my experience with my Pegasus kit.
- 29 replies
- Fly
- Victory Models
Hey Dan, thanks very much! Really appreciate the kind words. These particular versions of the 339-23 that went back to the US weren't used in combat from what I could tell, so I went easy on the weathering except to show a little dirt and dust. I was particularly excited with how the painted insignia and numbers came out - a little more work than using decals, but cleaner finish and no chance of silvering. All in all, a really fun kit to put together, and a good learning experience with all the aftermarket.
Did you use Future for this? And did you spray it on/brush it on the mask edges/dip the canopies? I haven't tried that approach yet, but have had bleeding issues in the past. I was going to try sealing the edges on my Buffalo by painting on some kind of clear by brush along the edges, but in the end decided not to and just crossed my fingers (luckily it worked).
Wow, what a fantastic job Andrew! Love all the details! Congratulations on a wonderful build.
- 206 replies
- Vanguard Models
- Brixham trawler
