Posts posted by cobra1951
Just letting everyone that has been following this log know that Bounty is no more.
Do not place your model on the bed then play with the dog on the same bed, because once you land on top of it this is the result
It was my own stupid fault and the dog is not to blame
I would like to thank everyone who has replied to or liked the posts in this log
Now onward with more builds, the left over wood and parts will come in useful in the future i'm sure
- AntonyUK, zoly99sask, Seventynet and 1 other
4
Hi Elijah. I don't know if you have already seen this or not but you might find the download helpful with your build. I think you have to register on the site to download the files
not sure as i haven't registered there
Extended the planking to about halfway now, but not happy with the kit design of not having any support underneath the planking. This meant there was a danger of cracking the planks when it came to sanding them.
Picture is planking seen from underneath
Got out my supply of 3mm birch plywood and roughly cut out two pieces to act as false decking
Once cleaned up they were glued to the underside of the planks to strengthen them
I then took some off cuts of 1mm x 4m lime i had already cut up for stirring paint and other such jobs
Glued 4 strips together to make a 4mm x 4mm beam, made 6 beams altogether
The beams were then glued to the main frames and cross beams and also to the bottom of the false decking i had made. Planking is now a lot more stable and will enable me to sand them without worrying about cracking them. The same will be done to the rear half where needed
- mtaylor, CaptainSteve, GuntherMT and 5 others
8
Great job getting rid of all the paint spill
All the work on the ladder is extremely well done, i really like the addition of the non slip tread plates on the rungs and also the big non slip plate at the top of the ladder before the planking starts
Hi all
First welcome to all and thanks to everyone for all the likes and comments
While waiting for planks to dry on my Bounty i started the deck planking on this build
The instructions supplied some 0.5mm x 2mm walnut to do the caulking in between the planks. i decided not to use this as it was a bit on the brittle side and more of it was ending up stuck in my fingers instead of on the kit
To simulate caulking along the length of the plank i used some 0.25mm thick black styrene sheet i have, i glued a strip along the length of the plank and once dry i trimmed it to fit
For the butt joints i went with the instructions which meant cutting a slot across the plank without going all the way through, The reason for this is that except for the 3 frames there is no support beneath the planks to use a proper joint. Then i simulated tree nails either side if the slot.
- cristikc, WackoWolf, zoly99sask and 7 others
10
thanks Piet.......made some small progress.........once I get it together........ I can also tell you all about the dummy move I made
Sounds intriguing
- Piet, mtaylor and popeye the sailor
3
I would guess but as i have had the kit i will abstain because i know
- popeye the sailor, mtaylor and Elijah
3
Hi.
You will enjoy this kit i had it a while ago.
Except for the figure head it's the same kit as the Zvezda's Black Pearl kit. You got the better one as it's a
lot cheaper than the Black Pearl version but exactly the same quality.
- tradewinds, mtaylor and Elijah
3
Love the attention to detail on this build. Looking forward to the next update
- popeye the sailor, Piet and mtaylor
3
Yes it dries clear, one of it's uses is to glue cockpit canopies on model aircraft
- Omega1234, popeye the sailor and Piet
3
Hi Bryan.
Looking good, surprising what a bit of paint can do to change the whole look
As for the gun port template i think you have done the right thing in moving it along a bit, not only because it misses out the ribs, but also if you left it and removed the rib parts it would seriously weaken the hull IMHO.
I too am building the same gun deck section as Paul is and you are correct in thinking the materials are good quality, they are.
What Paul says about the book versus the plans is correct they do contradict each other in places, you just need to read both for the part you are doing and decide which best suits the way you build. A bit like your template problem, but it's all part of the fun
If you want something to glue clear acetate to wood without it misting up try this http://www.ebay.com/itm/Deluxe-Materials-AD55-Glue-N-Glaze-Glue-/231851041327?hash=item35fb66222f:g:p7kAAOSwjVVVkwHO
I use it on all sorts you can even use it to make a window in a small space check out the video
Just spent some time here cruising through the whole log. Great work, and even more so that you are showing that a person doesn't need a shop full of fancy tools to do beautiful work. Mastery is in the hands, not the toolbox
Best Regards,
Bill
I totally agree with every word Bill said. You have made great progress since my last visit
- popeye the sailor, Piet, Omega1234 and 1 other
4
Battle Station by cobra1951 - FINISHED - Panart - 1:23 - Also known as Posto Di Combattimento
Gun deck planking done except for the last plank which cannot be fitted until the three rear upright supports have been removed later in the build. They will be removed once the six support pillars have been put in place
Next job is the inner and outer hull planking
