Posts posted by cobra1951
Looks superb, love it
- popeye the sailor, Piet, edmay and 2 others
5
Hi Paul
First there is no such thing as bad humor IMHO.
The only thing the Dog had done to him was to be fed lots of biccy's to show him it wasn't his fault, because he thought he had done something wrong
As for the Occre Bounty you are halfway there, i have got the Occre Endeavour
I can sympathize, Bob. I had a Billings model of the Bluenose that was trashed by an angry kitty. I put it aside, and 10 years later came back, stripped it to the hull and rebuilt it. That's what got me restarted on the hobby. I must say your acceptance of the situation is better than mine was! Hi Baily! Good boy!
What else can you do but accept it and move on. Worrying about it won't make it any better so i don't.
smile and move on
Jesus, Cobra, what have you done? I am so sorry. That hurts. Time to start a scratch build.
Daniel
I made the mistake of thinking you can play with your dog in the same place as a wooden kit
My fault not his
Hi Per
His name is Bailey and he is innocent when he's asleep
- Capt.Fisher, Canute, Harvey and 1 other
4
- robin b, Canute, thomaslambo and 2 others
5
Hi Mr Pucko
Yes you mean the part that has the 2mm x 5mm Strips glued on to it, so the wedge can move back and forth. I will try it out with 1mm x 5 mm strips before final assembly
Thanks for your input
One other thing i am going to look into changing is the Gun Port covers they are far too thick
Thanks Capt Fisher and thanks Ian
New replacement build arrived this morning "Occre Endeavour" will start on it soon
- Canute and Mike Dowling
2
Thanks Mr Pucko
I will check it out before final assembly. I am working from the booklet mostly and only use the plan sheet for double checking anything I'm not sure of because the plan sheets are older. Probably the same ones that Mantua made before Panart changed some of it.But there are still loads of errors in both the plans and booklet
Nice choice...to tell you the truth, if my dog got the Bounty I wouldn't build another one.
And it has nothing to do with AL
For me to buy another AL kit i would have to be able to view the contents before purchasing, because of all the bad timber in the kit i had. And i know others have had bad timber in theirs also
Awe yes using the bed as a playground has it's price
. You have the right attitude in saying it's only wood, carry on.
I have always had the attitude of worrying about it won't change anything so i don't
- Seventynet and Canute
2
Hi Paul
Will test everything once i have the parts built up. In the instructions the hatch covers do not look like they are in the same position on the upper and lower decks, to me this is incorrect but i will see better once i get to that stage and adjust everything as needed (hopefully lol)
Job well done those quarter galleries can be very fiddly
- Seventynet and Robert29
2
Hi Per
Bounty is beyond resurrection
in fact it's already in the the rubbish bin
lol
Thanks for the concern for me and my dog, he is fine apart from thinking he had done something wrong which he hadn't, but lots of biscuits sorted that out
As for me i moved on and forgot it within 5 minutes, i did think of setting fire to it and pretending it was a replica of the Bounty when they left it at Pitcairn
:D
- Canute, mtaylor and Seventynet
3
Thanks Paul.
I am going to add simulated tree nails to the hull inside and out but not to the extent i have seen some have been done, too much looks like overkill IMHO
Also i am planing on placing the bits central to the hatchways if possible looks odd the way the instructions want it to go
Hi EJ, what you see is all kit wood and the quality is great. The only wood i am planning on adding myself is to the exposed beams and frames at the end of the build. I am going to add 0.5 x 6mm Lime over each exposed beam and frame then painting them white. This should give me a better finish rather than painting over the exposed ply edges.
Thanks for noticing i had not added the simulated tree nails around the sides of the coamings, i had forgotton to add them
but better to find out now than to remember when the top deck is partially planked
The tree nails are indented and i use this to make the hole, then i use the point of a pencil to darken it and make it slightly wider
Tree nails duly added (thanks to you
The holes are a bit closer in the last photo but the camera angle makes them look more closer than they are.
Thanks guys you seem more concerned than me
It's only wood and i would rather i landed on it than the dog, imagine trying to find the splinters in all that hair
I am already partially through another build i have been doing alongside the Bounty.
Also i am thinking which boat kit to get next probably not another AL because of the quality issues i had with their wood
- Mirabell61, Seventynet and Canute
3
La Couronne by EJ_L - FINISHED - Corel - 1:100 - 1637 Version
Looking at the side of the ship as whole it looks fantastic![:)](https://modelshipworld.com/uploads/emoticons/default_smile.png)
