cobra1951
Everything posted by cobra1951
  1. On the first layer of planks i do nothing with the holes as they will be covered by the second layer. For the second layer i don't use nails, like you i use CA along the full length of the bottom, but not along the edges so it doesn't squeeze out between the planks
  2. Thanks Frank A lot of the time I use push pins on the first planking instead of nails. It stops the planks riding up like they sometimes do on nails
  3. It's a very thick stew First made as it was a cheap way of feeding a family as most stews are. If it's made with no meat and just vegetables it's called blind scouse
  4. Yes there's a fine line with plywood between soaking it long enough to bend and soaking too long so that the layers seperate I always leave it at least 24 hours to dry out then it holds it's shape Looks like you have a nice straight assembly for planking
  5. Yes it's a race proper name is The Indianapolis 500. It's part if the Indy car series of races
  6. Oops sorry to hear that . Empty out your hoover then hoover the floor and check the hoover afterwards. They are probably hiding under the fridge.
  7. Looks great . They sure liked their ships tall way back then.
  8. Very nice EJ . After all that fine delicate work do not knock it off
  9. Hi Mike The nails have been removed what you see in the planking are the holes left after removal
  10. Can you imagine trying to get a modellers carpet through an airport check
  11. Looking down the length of the ship those rails look nice and straight
  12. That's the reason i made my own Bryan, they looked a bit over the top to me but that's just my opinion
