Everything posted by MEDDO
There is probably one somewhere on a a shelf or in a closet someplace.
- 372 replies
The Constitution is in my queue so i will be following along with ya here. I had started this using the LSS practicum but it met an unfortunate accident and I need to try to rehab the hull a bit before starting again. I think someone in the "yellow stripe" thread mentioned something about a pending renovation that might change the number of stern windows. I am interested in what will come.
Yup all of these are going to be sanded down eventually. I think they are there to add "bulk" in the manufacturing/cutting process so there is less risk of accidentally breaking off a point or breaking a thinner piece. Its always easier to take a bit off than to put some back i guess.
- 372 replies
Starting the bow frames. I first roughed them in then dry fitted the lot before setting them in. There is still a bunch of sanding to do. I will let these dry before finishing that step.
- 372 replies
Thanks everyone! This is such a learning experience. I am glad I found this site again. I think looking though so many logs here has helped me with my "right/not-right" eye.
- 372 replies
I just received my copy of The Baltimore Clipper today from amazon. So far it looks very interesting. Will look up the Search for Speed when I get a chance.
Ok, first major mistake! I was looking forward to placing the half frames on the stern area and I kept coming back to the area just posterior to the last full frame. Something didn't add up. After going back to the plans and going over some photos in the practicum I finally noticed what I had done. Apparently when build up the stern post I had switched the 'deadwood' (term used in the practicum) around. Having switched this "around" I had inadvertently left a gap between the deadwood and the rest of the keel. You can see this in my previous photos as well as here. So I used some 91% isopropyl alcohol to soak into the glue joints and was able to debond them. Unfortunately I did break a very small piece of the sternpost off. It was then a simple matter of letting them dry, sanding and fitting the pieces back together. Welp, you live and learn. I think it looks pretty good for a redo. It makes more sense as well.
- 372 replies
Simulated caulking
MEDDO replied to Nirvana's topic in Painting, finishing and weathering products and techniques
For an unstinted deck I have used a pencil on the the edge and for a darker stained deck I used a black sharpie pen on the edge. Both came out pretty well. -
I always thought this would be kinda cool to do, but not sure if there is any place to sail near me.
Very nice build so far. Will be following along, interested to see the rigging go up.
- 188 replies
- constitution
- mamoli
Actually the poly is more for the sides of the frames as once they are installed there is a really small area to work with (only 1/2 cm or so between the frames) if I was to do that later. Also now when I am sanding/fairing the inside and outside of the hull I can see exactly where I have sanded as the poly does sand off nicely. It can be reapplied after fairing and is no problem blending into areas which were previously poly'd. I did just a few passes with the sanding stick on the second frame here and i think you can see in the picture where the poly was sanded off versus the area where it was still present. Oh My! The close up pictures really shows up the gaps and scratches....
- 372 replies
I also have the LSS kit bash Rattlesnake in my queue. I love seeing this. Keep up the great work.
- 974 replies
- rattlesnake
- mamoli
Eventually going to proceed to scratch building. The plan is to do a few kits then maybe heavily bash a kit then move to a Lumberyard timbering set. Eventually moving to a scratch built section then a full scratch build...... (It will take a few years)
- 372 replies
So taking a break for the rest of the night but I will be reading ahead to see about the cant frames.
- 372 replies
First couple of frames placed! Starting to look like a ship! I should be able to get the rest up tonight. Then start the work on the cant frames which are going to be a bit harder I think.
- 372 replies
I know I should of bought all the other ones when I had the chance. Luckily I have a Fair American on the shelf waiting.
- 372 replies
- 372 replies
- 372 replies
I am originally from Baltimore and always loved going to see this ship in the inner harbor. I will be following along with your build
- 116 replies
- constellation
- artesania latina
I have always used old t-shirts for the wipe on poly. (I basically have a lifetime supply from my time in the military). They seem to work great and don't ever produce the "fuzz".
- 137 replies
- finished
- model shipways
I don't have the time to do the wipe-on poly today so I went for the building board. It seems this would be pretty easy but it was more difficult than it looks. BTW I really don't like this material. It produces a ton of dust/dirt/fibers but it seems strong enough.
- 372 replies
