foxy
Everything posted by foxy
  1. Have also this ship, with all sorts of add ons, just need the inspiration lol. Looking forward to your progress.
  2. Now that's looking good Robin. Your getting to grips with it now I see, just to add you do not need a base, will look more realistic with a little glue to the sandle. Great work fella. Frank.
  3. Nice work and very fitting, I assume these are for port and starboard yards, as you know you only need one per side, with a boom ring at each end. Looking good. Frank
  4. Nice work Robin. I to use gloss varnish then matt, as you say for decals it is a must. But better to be sure than later find so many problems. Like the oars and the way you did them. Cheers frank
  5. Great Idea Bob,'why did I not think of that', DuRRR. Well next time I hope to get it right on my Pickle. Frank
  6. That's some fine cooper work Joe matey. She is coming along fine and I am learning lots from this build. Have Pickle to build and the coppering was the main bug bear, but its up an at em. Frank
  7. I to have learnt that its better to remove nails, but will leave some in. Went through 200 on my last wood build,' so won't make that mistake again',(he say's). Nice going Bob matey. Frank
  8. That's usefull Info Robin thanks. Looking foreword to more up dates. Frank
  9. I use a baking tin for my blacking. But Glass sounds good. I have yet to find a good brass chain blackner. Tried the German one, begins with a Z I think, It say;s water down first but found strait from the bottle is best,'well sometimes'. Frank.
  10. Mine to be one of them. The netting you see on my build is from Dafi(Daniel). Its far better than any i have seen in this scale. So go with the flow. Frank.
  11. That's a fine bit of work Robin. I to have other builds, but better to finish the one you started. Looking good and the grey cells are working mate. I have to use an optimizer some times for my work. Keep it coming. frank
  12. Thanks mike. \\\\\\\\\maybe its the pictures that show the wrong size, but have measured them and they do fit the bill. Thanks Bob,Frank and PTS, sorry to shorten your name . Frank
  13. Cheers guy's. Well its been two day's work so far to get the Cutter hung to the davit. One of the shroud cleats came away, but were getting there now. The Port side should be a doddle('He say's') . Some pictures of the cutter. Once shroud cleat(Dafis etch)are tied on, tried just to glue, and it doe's not work, so recommend that you tie them to the shrouds. Frank
  14. Nice one folks. One more picture of the finished Anchors on the Starboard side, tuther side next. Was a bit of a pain tying the main anchor with a few choice words. So Port side should be a doddle('he say's') Frank
  15. 'Hey Daddy', don;t be Grumpy, just hide it . Maybe in Glass Heee. 'But maybe not' . Thanks matey. Frank
  16. Thanks guy's. Well the boats were scratched with just the hulls on two of them and the other two were extended from other boat kits. Well Bob there's lots of different materials on this one lol. Glad you like, with the end in site its nice to put it all together. Frank
  17. Many thanks B.E. Well have left this for some time and it gets buried so quickly. Have now started again with the stern Davits, roped and one side(Starboard) will have a cutter hanging from the davit. Then its the boats now fitted. Jolly boat strapped. The Anchors was next with most done but the Davit and chain on the port side. Some one hiding behind the wheel. frank
  18. Not sure on those hatch covers, prefer the grating type, but it looks effective against the weather. Nice work Bob.. frank
  19. Nice work Bob on the ladder. The orlop looks the better for it. Frank
  20. Now that's a nice way of doing the copper, will have to try that as i have some copper strip. Great Idea's here as usual. Thanks Joe. frank
  21. Yes. cracking job Robin. Nice to see someone else likes a tipple now and then. Frank
  22. Cheer Mike and Bob matey's. Well not really thought on that yet Bob. It will be in a window, so might have to do that. The misses is off across the pond for a month, so I might set down and make one. Been a great experience and still have Victory to finish and Pickle to do. So It will be more to come. Frank
