Posts posted by Kevin Kenny
- GrandpaPhil, FriedClams, mtaylor and 5 others
- 8
That because you live in the developed world with a strong currency. $1 US =$7TT.
so thats $8 US, but we still pay through our nose to get anything here. We have air freight, 20% import tariff and 15% VAT or sales tax. Thats why I usually buy stuff and send it to my daughter in NY and pick it up when i visit, -
Boy
it seems i am going to have to add a few items to the work shop. The Smith little torch looks fantastic and i will consider added it some time this year.
i will buy the US version, my ole motto, if your are going to buy a tool buy the best tool you can afford plus a bit more.
- FriedClams, Bob Cleek and mtaylor
- 3
Yes Bob, i found a mill end .125” and was able to use it in the Cameron drill press to flatten a small section on the post, then a jeweler friend explained that they use a small diamond head round burr to create a slight curve in the flat section, which i then drilled. I was able to drill 22 holes through the post using oil as a lubricant and the drill is still good. This was a great solution as I have no idea when our airports will reopen. The lead time on ordering the resistance solder is also long.
so i am back on schedule.
thanks for all the advice.
I updated it
Decided to try to drill post as i have no idea when our airports will reopen. To my surprise i have been able to drill 4 holes in three post. Difficult as the drill bit tends to wonder as i can punch the post. I used a file to score the post. I do not think the drill bit will last too long but it will be much cheaper than buying the resistance soldering unit which is currently unavailable. Keep you fingers crossed.
Pat
thanks so much for your response. Makes me want to purchase the unit. What do you think i need to buy with the first purchase? I live in Trinidad so its problematic to get stuff. I am also not sure if i can even get to clear the items from the courier service as the country has just implemented a total shut down. The airport is now closed.
Just now, Kevin Kenny said:
I need a stronger joint than varnish would give
- mtaylor, FriedClams, GrandpaPhil and 1 other
- 4
- GrandpaPhil, bruce d and mtaylor
- 3
- GrandpaPhil, mtaylor, druxey and 3 others
- 6
- GrandpaPhil, mtaylor, G.L. and 5 others
- 8
- FriedClams, steamschooner, Moab and 4 others
- 7
Naparima by Kevin Kenny - FINISHED
First bench . Sides made from the hardest wood grown in Guyana ,” Wamara”,
wooden slats are “Juniper”
