Posts posted by Kevin Kenny
- KentM, Jorge Diaz O, AON and 6 others
9
I just like epoxy for major strength pieces. I am a big boat builder and cant get epoxy out of my system. I could have cut it out but the truth is i was able to solve the problem.
- druxey, michael mott, Bob Cleek and 3 others
6
This is an excellent video on building a real life stern assembly.
- thibaultron, mtaylor and reklein
3
Hi Greg
we have huge swings in Humidity which is why i like to use epoxy when ever possible. Having said that i have not had any problems with the 9 models i have built so far. I feel that it is because i dry my wood for at least two years before using.
I had not planned to fill the bottom space between the frames. If you feel it is essential i can still do this with difficulty. My memory of Davids view was that this was optional so i did not plan to add the fillers pieces as the entire model will be planked. His referance is book 1 page 164 3.26. Perhaps what made me not want to do this is that for whatever reason the spaces between the frames were all over the place. It sould have been a real pain. Ill go back and look at Bens post. Assuming that i do not add them i will continue to build the inner limber stakes, the mast steps hooks and the crutch. Then i plan to go to the wale and plank up to the deck. I do not plan to install rib bands as they would be tempory at best.
- mtaylor, EricWilliamMarshall and KentM
3
Thank you for your kind comments Bill. The sole purpose of my videos is to help other modelers and encourage new modelers to take the plung. My modeling skills continue to improve as I take the constant plung into the unknown. Never ceases to amaze me that things that seemed so impossible, end up being so simple when we learn just how to make it. The Sultana is a great model that I know that you will enjoy building. Stick to it.
Best regards
Kevin
- mtaylor, KentM, EricWilliamMarshall and 4 others
7
- KentM, EricWilliamMarshall, mtaylor and 2 others
5
On 1/28/2019 at 12:53 PM, druxey said:
Fixed blocks worked like this:
Greg
i had to edit the video as some how i decided to slide the fixed blocks down between the ribs instead of following the written instruction of pushing it through the hull. Humm, age is a bitch. Anyway i have corrected the video and the blocks now slide in. I assume they had a pin that would hold the entire block in place to prevent everything from sliding out when under load?
- KentM, Jorge Diaz O and mtaylor
3
Restarting the build after taking some time to build th3 America 1851
- bsaylor, Jorge Diaz O, Valeriy V and 7 others
10
The best boards would be near the center of the log.
HMS Thorn by Kevin Kenny - 1:48 scale - Swan-class - David Antscherl practium
Great idea about the knurled screws but they will be almost impossible to find here in Trinidad. I do have washers on the screws. The wood is an extreamly hard wood which i threaded then put CA so it should last a while. I am in New York next month and will try to find the screws.
