Posts posted by iosto
- Mirabell61, mtaylor, Jack12477 and 5 others
- 8
- Mirabell61, rafine, Rustyj and 5 others
- 8
- KenW, Canute, Mirabell61 and 11 others
- 14
- Seventynet, Ryland Craze, rafine and 4 others
- 7
Yes i'll be addìng.Nicely done, Iosto. Will you be adding masts and rigging?
I Made the mast and rigging, i'll assembling it in the next weeks
- Ryland Craze, Canute and mtaylor
- 3
- Mirabell61, hexnut, Chuck and 5 others
- 8
Construction of the base
I wanted to make the base to be set out in the window, in order to have the ship on a slipway site.
I wanted to get an antique effect as some models in museums.I used a wooden base that I covered, cherry wood, with the grain in the central part oriented to the long side, and on the edges perpendicular.
I added a decoration between the two framesI put the tape to leave free areas for bonding.
The finishing was done with shellac- Ryland Craze, GuntherMT, archjofo and 5 others
- 8
- Ryland Craze, hexnut, dvm27 and 5 others
- 8
- Ryland Craze, GuntherMT, Seventynet and 6 others
- 9
Test of of burnishing
I had never used this type of burnishing.
From the evidence I've seen that's not good to leave the piece immersed until the burnishing, but it is best to immerse and then take it off after 20-30 seconds, then go left to air and then rub with a woolen cloth.
after the operation must be repeated 8/9 times to get a good coating.
I had a kind of burnishing that works in one dive, it was given many years ago now is ending and I lost the recipe ....- mtaylor, Seventynet, Canute and 3 others
- 6
- yvesvidal, Ryland Craze, Mirabell61 and 2 others
- 5
Riveting bridge
I tried different techniques to see which one was better.
I made several holes with tips 0.5 / 0.6 / 0.8 mm
I inserted the tip of a graphite pencil in the hole and then I put a bit of glue.
then sanded after this is the effect obtained.
The system toothpicks is great but very long and I did not want to use it. -
Thank You.....I am not sure I understand what photo spars is. Can you clarify? I will certainly help you any way I can.
Chuck
Foto of mainmast and bowsprit.
What kind of finish you used for the hull?
only beeswax or shellac pad?
sorry for my english
but some terms are not easy to translate
thank you
Iosto
Cutter Cheerful by iosto - 1/4" scale
in - Build logs for subjects built 1801 - 1850
Arrangement of anchors.
I used to certain maneuvers of the Alert Cutter documentation.
