Everything posted by Canute
kit review 1:48 HMS Granado ‘Cross Section’
Canute replied to James H's topic in REVIEWS: Model kits
I'd be interested, too. I have one on the way; just biding my time due to my eye issues. Should be good in 6 weeks or so. -
The Chopper in its various iterations works great on thin plastic and wood. I have 3 and like the one Ryland showed, since I can replace the cutting surface. Older ones were more likely to get gouged out under the blade. Cutting much over 1/8 inch thick stock, the razor blade deforms, marring the cut. I've done better with a low sided miter box, in conjunction with a razor saw, to make good standard angle cuts. If you need different angles, you may have to cut those angles into your miter box or make up separate cutting fixtures to cut those special angles. We're all tool junkies to a lesser or a greater degree, but sometimes KISS comes into play, too.
Rye Field Models. After you and, I think it was Craig (CDW), showed their kits, I was sold. Read a few reviews on some armor sites, too. I can do research, just not able to see well enough to do the fine bits and bobs you're working on. Got another month before my first op on right eye, then 2 more weeks for the left one. I'm already cranky from the lockdown and it's too darn cold outside with the wind event we've had going on around here. Most of the white stuff Jack and Denis got up north was a swing and a miss down here. We got a bare inch of mostly slush. It's -2C right now with a wind chill making it -9C.
They also had howitzers which could lob shell and shot. As already stated, fusing was hit or miss, although they preferred air-burst shells for antipersonnel use. For direct fire against attackers, they had grape shot, rather large lead balls. As we neared the American Civil War, case and canister were developed for antipersonnel use, with better fuses. Like General Sherman said, was is hell.
