Cathead
Everything posted by Cathead
  1. With those additional photos I agree and stand corrected; much of that does look platier. I'm not directly familiar with the geology there so the bedrock may be dominated by something like slate that would produce the platier texture. I shouldn't have been quite so definitive based on one photo and apologize for getting ahead of myself. I wonder if some cat litter would be an option; some versions can have a platy texture that might look really good if the grain size is right.
  2. This is a very creative idea! As a geologist with an eye for accuracy, I'll note that gravel landscapes like this should have no sharp edges. Everything is thoroughly rounded by glacial action and overall extreme weathering. If the work shown above is just the sub-landscape you're planning to cover with fine gravel, great; it'll convey some of the underlying terrain's unevenness. But I'd argue that none of the straight-line effects should show clearly through. What you have right now looks rather like a highly weathered granite face full of fractures, but there's no solid rock shown in your reference image. Also, depending on how much you care about accuracy, beware of using products like model railroad ballast for your actual gravel. Most ballast products are angular, because that's how ballast is made (crushed stone), but natural gravel is entirely rounded. Depending on your scale, natural sand (from a creek, beach, or even gardening center or hardware store) would have a much more accurate appearance. But you may or may not be able to source sand in the right grain size...
  3. LOL, that's fantastic! And here I was, looking forward to seeing how you built those itty bitty paddlewheel frames...
  4. Kurt, fair point. To me, and I suspect many modelers, the point at which I sell or dispose of my models is when I can no longer appreciate them. So at that point it's up to the buyer/receiver to decide what's best for them. Maybe the new owner wants a different style of case, or has a pre-existing display setting (like their own curio cabinet). For example, I've had some interest from a local historical society in some of my steamboat models. They wouldn't want them in individual cases, but would rather display them within a casing context they'd develop to fit their display hall. If that were to pan out, any time and money I had spent on custom cases would be a waste, because the new displayer doesn't want them and the custom case probably doesn't easily fit a different model I might later build (and same goes if I tried to sell the empty case to someone). Whereas the curio cabinet is much more flexible in receiving whatever new item I want to put into it, or in being passed along to someone else down the road. Obviously the best approach varies by builder/owner. I just think it's worth putting the idea of the curio cabinet out there, because so many casing question on this forum assume that the only approach is to build/buy individual cases per model.
  5. I agree with Kurt, protecting models is important. Once dust and stuff starts accumulating it's surprisingly hard to get rid of it without damaging the model. But I also agree that individual cases get expensive fast and take up lots of room. My solution was to buy what's commonly called a curio cabinet, in my case from a Mennonite builder, in which I can display quite a lot of models in the same horizontal footprint as one or two individual model cases. I have seven ship/boat models in this one case alone, plus three small nautical-themed models, and still have room left over for some neat natural stuff (rocks, bones, shells, etc.). This was obviously more expensive than any one case, but way more cost-efficient than all the cases I'd otherwise need. I've also been able to adjust shelf heights to match different models, again allowing more efficient displays than single models on their own. And it's quite attractive in the home. The other upside to a curio cabinet is that's more flexible in the long run. A bunch of custom cases have little value beyond your specific model, and if/when you need to downsize, they may end up thrown out. A curio cabinet will hold a lot more resale value as they have a much broader appeal. And you can get them in various sizes depending on your needs.
  6. That's come together really well. When do you add the 3D printed figure of yourself?
  7. That's adorable! Great job on a creative way to do the upswept stern, that's always been hard for me to get right. And I've broken off more than my fair share of wheel supports, so I love the solid plywood version.
  8. Wefalck, you just made me realize the flaw in my suggested arrangement: it's not physically possible for the rudders to be hinged against the hull while the tiller arms rotate on a vertical pivot point set a foot or so further forward, because even an offset of six inches from the rudder hinges to the pivot point would result in too much bending of the tiller arm. All the rotational axes have to be stacked vertically. So yes, either the rudder hinges are set a bit further forward (under the tiller pivots), or the rudder posts have to be hinged against the back wall. Given that many sternwheelers had sterns that curved sharply forward (see again the drawings of Bertrand) it's at least conceivable that the rudder hinges are set forward enough (a bit beneath the stern's overhang) to be directly under a pivot point mounted up behind the engine room wall. It's also pretty conceivable that the rudder posts are (or could be) hinged against the back wall; just because we can't see them doesn't mean they can't be there!
  9. Not really, look at the drawings of Bertrand I posted earlier. You'll see that the wheel supports end just after the axle housing, as they do on Lula.
  10. OK, here's a rough sketch of what I'm proposing. The tiller arms would be controlled by various blocks running tiller ropes up to the wheel in the pilot house. They might even be slaved together with a rod connecting them. It would be easy to arrange the ropes such that the wheel's turning translates into the correct motion of the tiller arms; that's how all steamboats worked.
  11. Again, my alternate guess is that there's a pivot point supporting the tiller arms, just inside the engine room wall where you can't see it. The rudders themselves would have normal gudgeon/pintle attachments to the hull, and the rudder posts themselves are freestanding but supported by their strong connection to the tiller arms, which are supported by a vertical pivot point nearby. The wall openings don't have to be very big because the tiller arms are barely moving there; all the broader arc of movement happens within the engine room along the far extension of the tiller arms. Especially if the pivot point is essentially just behind the wall. To me it makes perfect sense. I can make up a rough drawing if you're having trouble envisioning what I'm saying.
  12. Keith, thinking about steamboats is more fun than the work I'm supposed to be doing, so... Wefalck raises a question I hadn't thought through, which is how the tiller arms are supported in this setup? Are there swiveling hinges/pintles attaching the long rudder posts to the stern wall of the engine room (can't see them in the image due to shadows but can't prove they're not there either)? Or are the tiller arms mounted on a pivot point of some kind just inside the engine room wall? On "normal" steamboats this wouldn't be an issue because the shorter rudder posts would be self-supporting and the tiller arms just extend out from them, like a normal tiller on a sailing vessel. But when those thin posts go up what looks like 7-8', there ends up being a lot more torque at the top and it seems like there would have to be a higher hinge/pintle on the post or a pivot on the arm or else the tops of the posts would twist right off.
  13. Great to see the sawdust begin! As to your question, to me those do indeed look like the rudder posts. As to why they're elevated up there, my best guess is that the compact nature of the superstructure meant that it was simpler to do this than run control lines lower down. On a typical riverboat of the kind I'm familiar with, the vertical rudder posts connect to horizontal tiller arms to which control lines were run from the pilot house using various blocks. Those tiller arms took up a fair amount of horizontal space, which doesn't matter on a large vessel, but certainly would on something as small as Lula. Here are a few examples. On Arabia, a sidewheeler with a single rudder, you can clearly see the long tiller arm requiring a lot of swiveling space, as well as the block linking the tiller arm to the pilot house. Here it's under the main deck, out of the way, but it's not clear if Lula's size or framing would have allow for that approach. Also, in something as small as Lula, crawling into the stern portion of the hull to repair tiller lines sounds awful, as opposed to having them right overhead in the engine room. My photo from the Arabia musuem in Kansas City. On Bertrand, a sternwheeler, there were two tiller arms linked to posts on the two main rudders that in turn each controlled an outboard slave rudder. This was pretty typical of sternwheelers in the era. Here the tiller arms were just above the main deck, where they were easily accessible for repairs, but they did take up a lot of horizontal space at the rear of the engine room. Vessels this size had that space available, again unlike Lula, where this would take up a big chunk of her tiny engine room floor. Images from National Park Service archeology report. So again, it makes sense to me that the tiny Lula would simply extend the rudder posts higher so that the tiller arms and control lines ran just under the ceiling of the engine room, a simple connection to the pilot house immediately above, keeping both the vertical and horizontal components out of the way in the compact engine room. There's probably a bit more torque/stress on those long rudder posts, translating sideways forces down to the rudders, but Lula (as a flatwater tug) probably wasn't subject to the same steering stresses as a riverboat, so I'd guess that didn't matter given the tradeoffs. Those are my thoughts, but would be happy to hear other perspectives!
  14. Keith, please don't eat the completed model. As for the other discussions, I would have agreed with earlier questions about door placement and so on, but I think they've been resolved if it's assumed that primary entrance to the pilot house is from the stern, and the side doors are mostly there for the pilot to step through briefly. I do wonder whether she's a bit stern-heavy as drawn. There's nothing forward balancing the weight of the wheel hanging off the stern, and the boilers which are still sitting aft of center. Maybe the answer is just that she's well-ballasted forward? I realize the original Lula looked like that but she presumably had a small gas engine of some kind, lighter than a coal-fired boiler and its associated stack, and liquid fuel tanks can be placed more flexibly than a coal bin that needs to be near the boilers. Not sure about a head. On riverboats it was common practice to place the head over the wheel so that its natural motion provided waste disposal/dispersal, but I'm not sure in this context. Is this modern enough to have a normal flush head that could be in a corner of any part of the main superstructure?
  15. I hope your "surprise" announcement doesn't undercut sales of everything else, including the newly-released Harpy, as the modeling economy grinds to a halt while everyone waits for next Christmas... You've certainly bent the timeline of my modeling future. MSW's going to have to open a whole new section just for Surprise logs.
  16. If you think enclosed makers more sense but exposed looks better, you can always fall back on the 'ol "repair scene" trick. Make one side of the enclosure solid and have the other one in the process of being re-sided with new planking or something. You could even hang a rolled-up tarp above the opening or something to imply that they're trying to keep it protected until repairs are made but just at the moment the model is frozen in time, the tarp happens to be open. Or some narrative along those lines. Also, would enclosing the boiler in a simple wooden structure really make a significant difference in its performance? Serious question, I don't know the answer. Intuitively it seems like it wouldn't, really, but I don't know. I can see the argument for an enclosure protecting the metal from corrosive salt spray, though.
  17. I've got nothing intelligent or helpful to add, other than to repeat the chorus that your builds & their research are fascinating and allow me to dabble in fields far from my own knowledge! Thanks for taking the time to write up your work for us.
  18. I'm back after a few weeks away from MSW and you pose a good question regarding water supply. I've only ever researched inland river steamers and have no idea how brackish water changes the equation or how all the various coastal harbor and river steamers (such as on the lower Hudson) handled that. As for placement of the funnel/chimney in front of the pilot house, it may be an accident of vessel design. On riverboats, the boilers tended to be relatively near the bow, both to the balance the weight of the engines and paddle wheels further aft, and to help provide draft without being blocked by superstructure. As the pilothouse on riverboats also needed to be near the bow for visibility, it generally ended up being placed more or less over the boilers, meaning the chimneys ended up in front of the pilothouse. Not as big a deal on a normal two-chimney riverboat but a bit awkward with just one. But the rest of the design requirements pretty much force a single chimney to stay there. I don't know much about regular coastal vessel design, such as the one Jim Lad showed on Oct 18, but I'd guess you still run into similar constraints in that there are only certain places that boilers/engines can go so sometimes you end up with a pilothouse in an awkward place if there are other reasons not to put it elsewhere. Personally, your fridge saga has been great for me since there's not so much to catch up on in this build!
  19. Late to the party as I've been offline for a while, and I'm not sure how to add praise without duplicating what's already been well said, but what a fantastic and interesting project to follow!
  20. Yes, if it were up to me, and no other evidence surfaces to show otherwise, I would definitely not offset the stack to either side. The New Era's stack is centered, it's just an optical illusion of the photo's perspective and the vessel's design that makes it look off-center. Though you could always decide it's a distant ancestor of the German BV141, definitely one of the more mind-bending aircraft I've ever seen with its offset cockpit and fuselage. My understanding is that it actually flew quite well but was just too weird to be taken seriously.
  21. Ian and Gary, in every photo I posted, the single stacks are centered. This makes sense to me as otherwise you have a serious offset weight that would destabilize the vessel.
  22. Even though we've discussed this prototype before, the single-stack forward question hadn't registered in my mind until now. It would definitely be a bit of a view block, though fair question is how much and does it really matter. I don't have a lot of time to descend rabbit holes right now, but in a semi-brief search through resources and imagery I confirmed that the predominant location of a single stack was behind the pilothouse, as in this very attractive example of the Suzie Hazard (UW La Crosse collection) : But I was also able to find a variety of steam ferries with single stacks right in front of the pilothouse. The New Era, from this steamboats.com article. One interesting detail here that you could choose to replicate: look closely at the pilothouse and you'll see that the wheel appears to be offset to the starboard side, allowing a clear view forward. And I found several Missouri River examples, which excited me. Here's Dorothy, built in Boonville (not far from me) from the UW La Crosse collection: And here she is renamed as Helen and somewhat altered, but the same vessel (from the UW La Crosse collection) : And another Missouri River example, the Henry Wohlt out of Hermann (also from the UW La Crosse collection) : None of these are quite what you're envisioning, with the boilers and stack well forward with more separation from the pilothouse. But they do give you some justification for saying that, at least in a few cases, builders and pilots were ok with that view block being forward. So I think you could go for it. I won't be able to give this build much attention for a few weeks, which makes me sad, but hopefully others can help out as well with ideas and input. This will be so fun to watch come together! EDITED later to remove the $@%! emojis MSW insisted on auto-adding whenever there was a colon after a ). I did not intend to convey a sad face after every steamboat listing.
  23. Absolutely wonderful! Not sure I have novel words to add after all the others got there first. These obscure unique projects are my favorite on MSW and you've really added to the genre here. I'm glad you anticipated my vote and went for the Lula.
