Everything posted by Cathead
Looks great! Definitely a very fun "model" to build. Trying to decide if we'll have the guts one year to tear it down and do it all over again!
Keith, I look forward to your adventures attempting to hand-make that spittoon on the floor by the stove. My vote is for plain wooden flooring. It's something the viewer "expects" to see and so fits nicely with the overall aesthetic.
- 732 replies
- Lula
- sternwheeler
Woe, woe, the mighty Keith has been defeated. All ye rend clothing in despair!
- 732 replies
- Lula
- sternwheeler
I don't know that there would be all that much smoke and fumes (noise, on the other hand...). Vessels like this used tall chimneys to carry away smoke and create sufficient draft for the firebox. I have no knowledge of whether there might have been gratings, but most of these boats (likely including original Lula) were so lightly built that there wouldn't be anything between the pilothouse floor and whatever's below other than some thin oak or pine planks. I'd go with the assumption, suggested by others, that there were steam pipes/radiators run up from the boiler immediately below, especially given the configuration you're using. Possibly with some kind of shut-of valve since the last thing you want in July is a hot radiator up there! Whatever boiler heat passes up there in winter, also passes up there in summer!
- 732 replies
- Lula
- sternwheeler
Lynn, thanks for your interest. I'm not currently working on a nautical model, taking a break from that to work on a model railroad project. Not one I'm writing up on MSW for now, though every now and then I get the itch to share, though I also enjoy the break from having to photograph and write up everything.
Great improvement! One subtle detail for the rest of the deadeyes: in the triangular pattern of holes, the "triangle" should be upside down, with two holes even across the top and the single one at the bottom. Lots of people don't realize this and put the deadeyes in any which way. It's the kind of detail only pedantic people notice, but it will make rigging a bit easier to have the holes oriented properly and reduce lines tangling or crossing over one another. The opposite is true for the deadeye that will eventually connect to this one. See this diagram posted elsewhere on MSW.
Great answer, Keith, that's exactly why I phrased it as a design question rather than a "you did it wrong" question. And I had entirely forgotten about those boxes along the walls. Thanks for indulging me.
- 732 replies
- Lula
- sternwheeler
Keith, great to see you getting "a head" on this model... Question about the engine maintenance doors: I'm curious why you chose vertical ones rather than the horizontal hatches common on many steamboats (since they provide full lengthwise access along the engines' horizontal extent in tight spaces). Not implying you should re-do it, just legitimately interested in the design discussion. See below drawing of Bertrand for an example of what I mean. And it just occurred to me that you could still add a version of these forward of each vertical door, if you wanted. Would add even more visual interest to the engine room walls.
- 732 replies
- Lula
- sternwheeler
Not just a long-ago problem. I based my 1850s steamboat Arabia in part on a modern painting of the vessel (artist's interpretation since no contemporary images exist), and while the guy is a wonderful historic artist, he's not a steamboat expert and there are a few blatant errors including one almost M.C. Escher level one that can't work in the real world even though it looks nice on canvas. All part of the fun of recreating history from art!
Keith, you owe me a new thesaurus, mine broke when I tried to come up with proper new praise for your work.
- 732 replies
- Lula
- sternwheeler
I prefer sternwheelers too. Three of my four steamboat builds have been sternwheelers and the only exception was because Arabia was too good a local project to pass up.
- 732 replies
- Lula
- sternwheeler
I should be used to your standard of work by now, but my jaw literally dropped when I saw that wheel. Better than any I've ever built and in a much smaller scale. Just fantastic.
- 732 replies
- Lula
- sternwheeler
I can't tell what you're showing in photo 2, so have no way to answer whether that item has a hole in it or whether it would work. I assume it's some kind of after-market product you found online? More context would really help with offering advice. As a broader answer, this kit makes a nice-looking model but it isn't even remotely accurate as a scale model of a Mississippi riverboat. So you're free to choose whatever visual theme looks best to you, and if you like the look of the item in photo 2, you should feel free to use it (assuming it's physically capable of the role).
Ugh, so sorry to hear of your rotten health luck lately. I'm sure the "bum wing" doesn't make caregiving any easier. Hang in there, even one-armed, and look forward to better days soon.
- 732 replies
- Lula
- sternwheeler
I agree with the other suggestions above: make sure you're done working with the metal piece, clean it well and handle it carefully, abrade the surface, and consider using a primer first. The biggest difference I've seen with Model Shipways paint vs. other brands is the former tends to be much thicker. This isn't necessarily bad, for example it makes a solid coat on things like metal and plastic when using a brush, where thinner paints sometimes don't coat easily. I'd also suggest, as in so many cases, practicing on some scrap material first to see what methods produce the best result. Brass blackening agents work very well, and I've also had success using a blackener followed by a coat of paint. But a warning: blackeners are fairly strong chemical agents and they will produce fumes; not something to use lightly in your living room or a confined workspace. Consider doing blackening in a garage or outdoors setting where the fumes can dissipate while you're not around. I've gotten multiple headaches from being around blackening fumes even for a short time.
We've finished ours, and it's been really cool to see how Lego has adapted so many pieces from other kits to produce surprisingly good feature on this one. There are a lot of really well thought-out details.
Lynn, a trick I sometimes use when trying to drill a difficult hole, is to drill a small pilot hole with a much smaller bit and then follow up with the actual larger bit. What this does is help guide the real bit not to jump or skate around as you get started. The tiny bit is easier to hold in place as it gets going. You can also try making a dimple in the material with some kind of sharp object (like a nail) that will also help hold the bit's tip in place while it gets started. It's easier to "punch" a dimple into metal than it is to get a spinning drill bit to stay exactly where it's put on a smooth surface. This is even helpful when combined with the small pilot hole trick.
Keith, I love that re-pairing of the model's status and the original photo. Shows how well you're adapting the original design to your own vision. Just awesome.
- 732 replies
- Lula
- sternwheeler
