Posts posted by kostas_gr
final touch, the flag. I have used the one provided from Corel. I used whote glue to make the folds
- BobG, mort stoll and Ryland Craze
- 3
Corel's kit comes out without sails. I thought that sails will look nice on this build.
I believe that rigging makes model to look more pretty.
I decided to use silk fibre. First step was to dye the fibre to get darker, I decided to use coffee or tes.
I made several tests with both and finally decided to leave it around 15 minutes into coffee solute. (on the left side is the original fibre)
For the fist sail I had to remaike it 4 times due to several issues I will describe
first try ....while cutting the sail, the edge was unravelling so i have decided to use diluted white glue to make it more stable until I sew on the edges.
Second try.... (with white glue on the edges) after sewing the side edges the outcome was miserable, it was stiff and almost impossilbe to handle I couldnt manage give a right shape
Third try... I found a thin sewing tape that I have placed on the edges so with normal ironing the tape was melting with a very thin film and kept the edges folded. I was Suprised with the outcome and made sewing very easy. But... unfortunally the length shortened a lot and the sail looked very small on yard.
forth time was a charm, the outcome was overall so I decided to use them. To be honest I didnt have much time or mood to test other fibres, I had a deadline due to the anual IPMS competition I wanted to participate.
- Mirabell61 and BobG
- 2
- KARAVOKIRIS, Prowler901, GrandpaPhil and 1 other
- 4
crates are in place, worinkg on upper deck
for deck planking I have choosen the "rule of 4", using 10cm planks. But unfortunately I couldnt avoid mistakesand had to redo some planks
almost done, the new planks are few tones brighter than the old ones, I guess I ll have to wait to see how are they look after oiling
deck planks were cut in 10 cm each and the caulking was made with soft black pencil.
I have marked the deck with parallel squares just to ensure the right positioning of the deck planks. In some occasions I have to make micro adjustments to keep them in a straight line
always planking from center toward sides
Half done
need some sanding, caulking looking good for this scale (1:98) will be darker when oil is applied
with half deck oiled the difference is obvious!!!
Along with victory cross section, that is almost done, the time has come to start HMS Victory.
Corel's kit is a bit old (at least the one I have) and probably I will have to make a lot of improvements/modifications
while building the hull, I have noticed that many parts did not fit very well, hull beams are looking quite old and dry
I had to fill the gaps almost in every hull beam
15 hours ago, Lt. Biggles said:
Bet you are a little bit happy you don’t have to rig the entire ship!! Looks great!
So true!!!
but to be honest I got already Corel HMS Victory waiting to get built....
- KARAVOKIRIS, ccoyle and wlell
- 3
- Matt D, BLACK VIKING and Osmosis
- 3
2 hours ago, Lt. Biggles said:
Looks amazing! A great perspective of how big she is!
looks like you picked a very busy slice of the ship to replicate too!
It is Corel's HMS Victory cross section kit 1:98, with modifications and improvements
HMS Victory by kostas_gr - FINISHED - Corel - 1:98 Scale - cross-section
thank you Steve, the build is completed I have few photos left to post. I hope you to enjoy the details I have added in the cargohold
