amateur
Everything posted by amateur
  1. Next were the golden parts on the side galleries: The white stuff you can see here is not filler, it is the glue I used. I used kind of gap filling, montage kit. slow curing, remaining a bit elastic. As the fit of many of the metal parts was lousy, this gap filling stuff worked fine with me (especially, while the stuf can be easily cut with a knife when dry) On this pic, you can see a second change I made to the kit: part of the smaller ports in the hull were assumed to be gunports by Corel. However, on the ketting drawing there is no deck behind it (at least not at such a level that a gun could be placed at the port) Ketting assumes that these ports are just for ventilation/light. I decided to keep these ports closed. So they were not actually made as ports, they were just cut into the planks, using a small chisel.
  2. I'll try to give you a short reminder of what she looked before the pic above. I started her as early as the year 2000. (birthday present from my wife, which I told her would do for about four birthdays ) I had the book of Ketting onthe PW in my posession a long time before 2000. So I decided at the start that I would follow the kit, but would try to make some adjustments to get her more in line with the drawings in Ketting. I did this in a more or less informal way: a look at the Coreldrawing, a look at the book, and make something taht looked OK. Over the years, I discovered that I should have planned these adjustments a bit more carefully, as I had some repairs, adjustmants and changes to make which could have been avoided if the changes had been more carefully planned. I bought my first digital camera in 2007, so the first I can show you, is how she looked then. Although not complettely in focus, you can see the first change I made to the kit: I changed the size and position of the gunports: Corel positions them right between the wales over the full length of the ship, Ketting shows the more usual run for Durtch ships: the sheer of the wales being larger that the curvature of the deck, so the aftermost ports do get into the wales. (Later I realized I should have done so with the round ports at the upper deck, also. Too late to change them now.) Finally, something I did not change, but should have done: Corel makes the width of the high stern too large: the lower end has the correct width, the upper deck (and thus the width of the stern) should have been considerably smaller. You can see that there is much filler between the golden pieces, and some bare, grey metal showing. This is because the quality of the castings was not to good. So some action was needed to get things fitted to the stern. I had deceided to paint the whole thing, even before I discovered these problems. (That's why you can see red in the gunports, and white on the hull (which I discovered afterwards, should have been a couple of milimeter's higher up, but again: too late for that now
  3. Thisis how she was, one and a half year ago. And to be honest, she is sitting on the table next to me, and I don't see much of a difference More will follow soon. Jan
  4. I once had a build log of my Prins Willem here on MSW. I also had a backup of it on my PC. Some months ago I deleted that one.... I wish I hadn't done so I will try to recreate some of it over the next weekends. Perhaps that will give me some inspiration to continue her rigging, as I haven't done much over that last months. Jan
