amateur
Everything posted by amateur
  1. Hi Ed, I can sit still and watch these pics for hours. It makes me wonder where all the trees grew in the time of those sailing ships.... I see some blue tape in the rear end of the ship. Why didn't you attach those timbers along the full length of the hull before starting your deck-framing? Jan
  2. Woulnd't have though of that, not in years..... Jan
  3. After being finished, it will take to the sea, and head straight to Den Helder, where it belongs at the Dutch U-boat base Making a video is probably the best way to show both detail and size of this wonderfull model. btw: Will your fathers name be somewhere on the model? Jan
  4. And today I did the othger side. Ratlines finally finished. I secured the knots with white PVA (diluted), but as that is still drying, I did not snip off the ends. Studying the rigging plan I discovered that two clamps on the bowsprit would be too few. So: destruction in a mild way, and replacement by four new ones. As there will ben loads of rigging line onto them , I didn't pay too much attention to the fact that they are not equal shaped. (and besides: the difference is below 1 mm) And here the first part of the crowsfeet on the main mast. The block is made from a strip of wallnut 3x2 mm, about 1 cm long. Problem is the same as usual with these "add-ons" to the stays: the rope with with the block is stropped has some resistance, so forcing the block into the right direction by tensioning the crowsfeet, results in a kink in the main stay (which is already is under some tension, so there is still some thinking to do....) Jan
  5. I'm still looking for the 'bad news', but apparently, this is not it. I just finished my ratlines today, I'm nog envying you at this scale, and at your level of perfection. Jan
  6. Nice colour of the ratlines! Are you sure the last (=leftmost) shroud is straight? Jan
  7. It gives a nice idea on the sizxe of the model, and the increadible detail. Fully rigged hooks the size of a ladybird... Jan
  8. I know, but you'll probably have to wait over 24 hours if he confirms..... (I don't know whether or not I will be next to my PC tomorrow) So if he confirms, mine is already there, if he doesn't (which I seriously doubt, given his clues), ignore my previous post Jan
  9. Then I give you the next one Slightly different type of ship I took the liberty to edit out both flags and name.... Jan
  10. Polyphemus was the cyclops that Odysee came across on one of his journeys. Jan
  11. Homer never met those Martians. And actually, the connection wioth Jasons Cyclops isn't that loose Jan
  12. So far the good news. What's the better news? Destruction again?? Jan
  13. There was a torpedoboat in War of the Worlds, but.....that's not the one you're after, as there wasn't made a picture of her (yet ) Jan
  14. Llittle green men from outer space are coming..... Jan
  15. Nautilus?? Jan
  16. something austro-hungarian, perhaps? Torpedoboat?? Although, I can't quite understand the use of those 'sidewings(?) on the hull. Stability? Jan
  17. You can just copy-past the URL from photo-bucket. Relatively quickly.... Isn't the main sail very small compared to the ship's size? Jan
  18. does that mean submarine tender? Jan
  19. She seems to have a massive search-light up front.... Jan
  20. Did some ratlines this weekend. Ratlines almost done by now, just the other side of the mizzen to do...... Jan
  21. Your source is wrong. This is definitely the Aurora Jan
  22. I'm pretty sure it's aurora.... Potemkin (the 'mutiny'-one) was a battleship, with much heavier superstructure Jan
  23. Interesting one. You don't see these ships modelled too often. Why do you date her 1942? As far as I know she was build 1937. 19/2 was her first action in combat. I guess you kow this one: http://www.maritiemdigitaal.nl/index.cfm?event=search.getsimplesearch&database=ChoiceMardig&needimages=true&searchterm=tromp%201937&allfields=&title=&keyword=&creator=&collection=&shipname=&invno=&museum=&startrow=1 and some pics here http://www.maritiemdigitaal.nl/index.cfm?event=search.getsimplesearch&database=ChoiceMardig&needimages=true&searchterm=1942%20tromp&allfields=&title=&keyword=&creator=&collection=&shipname=&invno=&museum=&startrow=1 Problem is: I don't know whether this is the Bofors you need.... http://www.maritiemdigitaal.nl/index.cfm?event=search.getsimplesearch&saveToHistory=1&database=ChoiceMardig&needImages=YES&searchterm=bofors+tromp Jan
  24. I would call it a major milestone.... it looks fabulous. Jan
