kurtvd19
7 Followers
About kurtvd19
  • Gender
  • Location
    Far West Chicago Suburbs
12,310 profile views
  1. Jim: Looks great! I always use an airbrush so the fine details can be seen and not hidden by thick paint. Long ago I was very good with brushing paint onto my 1/25 scale cars but I lusted after an airbrush. Got my first airbrush for Christmas when I was in 8th grade (1960). I had a great uncle who modeled HO railroad stuff and his brass locomotives where my inspiration for airbrushing. When HO scale rivets are not hidden under paint the results are great so I figured if I could paint my model cars using an airbrush my finishes would be much closer to scale thickness and would show the details others hid under paint. Remember the time period I am referring to. When I see people using brushed on paint today and if they ask my advice I tell them to get a decent airbrush and learn to use it. Airbrushing can make such an improvement in the finish of the model. But, one must practice like anything else and that seems to be something so many just can't seem to do. Take care, Kurt
  2. Richard: I believe that Liver of Sulfur works on copper but not on brass - no personal experience with Liver of Sulfur, so I may be wrong. I use Birchwood Casey Brass Black but there are other solutions for blackening brass available (Blue Jacket is one source). I first clean and then pickle the brass part in heated Sparex 2 till shiny and then thoroughly rinse with water. I dilute the Brass Black solution up to 50-50 and immerse the part in the solution for a short time - 15 to 30 seconds - and then lift the part out of the solution with tweezers to check the blackening process. Repeat as many times as necessary to get a good black color agitating the solution often. Do not leave the part in the Brass Black solution for an extended time w/o checking the progress of the blackening as a crust can develop that will need to be removed with unacceptable results underneath requiring one to start over. When blackened to your liking rinse thoroughly under running water and I then give the part a short rinse in distilled water and let the part air dry. When dry take a cloth like an old t-shirt and lightly buff the part. Some of the blackening will come off on the cloth and if you don't rub too much or too long the part will be a satin finish ready for display. If a flat finish is desired use an airbrushed flat finish. I hope this is helpful, Kurt
  3. BYRNES – MODEL MACHINES - ROPE WALK This machine is complete with Instructions, extra Take-up Reels, Belts, Centering Dies and Feed Spools. Used but not abused. Available for $300 or Best Offer. Will package and ship for the cost of shipping – will provide quotes for USPS, UPS and FED-X – you pick the shipper. Located 26 miles west of Chicago if you want to pick it up. Reply here if interested. Not my photo - from instructions.
  4. Richard: I switched to Stay-Brite solder at Ken's urging when I quit making radio control boats where the strength was needed to resist the action of water against the rudder and in control arms controlling rudders to turn. Some shafts required strength - like the rudder shaft. There is nothing on a static ship model that requires the strength of silver solder. Stay-Brite is a high silver content solder so it blackens nicely using various blackening agents just like regular silver solder. With the various attachments you had to make on the ram, silver solder might still have been necessary but I would have tried Stay-Brite and some heat sinks just for the ease of not messing with silver solder. Since switching to Stay-Brite and using Yyllow ochre (again from Ken) I find it so much easier and a lot less cleaning up of excess solder. The ram will not be left as bare brass so fillets could be made with any type of filler. I am sure you will find Ken's book well worth the cost. Take care, Kurt
  5. Eric: I hope you made a note of the colors used for the mixture to get the color in case it is needed later to match a repair. I am assuming your text mention of "mix" refers to the finished color but realize it could refer to the mix of colors on the building as a whole. I have found that keeping a record of paints used on any build is a good idea for later reference of what color was used for a particular build or part. Kurt
  6. Harbor Freight sells this saw for about 1/3 or 1/4 of the cost of the Micro Mark version - from the same mfg. Identical except labels - the last time I compared them. I purchased my say several years ago thinking if it got me through the project I was working on with a delivery deadline it was worth it - the tool would pay for itself. I completed the job on time and I still have this little workhorse and it's now at least 10 years old. If it ever dies, I will replace it with another from HF.
  7. They are an exact copy - ripped off after they were selling the original choppers - stopped ordering from NWSL and substituted their ripped off copies. Not the only instance of copying by MM.
  8. NW Short line is the OEM for the Chopper I, II and III Have a Chopper I for at least 25 years. When the base gets a groove from use, I fill the groove with epoxy and level it - good for another 5 years.
  9. Brian: Congratulations on completing a very beautiful model. River towboats are my favorite subject to model and I have been very happy to follow your build. Take care, Kurt
  10. I highly recommend that the paint manufacturers instructions be followed regarding thinning and only use the recommended thinner. There are way too many suggested alternatives floating around. You don't want to risk your time and effort in building a model to be ruined by an incompatible paint/thinner combination being used. Always test your paint/thinner application on an identical material before committing to your model. I highly recommend airbrushing for best appearances - an airbrush with the proper paint selection provides a scale like appearance much better than a paint brush. A properly thinned paint from an airbrush provides a near scale thickness of paint to the subject. An additional coat of paint just like in real life may be needed to cover thoroughly with much less chance of obscuring details. Take care, Kurt
  11. I understand that all contestant's have received their judges evaluation sheets. Also, as to a earlier question of showing the non-winning entries it was decided not to show them. Kurt
  12. Richard: Yellow Ochre powder can be mixed with water or alcohol and "Painted" onto the surfaces where you do not want solder to flow onto during soldering operations. Let it dry and then apply your flux and solder the part. I always use alcohol because the alcohol / yellow ochre solution dries much quicker than when water is used. Yellow Ochre is a flux repellent and where the flux won't go neither will the solder. The solution can be kept in a small jar or other lidded container and if it dries between uses just add water or alcohol to make it liquid again. This will greatly reduce the amount of clean up needed after soldering. I learned about this from Ken Foran's book Modeling With Brass - the 2nd edition has an added section on ship modeling using brass. In my opinion this book belongs in every serious modelers collection - but only after it has been read cover to cover. Take care, Kurt
  13. I was referring to the lack of free-board. A decent wave would have swamped the ship. I have seen photos of lumber boats on the Great Lakes loaded even higher and there are a lot of them on the bottom to prove they loaded it too high this time.
