Everything posted by kurtvd19
Font Size
kurtvd19 replied to DHS's topic in Using the MSW forum - **NO MODELING CONTENT IN THIS SUB-FORUM**
YES. When you compose a message there is a tool bar at the top - directly above your text. Size is for the size of the font. Font can change the font. Just highlight the text you imported and click Size and then pick the size you want. You can also do this when you start to type and the new font and/or size will be used for the message. -
Congratulations on finishing the project Eric. I am especially pleased to read your evaluation of the Guild's efforts in developing this project and your opinion that we achieved our goal of getting members to try scratch building and you confirmed our opinion that this project would be satisfying the those who undertake the project. Take care.
3d printing crew figures
kurtvd19 replied to highlanderburial's topic in 3D-Printing and Laser-Cutting.
I just attended my local IPMS club meeting - virtual yet - and a guy showed a figure of a Scottish warrior who had plaid pants on - what a paint job it was just on the pants. Hand painted of course and he said it took three tries to do them. The rest was just as impressive. -
Steamboats and other rivercraft - general discussion
kurtvd19 replied to Cathead's topic in Nautical/Naval History
Eric: Don't worry about it. I agree with both Randy and you. But I don't consider my time wasted at all. I know I will need to take things he said with a bit of skepticism but I found several things I found interesting and will do some checking into them as time permits. Those who had little to no knowledge might have been inspired to check things out further and the stuff he got wrong will be discovered if they check things out further. And for those who just enjoyed it as alternative to the Olympics on TV they were better entertained.- 281 replies
- Steamboats
- riverboats
(and 3 more)
Air brush vs paint & brush
kurtvd19 replied to jefferyt's topic in Painting, finishing and weathering products and techniques
I belong to a local IPMS chapter though I seldom build plastic models. We just had one of the founding members of our chapter pass away. He built airplanes and never used an airbrush. He won many awards at IPMS contests and when people found out he didn't use an airbrush they didn't believe it. His models stood up under close scrutiny at these contests so he was competing against expert airbrush users. A brush in the hands of an expert can produce a great finish just as an airbrush can produce a bad paint job in the hands of somebody who never practices. Both depend on the skill of the user to produce a great paint job. In my opinion it is easier to accomplish with an airbrush but only after a lot of practice - but a lot less than with a brush. -
Thanks Eric I will attend- 281 replies
- Steamboats
- riverboats
(and 3 more)
Jeff: Is the rigging line supplied still from Morope? That was what was originally supplied with the kit. Until Chuck made his rope available the Morope was the best on the market in my opinion. Kurt
- 42 replies
- lively of baltimore
- lumberyard
Three inches is the rule for shop table saws. But I mention it so people will think about it. How do I keep 3 inches away? I can't. So I will keep my fingers as far away as possible. The need to keep a good distance away is for when the saw is running. The adjusting screw is closer than 3 inches - I sure hope you don't try to adjust the blade height with the Preac running.😎 There is a tape sold by FastCap meant for Miter Saws that is put in place and the blade is turned on and to cut through the tape It's sturdier than the blue tape and is 16" long - 5 pieces for $6.66. Fastcap.com made for the big saws, but if it can be done with a big saw we can do it with our small saws - ,just scale things down. This looks like it will be usable on our saws - I am going to order some to test it.
Multiple applications will probably be needed. Keep it wet - don't let it dry or you will need to start all over. Have something under the piece to catch run off - don't let it ruin something it drips on. Some have used tissue to keep the area wet - applying more to the tissue so the underlying part is kept wet. Test occasionally and when soft do what works best to remove the excess. Repeat as needed.
What they are describing is how to remove epoxy type glues. One can use epoxy on wood so it can be a wood glue but ordinarily the term "wood glues" mean the white or yellow glues such as Titebond, Elmer's etc. Gorilla glue is a poly vinyl acetate glue (PVA) as are the Titebond glues. The Isopropyl alcohol works well on PVA glues. I have never use Gorilla glue on a model and would not use it due to it's foaming charistic - that may have caused your problem.
The common solvent for the white or yellow wood glues is Isopropyl Alcohol - you probably have some in your medicine cabinet. If you go to the drug store try to get the 90% stuff - whatever you get, go for the highest % you can obtain. The 90% costs more than the common medicine cabinet variety but it works a lot better and it's still quite affordable - just remember to put the cap on tightly between uses.
They are Bob Smith. Smith prints the customers name on the bottles. Best CA available.
Eric: As the bevels on the carlings are not seen you might make neater joints by making the ends of the carlings square and the pocket in the deck beam square. I can tell you from personal experience that I made the joints in the beams and carlings that way when this project was in the prototype stage. The one thing I did to the end of the carlings was to break the bottom end of the carling so that any wood left in the bottom of the deck beam pocket would not interfere with the bottom of the carling seating square. The left end of the carling shown in your photo will also work to be an easier fit - and the whole darn thing is hidden so make it easy on yourself. Also, it is easier to fit the pocket to the carling as you can sneak up on the fit - start with the pocket a bit undersized and slowly make it larger to fit the carling tightly. That's what the furniture makers do.
Shortly before Alan died he talked to myself and two other individuals about working together to update both books. Unfortunately I am the youngster in the group and by far the junior when it comes to actual knowledge on the subjects. Neither of the others wanted to get tied up in such a project and I just do not have the knowledge to do the job. I have the publishing and distribution contact - the NRG - but alas I don't see that there will ever be an update done. I know that by making the existence of the books better known and being able to get them published we would sell a lot more than 3 copies a year!
KIT REVIEW – USCG HARRIET LANE MODEL SHIPWAYS KIT #MS2270 Scale 1:96 (1/8' = 1'0") Length (overall) 28", Width 8", height (on base) 16" Plank on Bulkhead construction This kit is the fourth in a series of progressive model tutorials by David Antscherl for Model Shipways (Division of Model Expo) with the Lowell Grand Banks Dory, the Norwegian Sailing Pram and the Muscongus Bay Lobster Smack being the three previous models. All have been reviewed here. The kit comes in the usual sturdy blue box with a large color label showing a completed model. The box weighs just ounces less than 5 pounds. Upon opening the box, the plans are the first thing seen. There are five sheets of 18" x 36" plans labeled as Deck, Rigging, Sail and two sheets labeled as Rigging and Laser Cut Board Parts Identifier sheet (A-L) and (M-Y). The box also contains the following: Sixty-six page full-color instruction manual Twenty-two sheets of laser cut Basswood Three sheets of laser cut paper card Seven pieces - strip Basswood Three wood dowels Six rigging line spools Five packs of blocks Eighteen different Britannia castings – multiple pieces of several parts One sheet of Photo Etch Brass Misc. Brass and other parts Parts list – 3 pages The sixty-six-page full color instruction manual is well done. Before any assembly is started it is my recommendation that the modeler should read every word of the instructions before doing any assembly. The first page of the instructions cautions the reader in red print to read the instructions. There are numerous tips for the modeler designed to guide to building this or any other models. Tips are printed in red to help the modeler. There are also "Super Detail" tips throughout that provide ways to improve the accuracy of the model. The most important tip is "Take your time". There are hints throughout the instructions printed in red to catch the attention of the builder. Read them. Most tips will help with this kit and some of them will help in the future with any kit. Planking Sheets Planking is supplied slightly oversized but to the correct shape for the location intended. Adequate extra material is provided on the width of the parts to sand to fit. The other 18 sheets of laser cut wood Three Laser Cut Paper Sheets 5 1/2" x 8" x 0.0095 Photo Etch Brass Box of Cast Metal Pieces, Rigging Material, Flags & Wire Ladders, Anchors, Canons, Davits, Ventilators Belaying Pins, Eyebolts, Wire & Brass Rod Windlass, Cleats, Eyebolts, Chain Flag and Rings Blocks Rigging Line Rigging – in progress photo – Courtesy of David Antscherl Parts List – 3 pages and US to Metric Conversion sheet Overall, I think this is a great kit with good cast parts and laser cutting of the wood is very well done. The laser cut pre-spiled planking is a nice feature and will help most modelers produce a good planking job. The good instructions and plan sheets should leave nothing to be guessed at. The rigging line is very good quality. The blocks are decent quality for the size, but they are the typical kit supplied blocks with square edges so finicky modelers may look for replacement blocks. Thanks to David Antscherl for providing photographs of the finished model. Thanks to Model Shipways (division of Model Expo) for supplying the review kit.
I recently started to watch a YouTube video about saw safety and stopped the video after about 30 seconds when the guy went to the saw with an open button up sweater with long sleeves AND a tie! At that point I stopped viewing the video because I figure that anybody who wears long sleeves and a tie while using a table saw is a certifiable idiot. YouTube has some excellent informational videos but also some that are pure BS.
