kurtvd19
Everything posted by kurtvd19
  1. Here is an example of the Krylon Gold Foil paint on a whitte metal casting from the Steam Pumper that Ken Foran designed for Model Expo. This was done with the rattle can. The white metal casting was cleaned up a bit and then primed with Badger STYNLREZ white primer. I can say with confidence that one can't tell this apart from a plated piece. Kurt
  2. Jerry: The Krylon foil paints are great - also got the tip to use them from Ken Foran. I have decanted them from the spray can to use in my airbrushes and they are great that way too - better control than by the spray can. I did use some decanted foil paint with a brush to touch up some small areas on a build and it worked OK for that too. I don't know how it would be applied by brush to a larger area though. One point on these paints - they are to be applied over a white primer undercoat. I think it's more for the color than the sticking to the subject. Kurt
  3. Ken: It's looking good. When you do up the gun tackles consider making a jig with the eye bolts on a vertical piece and the deck being attached to the vertical piece with the deck eye bolt in the right position and do the gun rigging separate from on the boat so nothing is in the way. As to ME supplying what is on the kit parts list I have had very few issues over the years. I can't remember the last time I was short a part or a bunch - as to the right number of pieces like eye bolts as Ken ran into I think that's the kit designer's fault - though it would be nice when this is brought to the attention of the kit mfg that they fix the problem for the next run. I have seen ME and Bluejacket respond quite quickly to this type of input. When this happens drop an email right to Marc Mosko at ME - he's on top of things like this. So is Bluejacket - a call to Nic would straighten anything like this out there for sure. Kurt
  4. Yes, heat it red hot and drop it into water. It will bend very easy then. Kurt
  5. Duff: I don't always spray the base color against the tape as I have a lot of practice using the Tamiya and 3M tapes and usually know that they are very well sealed against any bleeding but when it is critical and not easily repaired or I have the slightest doubt about the seal I go to the base color spray. It doesn't hurt to do it all the time and if you don't airbrush/mask a lot then it is good insurance. As long as the spray is light there will not be a buildup on the tapes edge which can be harder to fix that some bleed at times. Practice, practice, practice. Kurt
  6. An update on speakers. Michel Mantin, former Editor of Neptunia, and NRG member from France, will speak on a WWII Japanese Battleship project he is working on. Kurt
  7. I have never used parafilm but it is pretty similar to friskit that I have used - which doesn't bleed - but if possible treat it like tape and take all the precautions, being sure it is down tight, edge sprayed with base color, etc. Another tip - always pull tape off by pulling it back over itself - never straight up, a sure way to lift the underlying paint. Kurt
  8. When trying to make sure that paint does not seep under the edge of the tape a good start is the Tamiya tape or 3M Fine Line tape used in auto body painting and by many custom painters of motorcycles and helmets. It is important to burnish the edge of the tape down onto the surface. The 3M tape and the Tamiya will change the color of the tape slightly due to the close contact with the underlying surface when the burnishing is adequate. A further method of avoiding paint seeping under the tape is to hit the edge of the tape with a light spray of the underlying color (the paint onto which the new color would seep) at the edge of the tape. This assures that if any paint were to seep under the edge that it is the same paint color and is not seen. Another tip is to avoid spraying with the new color directly at the edge of the masking tape. This can force paint under the tape if there is the slightest imperfection in the burnishing of the tape and it will also help to avoid a built up ridge of paint at the edge of the tape. Tamiya and Frog tape are not the same thing - Frog tape is much thicker. I had high hopes for it but I do not use it in my shop anymore after my testing showed it is very good for household painting but not models. I pass these tips along to all the workshops I do on airbrushing, they will help your painting. Kurt
  9. Ken: Thanks for showing this technique. Makes locating the ring foolproof and it's orientation can be very precise. I have filed this in my head for use in similar situations. I can think of several times when this technique would have saved me a lot of work remaking parts. When it comes to working with brass you are THE MAN! Guys, if you don't have Ken's book on modeling with brass your library isn't complete. Model Building with Brass, published by Schiffer - worth every penny it costs. I reviewed this book in the Spring 2014 Nautical Research Journal (59.1) with high praise. Thanks, Kurt
  10. Very interesting and a great fix. Fixing problem areas can be a real challenge sometimes. You nailed it. Kurt
  11. Welcome to MSW Sam. Let us know if you decide to post photos of the model in the completed build area. Kurt
  12. Ken: Really nice with great detail. I will certainly use the glue drop method for bolt head detail sometime. Kurt
  13. Jack: MSW members are Associate NRG Members. You will need to show MSW in the NRG Member # space on the form. In order to verify that you are in fact a MSW member and thus an Associate NRG Member we will need to know your MSW ID - yours being Jack12477. Yours will fit in the space completely but others may need to add it in the margin if mailing the form. If calling the office, just tell Mary your MSW ID. Hope to see you and a lot of the MSW members in Mystic. Kurt
  14. No, it is the kit with a lot of added details. The modeler was entered in the Novice class - by virtue of his award his future entries will be in the Intermediate class.. A gold medal automatically moves the modeler up one class minimum. Kurt
  15. Cathead: Do you have any documentation on the possible paint color of the boat? Is it included in the book? Kurt
  16. I have attached another photo of Sam Parent's Philadelphia for you guys to drool over. The details he has added are plentiful and truly make this a remarkable model. Sam is new to the NRG, I signed him up at the contest, and I am going to ask him to join in here. I gave a spiel at the modeler's symposium there about MSW and the NRG and I think we probably already have some new lurkers at MSW from there. Maybe he will share more photos with us. Photo by Sam Parent. Kurt
  17. We had two great models of the Philadelphia entered at the Manitowoc contest last week. Both took Gold medals and one took the Best of Show award! Before anybody makes their fireplace cook stove read my article - Part 7 - the concluding article on this model, about how I made bricks for the fireplace and how the Best of Show model maker did his. I would do it his way if I were to do it again, but don't use the wooden bricks from the kit - make real bricks. I have attached 2 photos of the fireplace. The first one is mine. I worked at making it look like it wasn't done by a bricklayer, figuring that the builders of the Philadelphia didn't include brick layers. The other is made by Sam Parent from Winona, MN who won the best of show award. He also made a lot of cooking gear as well as a lot of the stuff needed to load and fire the guns. Excellent work. Sam's is more closely that of a brick mason's work. Photo of Sam's fireplace is by him. We both made representations of fires in the fireplaces. Kurt
  18. Great job Ken. Brass stack is real nice - your comfort zone for sure. Kurt
  19. Ken: Nice job. Go with the stern side for the doorway. It was usually closed off with three or more horizontal planks that slide down in tracks on both sides to make a covering and when the sliding hatch is pulled aft the structure is sealed up against the weather. The doorway is aft for keeping out the water that would hit it from heavy weather over the bow - heavy seas over the stern happens but not as much as over the bow. Photo is of a smaller craft but the hatch and doorway is done the same. This one uses 3 crosswise planks to seal off the doorway. You can see the tracks. That's not me inside but the owner - the WI Maritime Museum hired me to build a model of this neat little boat in 1/12 scale. Have been out in it in Green Bay under the original Egyptian cotton sails - built in 1935 in Manitowoc, WI by Burger. They only bring out the original sails for boat shows, etc. Kurt
  20. Here is what I did with the area in question. The Smithsonian plans seem to show something similar. Kurt
  21. Dan: It looks good mounted and everything is straight! Congratulations on a job well done. Kurt
  22. I am checking again with our mail service as it seems that several members in Australia have not received their issues yet. When I spoke to them on Tuesday they said that the Australia issues are supposed to be delivered within 30 days of leaving NY. They were shipped on 3-16 from NY so they should be delivered by now. We are also tracking some missing issues for N. Ireland and several in the UK. I would ask that any overseas members to send an email to info@thenauticalresearchguild.org to let us know the date when you receive/received this issue of the Journal. Due to a mix up in Cuba, NY all but 3 or 4 non US members were mailed 2 issues of this Journal. Please let us know if you get one or two copies also. If you do not get a reply to your email to info@thenauticalresearchguild.org let Mary or me know with a PM here on MSW. Several members seem to have a problem with receiving emails from the info@.... email, but get emails sent from Mary's personal email - please check your SPAM filter before sending a PM. We are working to find out what has happened and we will make sure everybody gets their Journal.
  23. Fred: To heck with the 20 years - think positive! My wife saw my stash when my new 26 x 42 shop was completed and all my kits and stuff was consolidated into one area - previously stashed in various closets, basement & garage. She saw it all in one place and said "You have to live to be 350 to build all of those kits/projects". So I decided that she had given me a goal. Everyday now when I wake up I look around, get up and say "Well, the plan is working - only 283 years to go - so far so good!" That's my plan. Kurt
