Posts posted by Mumin
On 10.12.2017 at 5:14 PM, Mike Y said:
Aaaand....they are upside-down (check my October comments and numbering of the Left and Right parts). Those longitudinal groves are for forming only and should not be visible. Not a big deal however, on Russian forum some people do it on purpose
(they like the effect)
- coxswain, Canute, greenstone and 2 others
5
Great job! You definitely should send some photos to Daniel for his webpage.
- cog, EJ_L, Robin Lous and 2 others
5
There are more "traps" in this build:
1) markings on B19 are not for beveling, they are guides for gluing L11. And together they form temporary guides for drilling.
2) Waterways should be glued "upside down" (the glue goes on the upper - marked side)
3) Pay close attention to the right and left parts, sometimes they are intermixed on the plates (for example bulwark D2L sits together with R planks and vice-versa).
- Mike Y, Canute, John Allen and 1 other
4
Not now. The second planking should be glued to the bulkheads only (as far as I remember the instruction manual suggests this) and then you will see if it needs filler.
- Captain Slog and Canute
2
8 hours ago, catopower said:
The standard kit, like other Dusek kits, uses resin castings for the cannons, and that's the only downside I see to it, as I prefer nicely turned brass. Probably something Chuck sells might work.
Dušek sells both turned brass cannons and a bundle kit+cannons. And it's on sale right now
There is also "inside the box" video on youtube: https://www.youtube.com/watch?v=IBT3_J9oKsA
47 minutes ago, Ponto said:
... that looks fairly impressive! Is there an English version for the site offering more information?
JP
They have Canadian webpage... in French only
: http://hachettecollections.ca/contact.php
- coxswain, Ulises Victoria, Canute and 1 other
4
27 minutes ago, Ulises Victoria said:
I will try to contact them by email.
From what I can see here, Mexico is covered by their division Salvat, so you can contact them directly: https://mx.salvat.com/home/contact
- coxswain, Ulises Victoria and Canute
3
I've just noticed this message on the webpage:
To our foreign customers. The translations of manuals into English are currently at the beta state. They are correct, but the language is a little rough. Here is the list of translations that can be downloaded: MK0302 Schooner Polotsk
Might come in handy
Arsenal modeling is a discipline of naval modeling, the oldest and most demanding.
What is the meaning of the word "arsenal" in this case? I know that the historical ruins called "Arsenali" (eg. in Heraklion, Crete, from Venetian period) are in fact places where the ships were build, not the places to store the weapons/armaments.
If that's the case, then the term "admiralty model" is very close, or even the same?
Edit: link added
- CaptainSteve and mtaylor
2
Except the fact that every single part fits too tight and notches should be extended with a file. Bleh!
Mike, that's immeasurably better than "every single part fits too loose"
Great job on the build!
- Canute, hollowneck, mtaylor and 2 others
5
Here I made the mistake of installing the pipes first and the round frames afterwards, making it too hard to hammer nails to the holes on the frame. I leave them as they are for now, until I get a piece of iron rod to help hammer the nails without hitting the exhaust pipes.
Wouldn't it be better to drill small holes and use the pin-pusher?
- mtaylor, aydingocer and EJ_L
3
Hi Nick,
For strengthening the hull you can use the polyurethane spray foam (low pressure variant!). But do it carefully, as it can easilly lead to "banana" hull (or even break it apart).
The examples of this method can be seen here and (more detailed) here.
Also, if you are looking for other builds of this model you can search for WAK edition. As far as I understand, this is "Maly Modelarz" rescaled to 1:200.
- Captain Slog and mtaylor
2
Richard,
the plans and dimensions are for two variants: 60cm length/7 keel holders and 100cm length/11 keel holders but certainly can be modified.
BTW, some credits are in order, since the explanations on the plans are in Polish. This building slip is a part of group project "Baltic galeas Karl und Marie" meant as an introduction to scratch building. All the plans are available, along with sample build log by Romek Sobolewski. Original author of the building slip is Marek Mróz, the modifications and all the plans are prepared by Radek Kubera, Mirek Rybus and Jarek Bąkowski. The project was conceived somewhere in 2005, but is still very much alive - just recently several new modelers started their build logs on koga forum.
I am not experienced in creating plans, but if anyone does, please post them.
The plans are available on Polish modeling forum "Koga" (the link starts the download of pdf file).
- WackoWolf, Canute, Ryland Craze and 1 other
4
David,
The main purposes are two: to protect the ink (print) and to make the paper easier to form. As for the applying - one can use regular flat (about 3cm/1inch wide) paintbrush or by airbrush. Apply to both sides and hang to dry.
There is no difference in gluing when using surface cements (like polymer glue or butapren/shoe glue) and little to none with water based glue (like PVA or BCG).
- Captain Slog, Canute, WackoWolf and 3 others
6
Newsworthy updates from Chris Watton
in Traders, Dealers, Buying or Selling anything? - Discuss New Products and Ship Model Goodies here as well!!
Oh, I suppose you'll sell twice as much from preorders on this forum alone
