michael mott
Everything posted by michael mott
  1. Hi Roger thanks for the sympathy, I sent you a new PM I understand the principle and have used the same procedure on my rope making machine. I can wind up left hand 3 wires. Make 4 sets of that then wind up the 4 sets right or left by just twisting them in the same manner. the wire does not wind itself up in the same way as the thread does. I am just waiting for the brass wire to come for the next test. Michael
  2. Nice work on the fish box Denis, the tip about bending the hinges gives me some ideas. Michael
  3. Thanks Jack, yes as long as I can sit at the desk and putz I'm OK yesterday I plotted the positions of all the anchors on the funnel deck so now I can plot all the funnel stay lengths. they are all going to need replacing regardless of the individual few that are OK just so that they are all consistent colour and wind wise. I recall I think it was Bob in Arizona who set up the rigging on one of his boats by working at them off the model, I am going to do the same thing That way I will be able to just insert the eyes at the deck into slightly loose holes with some glue rather than forcing them back into tight holes. I will prepare a dummy funnel deck so that I can access the stays easily at the edges while working them. Michael
  4. Druxey Read these word just before stepping out for a meeting last night.....it's a long story suffice it to say I wound up in emergency, after tripping over a u channel stake in a front lawn cut and peeled back the skin on my shin to the bone. 7 stiches a lot of pain and a lot of deep breaths as the freezing was being done. I'm on some serious antibiotics and will be keeping fairly stationary for a couple of days to let the healing take a good start. Thanks for the tip about the Humbrol paints I will look them up. Bob, I agree with you on these scores, I will see how the smaller control wire looks, but will reserve all judgement until I have been able to fabricate the stays with the 34 gauge wire when it arrives. I have some of the type of pends that you mention, and had never thought about using paint in them, so will give this a try. cheers Michael
  5. Nils I have some brass coloured control line wire in both .018" and .032" the original B&L wore is .028" The hidden damage is now becoming more apparent. I am also of the opinion now that this ship has been knocked pretty hard on some earlier occasion.the following pic shows two concerns I have within the highlighted area the cargo winch deck is sprung that is the same on both port and starboard. you can see that the underside of the deck is unfinished and not very clean. The area below and just above the brass hatch is bulged a little and this is an old repair it is only on the starboard side. My concern is that the cargo deck is flexible enough that I should be able to pull it back down into alignment by using the vent stacks as a clamp by fixing the base ring that sits on the deck so that as the vent is reseated into the main block of the hull deck the black rings which are loose would pull down the deck. Both the foremast shrouds and the stern-mast shrouds are loose and I am reluctant to tighten them to make them look clean because they will put an additional strain on the already compromised decks. here you can see that the lifeboat deck at the bow is bent upwards in the same way as the deck at the stern, no doubt that pressure on the shrouds during the fall contributed to this. This brings me back to the funnels I think that having the shrouds and stays more rigid and made to exact lengths and replacing all of them might end up giving the best solution. The following picture shows a new stay using the .032" brass control line wire it is brass plated steel. with some of the Bassett Lowke wire used as a serving to emulate the same look but neater. I could do this with all the standing rigging, it even has the wrong lay up as the B&L help I'm falling down the rabbit hole........ Michael
  6. Hi Nils I consider you as one of the masters of this type of ship model, so any advice that you have to offer will most certainly be welcome. The tins I have seem to be OK after a while of remixing the pigment from its long rest on the bottom of the tins I use a piece of stainless steel that I salvaged from a wiper blade as the tool to remix The straight end works to dig into the pigment to break it up and the folded end works like a sort of potato masher once the pigment is mobile. Bob Not sure on this one yet, I might have to do a spot of practicing with my ruling pens and compasses, its been a while. I have some very fine lining brushes so might go with that option. I am reminded of a video I watched some time ago where someone was doing a decorative glaze on some china and they had obviously been doing the same motion for a long time and made it look like child's play. The other thought might be to use the type of pens that are used for doing the Pysanka but to use enamel instead of wax. and I would not need the heat either. This might be an interesting tool to sort out for painting. Has anyone used something like this for paint? Michael
  7. Ah yes Jan...that is why I still have this 40 year old Humbrol enamel, one of the best model paints that was ever on the market for hand painting in my humble opinion. Seriously though I hear what you are saying and my intention is to do as little painting as is possible. blending in a 1/16th line of paint will be a lot less hassle than a large repaint. The collapsible lifeboat that was the most damaged is about as far as I hope to have to go regarding replacing broken wooden parts. There are a few bits missing and I will tackle them as I get to them. I am going to use the enamel paint to fill the joint lines where possible this will take time to let the paint harden but will give me a lot of control over these small areas. In all likelihood Bassett Lowke used a very fine grind of enamel although they might also have used Lacquer, which is what we did at Allmodels when I was a young man in the early 60's we matched all our paints from the British Standard Colour charts I cannot remember the actual name of the Standards now but we only used the primaries and black and white to make any colour we needed. You are right in that this will be one of the most challenging areas but I do have a little background from the old school so I will be proceeding with a great deal of caution. Druxey, yes adding a little grime will no doubt be in order. Denis, my plan is to do as little to disturb the original surfaces as possible, the colour oxidation is already apparent regarding the areas of the deck that were hidden from exposure when I removed the structures from the funnel deck. The white will be the least problematic in my view. the most difficult I think will be the side of the hull, I will mix some colour let them dry after some initial test sample to get close, and then use the damaged area to test them with very small spots of the Humbrol to see how well they will blend. The next picture shows the aft funnel structure and the area highlighted is where one of the tiny broken bits somehow avoided being swept up it is glued back on with carpenters glue. The vertical rectangular section was snapped completely in half and a section at the bottom was broken off as well. The section highlighted on the collapsible lifeboat is one of the supports for the top boats and is the only pattern left, all the rest are missing from the port side boat deck, I managed to pull a small piece of similar Maple from my scrap maple drawer, so they will be easy enough to replace. time for some breakfast and a coffee. Michael
  8. Nenad What a great job on the canvas, you must be very happy with the look. Michael
  9. Denis it's just a bit of green felt I'm afraid. Greg two weeks! I cannot make any gravy in only two weeks....but thanks for the compliment. Druxey, it feels good to be actually repairing and not just removing broken parts. Joel I was using the end bench vise to clamp the V table for cutting out the curved piece for the open boat and wondering how to set up a stop, and it just came at the moment so I dropped the table about an 1/8th inch lower to create the well. John, yes I wanted to start doing some positive work as much for the inspiration as anything else, it cheered me up for sure to see some progress. I glued in the opposite piece this evening and will finish it off in the morning. Michael
  10. Made a start on the easy stuff first. The most damaged lifeboat is the one at the stern end of the boat deck. the damaged area was planed flat in preparation for some new wood I determined that it is sugar pine. glued to the new block trimmed off the main block Used a pairing chisel to shape the new wood I used one of the other boats to get the shape right Next was the open boat that sits on top of the collapsed one, I used the #11 blade to create a smooth shape for the new wood. then used the #11 to do the rough shaping That's it for now I'm off to make supper. Michael
  11. Bob there are some good prices out there. Denis I have also ruined a good pair of flush cut pliers doing exactly the same thing. regarding the stays I am looking forward to getting the right gauge of brass wire then I will be able to replicate the correct strand count. Greg I agree with you regarding browsing in the store, I spent a good hour discussing the round nose and the flush cut pliers with the owner. Fortunately his son is taking up the cause and is as pleasant and knowledgeable as his father. They both practice the epitome of good customer service. they have been serving the community for 30 years and it look by all accounts that they will continue. I have to visit their store most times I head into the city for supplies. I was able to try the different pliers with different wires in the store before deciding which ones serve my needs best. Albert thanks for your kind comment. Again thanks for all the likes and for those who looked in. Michael
  12. Hi Bob they are Lindstrom as are the flush cutters. the round nose are number 7590 and the flush cut are number 7291 The PDF product catalogue has some great technical data in it I did not pay quite as much but they are the best pliers on the market as far as I can tell, the difference is like night and day I have a couple of lesser quality round nose and they cannot hold alignment as well and flex too much for some tasks. One of the things that I make a point of doing is to use any remuneration on projects to improve the quality of my tools. These pliers are a joy to use. Michael
  13. Just finished going through the entire build Marsalv. Amazing detail and your sequencing of the construction of many of the elements make a great deal of sense. I particularly liked the way you fabricated the knees. beautiful workmanship on the stern details, very nice work on the lettering. Michael
  14. Igor you are amazing! I would have been happy to have made the yacht as beautifully as you did. but then you had to go and fit it into a lovely bottle, I just sit and shake my head,... Michael
  15. Dr Per I have no trouble resizing pictures, My issue is with the fact that in order to upload multiple pictures to this site one need to have Flash 9 as the flash version. The single uploads are fine, it is just a more cumbersome way of doing things. I like using IfanView for resizing it does all that I need. Thanks for the thought though. Michael
  16. Franks question is interesting, Why would there be so many holes and some not used, would it relate to different sail and or rigging configurations? Michael
  17. Thanks Joe, we must have been cross posting. And again thanks to all who are pressing the like button Michael
  18. john I think that you are correct regarding them being a crutch for the booms, There is a similar framework at the stern. Druxey, yes you are right, what I find interesting is the combination of the nickle silver (German silver) and yellow brass, I am guessing they used whatever was at hand in the stores, since it was all painted white. The rear section is all soft soldered together, I think it will take less time to fabricate a new piece than to fight with straightening the twisted remains. It will serve as a useful guide though. Michael
  19. The deed is done I was surprised to note that it is nickle silver. the next pictures shows the spring away from the deck. this is where it needs to end up the hull is damaged at the sweep of the rail but on very close inspection the sides are asymmetrical, the starboard side is different and not because of the fall, a little bit of a fudge during manufacture is my guess. I was able to find some wire for the handrails and also line for the running rigging, Oh and I tossed in a couple of much needed (desired) tools. I have ordered some 34 gauge brass wire and should have it by next week I did an experiment with some 28 gauge brass wire and the results are promising so should be even better when the correct wire come in. Yes I am learning a few new tricks here. Michael
  20. Hi Jeff, Sorry to hear about the health issues. Great work on the jig for the rat lines I can envision some other uses for a devise like this. Michael
  21. Yes It is, If I can find the right brass wire here in Edmonton and there are a couple of places that cater to the jewelry and silversmith folk The key is keeping it brass. using my rope machine I can easily twist the wire evenly. Regarding the cut basically I have no other option, I do not want to solder on the model, and the only way that i could remove the side that need soldering is to remove the whole piece which is a wrap around the whole deck. doing that would likely cause some damage that is unnecessary due to the way the model is assembled. Mick, thanks for the link, I think that there will be options here in Edmonton but if I strike out I will have to go father afield. Jan the force of the impact that twisted the boat deck and mangled the side likely imparted some forward movement. the front face is only forward about 1/16th inch on the port side, If I cut off the side at the blue line, it will be the easiest place to reconnect using a tiny plate soldered to the inside of the side wall. It will project an 1/8th inside behind the front rail and then a couple of pins as rivets when the deck above is replaced it is impossible to see inside the area without a dental mirror. I will work up a drawing to illustrate what I mean. Thanks for your thoughts Ed, I am going to see if I can find the right gauge brass wire as a first step. The way that Bassett Lowke did the stringing of the stays is interesting, My guess is that on the funnels the lower turnbuckle ends were fixed to the deck first and that the upper ends done last. I say that because the ones at the deck are tucked in behind the steps and railings in difficult to reach areas for winding up. This is in fact why I think that the stays were pre-made accurately on jigs. Some will definitely have been wire up in situ though. One thought that has occurred to me is use a combination of a simple fold through the loop the a separate wire for the whipping, rather than unwinding some of the strands as done by B.L. I will need to remove a few of the portholes in the area of the hull that is damaged before proceeding on the hull damage though. Colour matching was the one job that I always enjoyed when I had my model building business, I had a chip system similar to the colour chips that you see in the paint departments but mine were of architectural finishes, marble, granite, pre cast concrete you name it, it was the most enjoyable aspect of building the models. but I digress. off to the city to the suppliers this morning. Michael
