Posts posted by gak1965
8 hours ago, Keith Black said:
I'd take my skates apart and nail the wheels to both ends of one of dad's 2x4 cut offs. Myself and kids up and down the block would sit on the 2x4 and roll down the driveway or if dared, you'd ride down the driveway standing on the 2x4, kinda like a skateboard but long before skateboards that we know today.
Neighbor had the steep driveway. A couple of 2 by 4s, some lag bolts, a piece of rope, a bit of scrap plywood, and the wheels from a broken wagon were turned into a "go cart". Fortunately we lived in a cul de sac, so as we flew out of the driveway there weren't a lot of '70s cars with their crap brakes to run us over.
That's the thing that was really different for my kids; vs me; even in the suburbs there is just so much more traffic and the drivers are always in such a hurry. That and there just wasn't the same number of kids their age to help provide safety in numbers. I think it was because I grew up in a new neighborhood, where everyone was a family with young kids, whereas we've always bought older homes, and the neighborhood was a mix of empty nesters to people without children and everything in between. There were 18 kids on my block growing up in the mid 60s through the early '80s, all but one in a 6 year birth year range; there were 10 on the block with my kids covering a 17 year range. Not the same.
The heck of it is that we always misunderstand the risks, don't we? When the DC sniper hit in 2002, our kids were 2 and 4. After a day or two they were crawling up the walls and we figured we had to do something, so we took them to this playground in our neighborhood behind the Silver Spring YMCA on the logic that this was not well known, required you to take an obscure route on a bunch of residential streets, and we couldn't be afraid of everything. The chance of the snipers being in there was astronomically small. Well, it worked for the kids for the two weeks or so it took to catch them. I almost had a heart attack afterwards though, because they had been using the YMCAs in Silver Spring and Bethesda as bases, those guys had been within 100 meters of the playground multiple times. At the end of the day it was fine, it was the correct decision on statistics, but you really never know do you.
George
- thibaultron, Canute, Keith Black and 5 others
- 7
- 1
On 6/14/2023 at 6:45 PM, Cathead said:
Who needed brakes when you could put your feet down or just bail out? Scabs are a sign of childhood done right.
Gosh, a Big Wheel, although ours were from the '70s and the one in the photo has the "safer" hand break designed to intentionally create a spin. Between the three of us, we wore a long hole in the contact patch of the front wheel (like maybe 3 inches long) and still rode it.
My guess is we'd be arrested if we had let our kids play with them. Lord knows my collection of scars implies I did childhood right by your impeccable definition 😀
George
Sails look great! I hadn't thought about how the split topsail would create a situation where you have stuns'l booms on the course and upper topsail only (so skipping a yard) but that makes complete sense seeing it.
What is that device in the background of a bunch of your pics (the one with the 4 meters)? An old school power supply or an amp of some kind?
Great work, looks like you will be able to put 'FINISHED' into the title soon!
George
Well, it's been a couple of weeks, so I thought it was time for an update. A little early, but Happy Father's Day to all, and thanks for the well wishes on progress. I mentioned in my last post that I was off to Chicago for the ASCO Annual Meeting, so, I've had more like 9 days rather than 16, but progress is still a bit slow as I find yard making a slow task. However, I've taken a bunch of pics that show the progress of the main yards, including the previously made main course, which I accidentally made with the fore yards. So first, we have a photo of the four dowels that will be the top, topgallant, royal, and sky yards. I've drawn in the locations of the trusses (center) and the yardarms on either side, and then marked where I need to drill the holes for the jackstay eyebolts. Extra wood so they have someplace to attach when I put them in my mini wood lathe.
Second photo. Holes drilled and lathed down to shape, with the extra wood cut off.
Next step is to put in all of the eyebolts.
Photo 4, I've made most of the bands on the yards out of the Venture tape I used to make the copper plating, just cut down to the proper size.
Next, I need to make the trusses that connect three of the yards to the masts and are the halyard attachment point on the top yard. I made a former out of a block of wood. I use 1/32 by 1/16 brass strip that I've cut a hole in to make the truss. The hole is the diameter of a belaying pin, so I use that to place the brass onto a forming model I made from a chunk of wood. I bend it with the end of a pair of heavy wire cutters, and then cut the ends to length, and bend them to form the attachment points. If the truss is going to connect the yard to the mast, I take the belaying pin out, remove the 'ball' top, and reinsert it in the other direction, and CA glue it in place. That pin will eventually be mounted in a hole in the mast to allow me to sturdily set the yard in place. It won't allow me to change the orientation (straight on or nothing), but it's very solid, which I appreciate.
Finally, the last steps up to where I am now. CA glue the trusses in place, and the wrap with trimmed copper tape. Slide steel wire in the jackstay eyebolts as the jackstay itself. I still need to add a bunch of eyebolts as mounting points for various lines, make and add 2 iron blocks for the course and top yards that handle the top and topgallant sheets, and add the stuns'l irons to the top and topgallant, add the wood parrels to royal and sky, and of course paint them all black, but progress.
The jackstays are not perfectly straight, even using my drill press I find that the bit tends to wander a bit, especially on the smaller yards, but once they are painted, it really isn't very noticeable.
In any case, thanks for looking in!
Regards,
George
- BobG, VitusBering, Jared and 3 others
- 6
52 minutes ago, Bruma said:
If I may add something, don't glue them now if you plan to fully rig the main mast. They will get on the way and you will hate them.
Ask me how I know...
Absolutely concur. The davits are going on the Fish very near the end. The only thing that may go after are the lower stuns'l booms . The holes are drilled (on the Fish they mount on the outside of the hull amidst the chains) but they are getting rigged at the last moment. I'm even tempted to rig them as if the boats are away on a task as the Britannia boats are really bad (the ones on the deck house are upside down and I added some detail to make it look better on the outside).
One other thought is to get a set of Britannia davits from Bluejacket or Model Expo. It looks like BlueJacket has several sizes, and they make 1:96 ships that use them (e.g. Red Jacket), and they will sell definitely you a couple pair even if they aren't in the catalog. I don't see them in the model expo catalog, but my Flying Fish has 4, so they must make them, and I imagine that if you call or email they will sell you some.
Britannia fittings are also somewhat soft so you will need to use some care, but they will do better than soft plastic. I'm not in love with the model expo ones generally, as I find they have a lot of flash and sometimes casting defects such that I've replaced a subset of them on my Fish with either Bluejacket or scratch replacements, but I'm not planning on doing that with the davits at the moment.
George
The 2017 instructions don't make a lot of sense to me. It looks like they are trying to set up the boats to be lifted out of their cradles, but the rig for that looks all wrong to my eyes.
Something I have done to flimsy wood parts is add some wire or brass in unobtrusive locations (like underneath spreaders). Can you take a bit of brass or steel wire, CA glue it to the hidden side of the davit and paint the whole thing? I'm not sure exactly how big these are, but maybe that would work enough to keep things steady.
Could you set the spacing between the blocks with the line in place and then paint it with dilute glue while hanging down? It would presumably stiffen the tackle and you could attach it on the other davit without worrying that it will go slack. Never tried it, it's just an idea.
George
Fast as well. You are making great progress
1 hour ago, ted99 said:
Does anyone know what color the exposed screw shafts should be? I've never seen exposed shafts in dry dock. I wouldn't see a need for anti-fouling paint for an active service vessel, but I don't know.
Can't say for WWII. However, if you go here: https://www.dailypress.com/2019/10/29/the-aircraft-carrier-john-f-kennedy-to-float-in-dry-dock-12-at-newport-news-shipbuilding/ and go to the third picture, you will see that on modern ships at least, the shafts are painted.
9 hours ago, rwiederrich said:
Wow. Six capstans. Is the helm in that aftermost house on the poop? Given the skylights I assume there are some kind of cabins in the after 1/3 of the ship whose overheads make up the poop deck?
She must have been a bear to unload with only two hatches, both in the waist.
Regards,
George K
Saratoga and Lexington were repurposed battlecruiser hulls. Under the Washington Naval Treaty, they could be either scrapped or turned into aircraft carriers.
Yorktown and Enterprise were designed as carriers from the ground up, and was based on the US Navy's first such clean sheet design, USS Ranger, although both were much bigger than Ranger. Wasp was a smaller ship, more like Ranger because of the available limits under the Washington and London Naval Treaties. After the treaty system was concluded, the Navy built Hornet to the Yorktown specification.
George K
Thanks Rick!
I did the standing rigging fore to aft, but would do the opposite next time, as you are proposing, mostly because I think that getting the forestays on the mizzen and main will be easier without the shrouds from mast in front of it getting in the way of the anchor points on the next mast forward.
However, I'm glad I'm going fore to aft on the yards. Because the majority of the lines end aft of the mast itself, by going fore to aft, I don't have the yards from the main or mizzen getting in the way as I have to reach into the gap between the masts to anchor onto to the pin rails.
Your mileage may vary. Once I start installing the main yards, this thesis may be proved wrong, but so far I think it's working
George K
Hello all!
Well, just a quick photo, the foremast is now complete, minus the braces, so a milestone. I will be away from the bench for a week, as I'm going to Chicago for the annual American Society of Clinical Oncology conference. I haven't been since 2019 because of the pandemic and various job changes, so looking forward even though it means being away for a while.
As always, thanks for looking in, and for the likes!
Regards,
George K
Good evening to all. Memorial Day is a holiday that has many meanings to different people, so I will just say that I hope that all that mark the day found their observance satisfactory.
I've been busy on the foremast, which now has all five yards (course, top, topgallant, royal, and sky mounted. All of the halyards are mounted, and the live ends secured. The course lifts are fully in place, as are the iron sheets for the top and topgallants. I mounted five trucks on each set of fore shrouds to act as fairleads so that I can start the clews and sheets that are higher up the mast. The top clews and sheets and topgallant clews and sheets are fully installed, the royal sheets are mounted and threaded through the trucks, and the skysail clews and sheets have yet to be installed. Still progress is being made. Here are some photos:
One little oopsie that I discovered was that after installing the topgallant yard, I had failed to drill the sheaves for the sheets. When I went to drill one side, I put enough pressure that it ruined one of the lifts, which required replacement. When I went to do the other side, I was determined not to do so much damage, so I set up the following jig using a bit of dowel, held in place with Tamiya tape. It kept the yard from moving so much and I was able to drill the hole without additional damage. Eagle eyed individuals may also spot a point where I repaired a chain that broke under stress (I basically made another link with very fine wire). I figure that the latter is probably something that happened on the real ship, so, it's a feature, not a bug.
As always, thanks for looking in and for the likes!
Regards,
George K.
I have nothing to offer on the best way to build her, certainly not compared to some of the folks that have actual expertise. My only observation looking at the side view plan (and where I m in my current build) was "I hope you enjoy tying ratlines", because that ship has a lot of shrouds...
Good luck, I'm sure she's going to turn out great!
George K
- mtaylor, Louie da fly and Canute
- 3
5 hours ago, ted99 said:
Something I didn't know is the size difference between the German U-boats and US Fleet subs. Picture shows the completed U-511/Ro500 (Type IX9-C)and the hull of SS-212, USS Gato. Size difference is very apparent. Both are 1:200.
The Balaos and Gatos were all designed with having to transit the large distances of the Pacific so that they could operate with the battle fleet. As a result they were designed with certain comforts such as enough racks for each sailor to have their own and lots of food storage. While the nominal range of the Type IXC was longer, it seems like (at least in the beginning) the Germans were anticipating shorter patrols and less need for the creature comforts that took up space in US fleet subs
I've made some progress, but not much to show now as we've been in Boston for our younger (and final) child's college graduation (technically she finished her degree in December, but she didn't graduate until yesterday). While we were there we visited the Museum of Fine Arts (she lives about 1/2 mile away) and stumbled into the ship gallery. Thought I might share a couple of clippers from there; have a look at some professional level skills...
First up, the Marie Rose at 1:64
And the Flying Cloud at 1:64
Not a Clipper obviously, but a 100 gun ship of the line at 1:64
Tis is Boston, so USS Constitution
And he a French ship Héros (1778). This is not technically at any specific scale, but the craftsmanship is amazing considering it's bout 14 inches long. It was made by a French POW around 1781.
Regards,
George K
- bhermann, Snug Harbor Johnny and Cathead
- 2
- 1
1 hour ago, BobG said:
but she slipped into dementia and a long, slow decline
Thank you. I'm sorry your mom (and family) had to go through that. I'm hard pressed to imagine a worse way to go. Fortunately, as I say, my mother was mostly with it until the very end; but I know far too many that went the other way.
Regards,
George K
Absolutely amazing. It's great to see a model with all that spread canvas. It makes me think about the (usually pretty small) crew having to manage all of that sail so that the ships could make top speeds.
The finish line must be visible now...
George K
- robdurant and Keith Black
- 2
7 hours ago, ccoyle said:
Sorry to hear about your mother, George. Good to hear that her family was able to be with her.
Your model is coming along nicely.
6 hours ago, Rick310 said:My condolences losing your mom, I know how difficult it is as I lost my mother some years ago.
As far as the model goes, I echo What Rob said, very clean and well doneThank you both for the sentiments, it is appreciated.
6 hours ago, Rick310 said:I wonder if the reason that the topsail halyards rove through a block on the deck was so that free (bitter?) end could be taken to the capstan when raising the topsail yard. Just a though.
Could be, although the capstans are poorly placed for that. I assumed (as was suggested somewhere earlier) that it was because when you pull down you are limited in how much force you can exert by your weight, vice when you are pushing up from a (basically) immovable object.
Turns out the instructions had something to say about that. It appears that the block was only on the topail. Next time, I should RTFM I guess. The instructions are fine, but I've been tending lately to just build from the plans.
Regards,
George K
Flying Fish by gak1965 - FINISHED - Model Shipways - 1:96
in - Kit build logs for subjects built from 1851 - 1900
Thanks Rob. No footropes or stirrups either. I finished the eyebolts and wood parrels yesterday, maybe I can make the iron blocks and paint tonight and get the regular blocks and footropes this week. We'll see
I'm sure you are aware of this, but one thing I realized installing all the eyebolts is that I have to remember to move one set on each of the mizzen yards to the forward side of the mast. These are the bolts that make up part of the band where the yardarm begins, and they are used to attach the brace pendants. On the fore and main, the braves run aft, on the mizzen forward. On the Niagara I just tied them onto the yardarm, but there are irons, hence eyebolts, hence I need to orient them correctly.
Regards
George
