CDW
Posts posted by CDW
  1. Just now, mikegr said:
    Not sure about availability in your area. Car painting products are all high quality. Also i use one ingredient car filler, P1000 Liquid. Superfine, great  apply and easy to sand.
    The very best spray cans I ever used were of DuPont automotive lacquer paints, but I have not seen those cans available in many years. An adjustable flow nozzle sounds very unique. I am not familiar with any spray paint cans that have this feature, but I am going to have a look to see.
  2. Whether you buy one pre-made, or make one yourself, you will want it to have lights, a turn table, and a fan that vents the air to blow outside your window using ductwork as seen in this item advertisement from Amazon.
    Amazon.com: VIVOHOME Portable Airbrush Paint Spray Booth Kit with 3 LED Lights Turn Table and Filter Hose for Model Cake Craft Nail Toy Part
  3. Just now, king derelict said:
    Thanks for the advice Craig
    The treated glass that comes with the V2 has a smooth side so I am thinking of flipping it and trying it. Who knows I may have a sticking problem.
    I took your advice and bought the magnetic pad you suggested. Many Thanks. I would really like to get the reliability of printing improved. Its spoiling the fun at the moment.
    Thanks again
    Alan
    Alan
    I should have mentioned to be sure to buy one that matched your print bed size/range. Once I started using that pad, it solved my issue of the print coming off the print plate. I tried glue sticks, hair spray, and just about everything else, to no avail. One day I visited a 3D print shop here in Tampa and they turned me on to the need for a pad. That did the trick.
    Hate to say it in fear I may jinx you, but filament coming off the spool smoothly is another area of failure. Several times I had issues where the filament would get hung up, similar to what happens on a fishing reel...a bird's nest backlash sort of thing. We have to trust the filament has been wound onto the spool from the factory so as to not be "crossed". I think it's very easy to accidentally get the filament out of sorts when you finish one print job and use the same spool to start another print. Unless great care is taken, that filament can become wound underneath itself and as a print job progresses, it comes to a point where it can no longer come off the spool.
  4. One inexpensive change you can make is to use a mirror instead of the glass bed that came with your machine. Mirror glass is much flatter and less likely to be deformed.
    Also, cannot emphasize enough how much difference a build pad can make. Like this for instance: 3D Printer Magnetic?Hot Bed Sticker Pads for Ender-3 Build Surface 235 X 235 MM | eBay
  5. 15 hours ago, king derelict said:
    Yves
    You are working masterfully on this.
    I set up my newCreality printer and downloaded the Flower corvette files and so far have failed to print anything. Eight attempts failed to adhere to the bed and either created a ball of spaghetti as the filament detached or quickly deformed the hull section as part of the print moved on the bed. I have gone to using a brim around the part which may give me dimensional issues later but that has stuck to the bed at last but then nine hours into the print the filament snapped; looks like an air bubble in the filament. Attempt number ten is three hours in and we shall see what happens. 😄
    Thanks for the inspiration to try this
    Alan
    Alan
    Sounds like your extruder is too far away from the print bed. If too far away, the filament cools too quickly and does not adhere well to the bed. If it's too close, the extruder will push the filament on the bed.
    PS: At one time, I had all kinds of problems with my project moving off the print bed and tried all sorts of things to correct the problem. Finally, I bought a print pad and that solved my adhere issue. The print pads are cheap and it's worth a try if you cannot get your issue sorted out. Printing directly on glass just did not work well for me.
  6. Just now, lmagna said:
    Wow Craig
    Your Hood is really coming about. I think it is not a stretch to say that it possibly may be the best Hood build I have ever seen, in ANY scale! Hard to believe there is still more to come and it is not even done!
    Thanks for the compliments Lou. it's been fun to build this far and look forward to more offerings from this company. Keeping my fingers crossed, they are an excellent value for the dollar spent.
  7. Great choice OC! You will get a lot of pleasure with the airbrush system.
    95% of the problem issues new users experience with airbrush relate to learning the correct ratio of paint to thinner for the particular paint you're using, and keeping the airbrush clean and free of clogs.
    Like Ken said, practice, practice, practice,
    Congratulations on your new purchase.
  8. If you look closely at the decks, there are numerous rectangles scattered all over, about 50 or 60 of them. These are locations for storage lockers and ammo boxes for the most part. Got a whole lot of micro "hold-and-fold" photo etch to create the lockers and boxes, then primer and paint them before installing. Not really looking forward to that but will grit my teeth and getter done.
  9. Added the secondary’s, the rocket launchers, and Pom Pom guns. Added the rear superstructure with the “Hood” placard.
    544F4B68-58CC-4010-AF7E-DA8E99E82EE1.thumb.jpeg.6ce15abab37c1867695fe93788a07255.jpeg0F3ECF89-B545-4E73-BCC1-3B37C0FEDD72.thumb.jpeg.74707a64050b9679e55bb7a0e1c4548d.jpegC177D84A-7A60-4CCB-AEFC-1A8CDAD0E9AF.thumb.jpeg.6f8d50a28c8d7c2c93a8ffc06ba1376a.jpeg764E57E1-FCB0-4F87-86F8-A2E89D50C860.thumb.jpeg.1b80ee5aac2a7ce1c1e71031e16e0f8c.jpeg21008765-CFA6-45A4-8257-3AE01DB6871D.thumb.jpeg.65ca443938bc2fecfd6d7864a917ae8a.jpeg6203C852-C0F6-402B-AED4-34578C324A46.thumb.jpeg.c620357301ffbf29c0a5d3fa0b5ab25a.jpeg764E57E1-FCB0-4F87-86F8-A2E89D50C860.thumb.jpeg.1b80ee5aac2a7ce1c1e71031e16e0f8c.jpeg5EE21EB3-4A7E-4703-A5AB-71F8CA37AA52.thumb.jpeg.2c098b2f3faf81118cf6a7ab6831d971.jpeg
    Survived a “near death” experience when I nearly dropped the model on the floor. Caught it before it hit the ground and only suffered minor damage...now repaired.
  10. 11 minutes ago, Old Collingwood said:
    I am  seriously  looking into  getting an airbrush kit,    it will be my last chance to get one if I do  -  I just think it will make some of my kit painting  easier than using rattle cans outside,   I have been looking in Flea Bay  and seen a few  (one that impressed me was not just the low noise 54db  but its from an actual  UK airbrush specialist.
    Is it a case of getting a  fairly good one taht would serve me over the years  - or would any cheap one do as long as it was quiet  under 55db?
    OC.
    Think about it as learning to ride a bicycle. After you have learned to ride one and used it a couple of years, you can then appreciate a higher quality one. Until then, you are concentrating more on learning to use it than you are the quality of it. So I would say yes, a cheap one should be fine to get you through the learning curve which will take a while. I'm going to be honest and tell you it took a year or more before I ever got the hang of proficiently using my airbrush. And even after that, you learn more and more the more you use it year after year.
  11. Just now, Landlubber Mike said:
    So you just purchase the CAD plans from someone that has drawn them up, scale the parts up or down, and then print them out?
    It's not as simple as using a CAD plan. To be suitable for 3D printing, special attention is required to massage the CAD plan so it can "guide" the 3D printing process. The holy grail is learning to prepare your own 3D plans so that way you can model anything you wish, but man, that is an intimidating and long process learning to do it not to mention the cost of the drawing software. Purchasing a tried and proven plan such as Yves has done is the way to go, but there are a lot of CAD drawings out there not suitable at all for 3D printing.
