Everything posted by JeffT
Welcome to MSW
Welcome to MSW
HMS ROYAL KATHERINE 1664 by Doris - 1/55 - CARD
JeffT replied to DORIS's topic in - Build logs for subjects built 1501 - 1750
😮 nice- 1,035 replies
- royal katherine
- ship of the line
Welcome to MSW
Interesting method for building the hull. It looks very sturdy though.
- 216 replies
- masterkorabel
- ships
(and 3 more)
Welcome to MSW
I got the small pieces of planking glued to the frames and finally glued the transom on. The picture shows how I did that. The pieces of wood were used to prop the transom up after it was glued. Once the glue was applied I used a ruler to align it with the rear most frame and to makes sure it was level. On to fairing.
Welcome to MSW Bruce
Welcome to MSW Those are some nice looking models!
You're making this look easy Rusty.
- 152 replies
- medway longboat
- Syren Ship Model Company
Hi Chris. Welcome to MSW
Welcome to MSW
I've finally completed the front frame section and glued the frames to the keel. I ended up clamping the front section down to keep it from moving around when I lowered the keel over the frames. After that, I clamped the rear section as well. I just wanted to be sure I didn't bump something and knock everything out of alignment before the glue dried. Once the glue sets I'll tape the build board sections together and then add on the transom. I still need to glue the little piece at the top of the front and rear frames before I start to fair the hull.
Looks great Rusty. What type of paint did you use for the red?
- 152 replies
- medway longboat
Welcome to MSW
Welcome to MSW
New member from Maastricht, The Netherlands!
JeffT replied to Anna's topic in New member Introductions
Hi Anna. Welcome to MSW -
Welcome to MSW
I'm back at the workbench after a short holiday break. I glued the aft 10 frames to the keel after some prep work and a few dry runs. I went ahead and applied the glue and after several terrifying moments of manipulating and adjusting the frames everything settled into place. I used the front most frame to help me align the keel squarely to the frames. Now I move onto the front frames.
Welcome to MSW
Welcome to MSW
