EJ_L
Everything posted by EJ_L
  1. I agree that the planking will add a cool element to the build and enhance the overall appearance. The tires will also look great and may even prove functional if you have to go out and retrieve a lost ship.
  2. Welcome to MSW Scott! From a fellow veteran (Navy), glad you made it home and thank you! Best of luck on your future builds and I look forward to seeing your work.
  3. Welcome to MSW Dave! I understand your trouble of being land locked as I share the same misfortune right next door in Kansas. Glad you decided to come out of the shadows as you will find the community richer still when you can actively participate. Best of luck to you on your Syren!
  4. Welcome to MSW!! Great to have you with us and best of luck to you on your first wooden ship model!
  5. Welcome Sjors, good to have you with us and don't worry, you are not too late as this is a slow moving build. Glad you brought that popcorn machine with you, I think people are starting to get hungry. The curves at the stern of S.R. have been much more interesting to build than I was expecting. The hull goes from a nice smooth gentle curve quickly into a rather extreme narrow curve on the last two frames. This has caused some interesting challenges and shapes in my planking. The more I complete the more I believe that once done, everything will look alright but till then?....
  6. Those belaying pins are great at hiding on the drawings. I have missed several myself but luckily, so far, I have caught them before getting buried. I have found with my set of Corel plans that I have to lay down multiple pages to get the full scope of what is needed for each line of rigging. One page may show the path from the mast or yard, another the close ups of the seizing and a third where it secures to on the deck. While I am getting used to this process now, it took many long and confusing hours to make sense of it all! Glad you were able to fix it without too much trouble!
  7. I got a lot done tonight and the great cabin takes on more life! Exterior bulkheads are up, doorways to the quarter galleys cut in and built a couple of bench/storage lockers. Next up I am going to try to build a table and a couple of benches and then I will be ready to run the wires to the lights. I plan on trying to design a couple of small hanging lanterns for the lights to go in. I bought flickering LEDs in hope to simulate candle lighting. We shall see.
  8. Light bleed through is another reason why I am building the interior walls before planking the hull. Once the walls are in place, I plan on sealing off any and all cracks/gaps in the wood work and then I will paint the backside that will be in between the planking layers black. That is what I do on model buildings for my railroad that have lights and it seems to work great. Last thing I want is to turn on the lights and have a glowing ship!
  9. Incredible! That has to be one of the coolest things I have seen on this site in a while!
  10. Our Admirals often have more common sense about them than we like to admit.
  11. I would think that in practice there would be discrepancies in exactly how ropes were tied off from crew to crew based on the instructions from the bosun. I would think though that while differences would be found between ships, that the same practice would be used throughout the same ship. So I would say, stick with the way you have started so they all look the same the same. Unless your bosun was killed in action and replaced midway through by another who wanted to change the existing practices...
  12. Thank you to everyone for the nice compliments! I am still far from an expert at this and there are many others on here far better than myself so the kind words mean a lot. Re-dos and start overs are definitely a major component to this hobby but that is usually a sign that you are learning and growing in your understanding of ship construction and the skills to build them. Go ahead though and curse me if you want, I feel the same when looking at some of those other works on here myself. If that cursing is because I inspired you to do something better then I will gladly take it! Inspiration and motivation is what this community is all about and I am proud that I can contribute to that. Anton, I share that same sentiment on having builds from the same time period to compare with. Many of the things I have don on her were inspired from other S.o.t.S. and Vasa builds. While they are not exactly the same many of the features and practices of the era are close enough that they are interchangeable. Again thank you to all for the compliments and the likes! Helps to keep me motivated and pushing myself for better!
  13. I have not tried the meet in the middle approach but it might be something worth trying. As for being able to see inside the cabins, S.R. has large rows of windows on her stern that will allow people to look inside. Combined with the LED lights that I will be placing inside you should be able to see most of the details fairly well. The real challenge to see inside will come when/if I decide to case her when she is done. Being able to get up close and look will make things easier but if you are several inches away due to the case, I do not yet know how well you will be able to see the interior. I will play around with this as the build progresses and for the next couple of years this will not really be an issue!
  14. I have always planked from the keel up on the lower hull. The upper hull I usually do first from the lowest wale up. (See my La Couronne build log) On S.R. I had to do it a little different though due to the extensive modifications to the cabins. With needing access to the interior to run wiring and to install the bulkheads and furniture, I had to hold off on the planking. While I do see the advantage of starting from the top down in that you can hide screw ups on the bottom of the ship, if your layout is drawn in properly and you take your time, either way works fine. I do think that if I was trying to do the planking in a single layer I would go from the top down. Thanks for the compliments Popeye! Hopefully they will only look better as they go! The best part of modeling the interior is no one really knows what it looked like. There are a few sketches of the interior dimensions and layout but as far as decorations and the actual furniture I have not yet found anything. So here I can definitely take creative liberties and design the spaces as I think they possibly could have looked.
  15. The planking continues to go on and on and on but, it is growing as the port side has now reached the lower gun deck. This is a good place to be as at least on that side there are no longer any crazy curves to deal with. The real story of this weekend though is that I have started to build the interior of the great cabin! In order to run the LEDs before the hull is closed up I had to know where they needed to be and in order to figure that out I had to have cabins to put them in. Also, it is far easier to build the cabins now while the hull is open and I actually have room to work. I had though about just leaving the stern off and working the inside from there and while some final details and touch ups may need to take that route, the floors, bulkheads, and many of the other details I want to add can go in now. Thankfully S.R. has a lot of windows on her stern to allow people to see inside her and combined with the lights, I have hope that all this work will not be completely wasted. If I'm wrong then at least these pictures provide proof that I am in fact partially insane.
  16. Unfortunately life does tend to get in the way of model building but I am glad to see that you have not quit and are continuing along as time and money permit. Looking forward to having you back at it and seeing the updates!
  17. Are you asking about the deadeyes themselves or the iron rings and chain plates? I think the iron works should be black but I have seen some nice models with them made from brass. Unless the deadeyes are made from a very white wood, in which case I would probably stain them walnut, I would leave them their natural color.
  18. Welcome to MSW Ian! Great to have you with us! I look forward to seeing your Sirene and don't worry about posting pictures of something that looks bad, we all have those of our builds. Part of the great thing about this community is that we are here to help each other and encourage learning and the continual growth of this hobby. We don't put down and insult work no matter the quality, instead we try to help improve by sharing techniques and tricks to help make things better. I look forward to seeing your build!
  19. Welcome to MSW Miles! Good to have you with us and I'm sure that you will find us a great community to help you get through those challenging moments in the builds as well as some of those same moments in life. Best of luck to you and I look forward to seeing your work!
  20. Welcome back to MSW Sterling! Best of luck to you on your search for the Glory of the Seas. I hope you can find those plans and I look forward to watching you bring her to life!
  21. Fantastic! Your mizzen mast looks great and the rigging is very sharp. Well done!
  22. Thank you all for the kind comments and the likes! I do plan on putting her in a case when done. I am working on a design for a new curio cabinet that will have her center stage but also allow display around her for the Admiral's collections also. Don, funny you should mention that as I have just came from that particular shelving unit and am in fact enjoying a nice beverage while I catch up on the goings on in MSW. May have to pour another when I slide over to the work bench to continue S.R..
  23. I've run into the same problem of the blocks supplied with the kit being too large for the canons. I have bought some smaller ones through Syren that I intend to use on S.R. but on on other builds I have left the larger ones and while I know and a lot of people on here know they are not quite right, my main audience of friends and family are just impressed that I rigged all of those blocks! As already stated, once everything else is in place there will be so much to look at that they will hardly be noticed. By the way, your rigging on the canons as well as the canons themselves look fantastic!
  24. Great fix. Had you not shown us the whoops, we never would have known it was damaged. Looks like you are back on track and moving along again!
