Ian_Grant
Everything posted by Ian_Grant
  1. Nice pics of scenic landscapes. An area I've never been to.
  2. Funny you should ask....I just recently ordered "British Battleships of WWI" by R.A. Burt (I'm re-detailing an RC model of HMS Lion I scratch built in the 70's). This book obviously includes Dreadnought. Here are a few pics which might assist you. In the line drawings of profiles in this book, signal halyards from the yardarms just kind of fade out in mid-air but they all were cleated on the flag deck which at least on Lion is one deck above the shelter deck which is one deck above the weather deck. One of the photos shows a set of signal halyards pretty clearly. If you need a pic of some particular view, let me know and I'll check the other photos. By the way, she looks great! I've never airbrushed a model, I'm such a dinosaur....😭 Ian
  3. Hi Glen; FYI usual practice is to hang long weighted lengths of thread for shrouds on the wall to stretch them out. For days. When rigging them, they can then be pulled nice and straight without too much tension.
  4. I wanted lots of framing because the skin is only 1/32" plywood. Don't know the weight yet; by the heft of her there's more ballast under the after deck which I haven't torn off yet. 😶
  5. Butchered inside the hull for "A" and "B' turret linkage. Hacked out the centre portion of the two bulkheads involved so I can get my hand in up to beneath "A" turret. I'm not sure what the assembly sequence will be vis-a-vis locking the timing gears on their shafts, given that the deck and barbettes must be on before the turrets are added. I'm about to make a plywood "base" which will define the spacing between the brass tube liner shafts for the turrets, and the required servo. I realized that I can reverse the servo's rotation simply by mounting it upside down which also has implications around fixing the gear to the servo arm below the servo body. The good part is I can use the laser cutter to form this plywood part, with shaft pilot holes and servo mounting holes drilled with pinpoint precision so belts/gears will work well. Bulkheads hacked out. Here is all the metal ballast from the bow compartments. It's a considerable weight. I'm not sure what battery I will be using, the 70's gel-cell was itself very heavy yet all this extra metal was needed. I can see I'll need to buy a battery and build a shallow tank in the shop for some flotation tests before the decks go on again. I lubed the two motors for the first time in 40 years. The prop shaft stuffing tubes sound absolutely dry too.
  6. I finally unboxed the A1 3D printer. Is it just me, or is it harder to figure stuff out without an included printed manual? Their included "quick start" comprises about eight 3"x2" pages. My first problem was encountered while attempting to screw in 10 machine screws to attach the printer head frame to the base. The six central ones simply would not go in. I took it apart and tried again twice before finally noticing the six threaded holes in the base were covered by very tough transparent tape which of course peeled off in tiny shards. There is absolutely no mention of this in the "quick start". And no apparent reason for the tape, at least to me. I had problems trying to produce a sample print. What do I as a raw beginner know? This is supposed to be a beginner's machine. After plodding my way through getting the printer to bind to my Bambu account and giving it a name for the network, and waiting about an hour for it to do a full self-calibration, I could not get it to notice the filament I pressed into the tube. What is there to know, I thought? Just push the filament into the plastic sleeve until it enters the printing head and stops. Then I tried to get a pre-stored sample design (a little boatie) to print. Nothin' doin'. I had to google to youtube to find out that I have to go through menu screens to find "Load Filament" and press it and then the thing warms up the head and tells you to push the filament in "now" ( and by the way before you do this you have to find the menu locstion to tell it exactly what type of filament you propose to use. It then failed to see the filament and bleeped "retry" several times with me pushing the filament each time. Then it spent about ten minutes doing I don't know what, with the head moving around sometimes touching the base plate and sometimes going over to the head cleaning attachment while I wondered what was wrong. Finally it started the print and came out with a beautiful print in less than 15 minute , which surprised me because it was moving so fast the desk and floor were shaking. It's blindingly fast compared to the library printers. I think I will set the speed to 60% from now on, which is the next option down from 100% which was the default. I find it annoying that I needed to blunder around on youtube to find out such basic info instead of it being provided in the box on just a few sheets of paper. It will be interesting to discover if there was needless delay because of some other menu option I am not aware of, or if the head cleans itself several times before every print. Anyway, the print is beautiful and I'm sure I will get used to printing with time. Next up: Have to figure out Bambu's slicer program. Another thing I have never used. At the library "Makerbot" just does it for you with no manual intervention necessary.
  7. I took another look at my Norman Ough drawings. I can see why the teenage me made the forefoot squarish thinking that's just the way these old ships were, but looking now it seems that there is a gadget placed over the forefoot and clinched in place by lines/chains to the cleats on the foredeck. Some sort of cable cutter ,maybe? Or something to do with paravanes?
  8. Struck me afterward that it's octagonal not hexagonal, or it should be.
  9. Bill, if you sanded a hexagon into the middle of the dowel yard the hexagon "tips" would be flush with the adjacent round part ie the flat faces would be recessed compared to the adjacent round part of the dowel. This would make the yard weaker in the centre which is nonsense. Adding six strips to make the hexagon is the solution; this way the hexagon area is stronger. That said, I don't like Occre's picture; it looks like the yard has been broken by a cannonball and they've fished "splints" around it. Make it all the same colour. And I'd be tempted to sand the flats thinner than they are, until the centres of the flats are only a little proud of the rounded part.
  10. Very nice Bill! You have definitely transitioned from plastic to wood. Well done!
  11. Yes I was aware of this. I have no plans to print ABS as it is toxic and we have a parrot in the house. Birds are very sensitive to odours and airborne chemicals. The Envirolaser people assure me I can print "PLAwood" etc with a stainless nozzle as opposed to a hardened one. I decided to go all out and get an A1 tomorrow. Looking forward to trying some prints.
  12. Thanks for the drying tip, Kevin! I assumed the sealable bags were sufficient but hours on the spool while printing could be spent absorbing humidity........
  13. Kevin, what have you heard on the street of the Mingda X2? Black Friday priced less than an A1 Mini.
  14. STOP THE PRESSES!!!!! I just noticed on the Bambu web site that their Black Friday sale starts on Monday morning!! The sale price on the A1 is $379, as opposed to $450. The Mingda will be go for $230, as opposed to $320 which I just paid. What to do? I'll be talking to the 3D store people tomorrow.
  15. Yes, I was noticing that myself. Will fix it when I improve the patch. Thanks!
  16. Tore off the foredeck (while saving all the brass bollards, cleats, etc) to reveal things that I had forgotten...... I packed the forward inaccessible cavities with bits of styrofoam, I suppose to provide buoyancy in case of a leak. Or, it might have been to prevent the metal ballast from clunking around. Yes, I did put metal in there before adding the deck; I guess I did a flotation test in 1977 and realized that a lot was needed. Those of you who followed my recent RC Roman Galley build may remember that early on I weighed "Lion" sans motors and other equipment to provide a guess as to what the galley hull might end up weighing. Well, now I know why the bare Lion seemed so heavy, or, why the galley turned out so light and threw off my displacement estimates. Deck removed: (Why did I leave that red pin in there in 1977??). Styrofoam removed.....oops, there's ballast in there. Brass sleeve for "B" turret pivot shaft, after barbette removed. (More metal!). I pondered how to get 180 deg pivoting at the turrets. Simplest thing I can think of is to mount a toothed timing gear on a servo arm and connect via a toothed belt to another toothed timing gear on the turret pivot shaft. Making the gear on the servo triple the size of the other gives 180 degrees at the turret from a 60 degree servo. I found very nice aluminum timing gears and belts on a robotics web site. Couldn't get ratio=3 exactly, just 2.8 with not-too-large timing gears. Close enough. So the plan is to have a setup like this for each of "Q" and "X" turrets, ie two individual servos y-connected to a receiver channel to move in unison. Fingertech provides a simpletool for calculating the required centre-to-centre distance of a given pair of gears with a given belt. See here: https://www.fingertechrobotics.com/how-to_pulley_belt.php In the case of the belt joining the "A" and ""B turrets shafts, using two 18T gears and a 70-tooth belt yields centre-centre distance of 78mm which is exactly right for the inter-turret spacing at the scale of this model. There is a complication for "A" and "B" turrets; they need to turn, in unison, in the opposite direction as the others; eg "X" and "Q" pivot clockwise (seen from above) to train to port, "A" and "B" pivot anti-clockwise to train to port. Plan is to drive "B" shaft from a servo via either two meshing gears, or via belt from a servo which rotates in the opposite direction given the same signal as the other two. I read rumours that this might exist; someone said Futaba servos move opposite to the norm but I will have to check this out. If I find such a servo, it will connect via the belt to a second timing gear on "B" shaft, again with a triple-size timing gear on the servo. If I can't find such a servo, I will connect it to "B" shaft via two laser-cut wooden gears. "A" of course will move in whichever direction "B" moves. I found an on-line tool which generates an .svg file to laser cut two gears, after you fill in a table of numbers of teeth etc. See here: https://evolventdesign.com/pages/spur-gear-generator As in anything I build, this hull is very solid; keel plus four stringers a side, 1/4" plywood bulkheads, many solid. I need to carve out the centre of the engine room forward bulkhead; you can see where I hacked holes to get alligator-clipped wires to the motors. Being older and wiser I'll now use bullet connectors meaning the solid ply would be in the way. That blue tube is the RC-aircraft-style cable guide for the rudder linkage. Loose U-joint is for absent motor. Bow shows a badly-patched square. This was due to my brother's idiot friend George who dropped the unfinished hull while looking at it. Ah, memories! On another topic, I got tired of having to sit in front of the library's 3D printers waiting for them to finish. Plus, you only get a maximum 3 hour window for a print so there's no time to make anything significant. I decided I want my own 3D printer. Impatient, I bought a Mingda Magician X2 this week, a very nice printer with features making it easy for beginners to use. However, I'm having second thoughts. I was torn between it and a Bambu A1 Mini. Until I get rid of some clutter I can't set it up, and we're away for most of November, so I am going to return it (unopened) and wait to see if the full-size Bambu A1 comes down about $100 on Black Friday at the end of November. This would bring it down to the price of the Mingda and I'm convinced it's an even better printer. If not, I will probably go with the A1 Mini and save $100.
  17. Hard to tell from the nice photos, but are the stacks always centred on the keel line? I have no knowledge on this topic either, by the way.
  18. Glen, I had an inspiration to make it much easier to implement in a bottle. The trick lies in your choice of bottle; something like this: It's a one-gallon wine fermentation bottle. Plenty of room, and a bigger mouth.
  19. What about one of those straws with a corrugated section bent to 90 deg in the bottle, and a funnel attached at the outboard end? Glen, I would like to propose an engineer's approach. Since you can't make the epoxy spin after you pour, you need to spin the bottle instead. Some sort of cradle to hold it horizontal, with a DC gear motor to do the spinning with the spin axis passing through where you want the centre of the whirlpool, speed controlled by adjusting the motor voltage. There, simple! You're welcome. 😉
