Baker
Everything posted by Baker
  1. the description is "a la billings"... mast : 26 pieces...
  2. if I remember correctly. First impression. Pieces with this shape are intended for the lower parts of the fore and main mast. so, you should have 2 like this. otherwise you may have one too many.
  3. I fill the open spaces between the bulkheads with fillerblocks when I make a scratch model. The reason is (was) that I did not have a correct frame drawing. Due to the thickness of the filler blocks, there is a lot of margin for sanding errors here and there. The first coarse sanding is then done with the vertical sanding disc (Goes quickly and without much effort). I will not do this with a kit model with 2 layers of planking, only a few at the bow and stern.
  4. An example from a great modeler
  5. The French text translated into Dutch Onder de elementen wordt genoemd "een kleine brajart" van 20 voet lang, 4 inch in diameter en 6 inch in toon. Ik veronderstel dat dit mastelement onder een naam die ik niet kende een luchtboog is die het mogelijk maakt een fok te vestigen, zijdelings met de wind mee of met volle reikwijdte en bij goed weer. Fok in English = fore sail It can be a curved yard for the fore sail (20 feet long 4 inch in diameter and a curve from 6 inch) To be able to make full use of the fore sail in good weather. There is no guarantee that this is the answer 😇😉
  6. Now that the bulkheads have approximately the right shape, it is time to add the extra supports between them Then the bulkheads and the supports are chamfered now my favourite part, fillerblocks These will be installed in the hull part below the cannon deck Number 1 in place Thanks for following
  7. Great work All the extra details bring more life to this kit
  8. Great model Much, much better dan 70% 😉
  9. Thanks Mike. Next... Mary Rose, Mary Rose, Mary Rose 😉
  10. With a broken grinding machine, some gears and some other leftovers you can build a serving tool. costs little, just some time 😉
  11. The 3 models are ready. These are all made "out of the box" As mentioned earlier, these Revell models are quite nice without extra detailing. The boxer The 6 x 6 And the 8 x 8 three in a row Thanks for following, comments and likes during this build
  12. Good luck I also had the idea to build this (later...) Some useful links https://maritiemmuseum.nl/en/stories/masterpieces/mataro-nodell
