Everything posted by RGL
Side plates pre shaded, a few shades of grey and oilcanning. I need to put another diluted coat over the top then cut some templates and overspray with dark blue for the camo.
It’s near impossible to find any contemporary photos, there is a website dedicated to the restoration of a Fletcher class destroyer where the hull is covered in barnacles and almost rusted through but it would be sitting fallow for years and years. The oilcanning would (I expect) get worse as the years and pounding into big waves over and over.
Lower hull, using a piece of card, overspray of red to highlight the ribs, then diluted coco brown to dull it down, the very dilute burnt occre to highlight. Next will be grunge which will make most of this go away, but as this is 1942, the damage and grunge would not be so bad.
Pat, XF9 (hull red) and XF50 (blue) at a 1/2 ratio (That’s the Tamiya instructions) I need to lighten and highlight yet as there are non slip walkways. Cog, I’ve done oilcanning on a lot of my builds, in particular the USS Spruance but I’ll break it down when I do it next.
Now to make the brass disappear. Base coats of the lower hull and blue deck done. I’ll give it a day to dry before I start working on them properly to add the oilcanning and highlights.
I’ve got 2 Anatomy Of the Ship books on subs, my brain would just explode given the amounts of pipes inside of them and having to replicate it
There are some tiny bits off brass which I’m leaving off too as it’s not visible with the naked eye.
I could probably make this piece 5 times to get it perfect but that’s not going to happen. When painted it will be less noticeable. I only ever ever use a cigarette lighter to burn CA off PE.
Um, don’t know what that is, I just bent them around a drill bitt. They are about the size of a thumbnail so any further details added just would get lost in glue.
Ah ha! Cog’s back! Nearly every PE instructions I have seen have some type of beni g instructions not the finished product that just mentions the part numbers. For instance, the rear end of the torpedo types require rolling then wrapping around a drill bit to even come close to being right, and I’m yet to see any instructions for that.
I’d hate to think what would happen if this was someone’s first PE set! It’s quite hard.
The railings will be individual stanchions so that’s easy, I can mask the hull and probably stencil abovedecks.
