Everything posted by FriedClams
Good to see an update Vaddoc. Bummer about the mold and misshapen hull, but it looks like you've worked your way through those problems. Nice work on fitting the deck. Gary
Thanks JD, I'll be sure to check that out. I subscribed to Wooden Boat for years - it's such a great magazine. Actually, I don't know why I stopped getting it. Maybe time to re-subscribe. Thanks again. Gary
Thanks for the nice comment Wefalck. Yes, shadows can be a problem, but it was one that I didn't consider until I saw it. I too like the "looking under" figure, but no I didn't make it - it is from Preiser #28156. Thank you CDW, Keith, Kurt, Mark, Edward, Paul and Ken for your wonderful comments. It is always so truly appreciated. Thank you for the nice words, Jack. An N scale scene would be very cool I think, maybe a steam locomotive taking on water at a tower/tank or sitting in front of a station. Limitless possibilities. You better get started so we can all follow along! Mike and Andrew - thank you so much. And thanks to everyone for the "likes" and for taking a look. Be safe and stay well. Gary
Greetings Fellow Modelers, After a few weeks of being sidetracked, I finally put in the time to finish this shadowbox display. Because the main door is partially open, a surface that extends beyond the wall to the “outside” is needed. I decided that surface would be concrete and is made of hydrocal smeared on a piece of basswood. This extension is 7/8” wide which is all the space available between the display module and the inside of the case. The doorway needed two doors that swing out from the center. I drew up what I thought looked appropriate and made them up. The outside lights are white 5050 surface mount LEDs. I started out thinking four would be enough, but then added two more and then another two. They were mounted to a rectangle of styrene which was then bend downward over the doorway. I lowered the lights up the point where they could almost be seen by the viewer looking out the doorway. The two sticks of basswood were glued together at their crossing once the optimum downward bend was found. The doors were positioned to minimize what could be viewed beyond the doorway. I don't want the inside of the shadowbox to be seen. The rear window presented some difficulties due to the background image being so close to the window. In fact, the image is 1/8” (3mm) from the back of the window. I boxed off the window with 1/8” basswood strips and painted the surrounding area with a silver chrome for added reflectivity. I then positioned five 5730 LEDs around the perimeter of the window with the side LEDs pointing inward toward the center. Back when I installed the window, I had placed a grating over it and dirtied up the glazing so the view through it would be obscured. This didn't work and just looked muddy and grubby, so I removed both and replaced it with clean clear acetate. A background image was attached to a piece of styrene and the window box was closed up. I placed clips inside the box to hold the display in and to make it easier to remove for swapping out the vehicle in the future. Also, an image was glued to the inside wall of the box outside the doorway. I spent considerable time balancing the lighting to get the look I was after. Not a complete success by any stretch, but I'm satisfied with the result just the same. The first three photos are with both interior and exterior lights on. Then the exterior lights only. The problem with having the interior lights only on, is that you can see the shadow cast by the window muntins on the background image. This is because the image is so close. My other displays don't have this problem because the images are set back much further. And that's it. Thanks to everyone for taking a look and for all the likes. And a special thank you to those who left comments of support and encouragement – I appreciate it very much. Be safe and stay well. Gary
It’s true, very little is square, plumb or level on anything that floats. So many odd compound angles. It is certainly one of the challenges of this hobby, but I find it’s one aspect that makes modeling boats/ships so entertaining. In a deranged sort of way of course. I’ve not heard of the petroleum jelly trick - thanks for sharing that. It’s going into my notes folder. As always, beautiful work Marc. Gary
- 2,696 replies
- heller
- soleil royal
(and 9 more)
Such a beautiful model Keith and I have enjoyed every posting from the beginning. Thanks for the extra effort of sharing your process and techniques. I’m looking forward to the final photos and anxiously awaiting your next project. Gary
US 6” gun by RGL - FINISHED - Panzer Concepts
FriedClams replied to RGL's topic in Non-ship/categorised builds
Very interesting build you have going here Greg, and I’m really enjoying your log. Like the round modeling vice. Gary -
Me too Mark - good to see you back and watching for future updates. Gary
- 505 replies
- vanguard models
- Sphinx
Beautiful work Tom! Congratulations on its completion. Gary
- 118 replies
- Duchess Of Kingston
- Finished
Hey Paul. That’s not the easiest hull shape to plank. If it’s your intention to fill and sand, I think you should be fine. You can fill the gaps and build up material where needed to obtain smooth fair lines. You probably already know this, but the NRG has a couple of great articles on hull planking. Being new to this, you may find them helpful in better understanding the process more completely. I found them invaluable. Gary
