bruce d
Posts posted by bruce d
  1. Thanks, Wefalck. Yes, I found it in PDF quickly and it comes close but does not state the rules. What a great piece of reference material! I am glad to have this one.
    My observations tell me that the width of most regal monograms (if that is the correct name?) is roughly just less than half the diameter of the part of the barrel where it is cast: so if you looked down on it from above the emblem should appear to occupy nearly half of the section you are seeing. Not very exact but that is what I see.
    If there is a source of course I will be glad to chase it down. Best bet at the moment is 'Boxer, E.M. Treatise on Artillery' which is quoted greatly in the 'MCCONNELL (1988): British Smooth-Bore Artillery' from Wefalck.
    Regards,
    Bruce
  2. 28 minutes ago, Clark said:
    there are some providers - at least in Germany - who are selling a lot of blade subtypes
    Clark, thank you for the link.
    I recently got a Proxxon FET saw and have been learning how to get the best from it. So far I think the saw is better than I am: everything I have attempted, from rabbets to thin strips, has worked with a little practice.
    No tool is sacred (well, perhaps the Byrnes saw  ...) so I will be making a couple of modifications to my Proxxon.  Maybe if you find your saw has a limitation, you will also find a solution and post it here?
    Dust extraction would be first on my list if I had your saw. I haven't found a tool yet that works better when it is dirty.
    Regards,
    Bruce
  3. Keith, thanks, that makes it straightforward (I like straightforward). I am very impressed with the looks of your Germania and will experiment with the home-brew wipe-on-poly on the different woods I am accumulating for my build.
    My garage/workshop is very poorly sheltered from the Sussex elements and I intend to get this round of experiments over quickly now the weather has turned nice.
    Bruce
  4. 39 minutes ago, Maurys said:
    Any comments on the independent vs the self-centering model?
    Hello Maury,
    They do different jobs. The s/c will hold the workpiece on the centre-line axis of the lathe providing the workpiece is round or the number of sides is divisible by the number of jaws (usually three but there are s/c chucks with four or six jaws for specialist purposes, such as this one). An independent four-jaw can do the same trick with odd shaped pieces. The independent requires each of the four jaws to be set to achieve the correct position, and the operator must have the ability to establish when a piece is centred correctly. The s/c is the same every time so you just put the workpiece in and tighten it down: it is centred (within it's limits of accuracy).
    If possible, get both. Setting the four-jaw chuck gets easier with practice and it enables you to get more creative with the lathe/milling machine. The three-jaw is the 'go to' for most fabrication. If, for example, you intend to make a working steam engine from castings you will need both: if turning cannons, the three-jaw is all that is needed.
    By the way, simple dividing can be done using either without extra attachments.
    HTH
    Bruce
  5. 2 hours ago, Tector said:
    The other thing that is important to note about Jutland is that Beatty's squadron missed out on several gunnery practices...
    It has been a while since I studied the battle, but I came to the conclusion Victorian-trained Beatty did not grasp the needs of modern gunnery. He ordered an alteration of course as the two fleets at Jutland approached while his gunnery officers were half-way through calculating their firing solutions: the need to recalculate delayed the British opening salvoes. Nobody at the time could chastise the victorious admiral but it damaged his perception among the more technically minded younger officers.
  6. 20 hours ago, Kevin said:
    .... will press ahead a try to complete the build before the end of this month, ....
    Hello Kevin,
    I saw this and thought it might cast some light on your subject:
    It is 'Shipbuilding on the Thames at Redriff' in the NMM, object ID = BHC1868, dated 1792
    The description is " A scene on south bank of the Thames at Rotherhithe, looking east to the tower of St Anne's church, Limehouse. Two ships are shown on the right, viewed from the starboard quarter and flying the red ensign. Both are, by type, merchant vessels but that on the left, on the stocks just prior to launching, appears to be a naval transport flying a naval pennant from her central flagstaff and a white St George's jack. The other is refitting in a dry-dock. Piles of timber are stacked on the wharf between these two with a Dutch flag prominent on a quayside hoist. A ship on the far right is shown on the water, apparently with her rig struck down to her lower masts. On the left of the vessel ready for launch stands another under construction on the same slipway and in-frame up to her top-timbers. In the right background, in starboard broadside view, is another merchant vessel with only her lower masts standing, probably at the inland end of a dock or basin, voiding to the Thames out of sight on the left. Houses lie beyond and on the left of the skeletal ship is a low building with a red roof and a pile of timber in front of it. Men can be seen on ladders working with the timber. Two merchant ships are moored off the point, in stern view, with the masts of a third visible beyond. Others lie in the river on the left, where a cutter is also tacking upstream in the distance. In the foreground on the right a couple sit in a Thames skiff being used as a water taxi. In the centre a Dutch trading dogger is coming upstream, her starboard leeboard visible, and the male passenger in the skiff gestures towards her while his oarsman turns his head to look out for her. Although similar craft often appear in Dutch paintings, its presence combined with the Dutch flag on the quay indicates that the artist had intentionally established a strong Dutch connection. It is possible that the picture, painted in 1792, marks a contemporary event of Dutch or Anglo/Dutch significance such as the 100th anniversary of the Anglo-Dutch defeat of the French at the Battle of La Hogue in 1692. The prominence of the man gesturing in the skiff may indicate that he has a commercial interest in the scene. The shipyard shown was previously thought to be Quallet's at Pitcher's Point. However, this had gone by 1792 and Richard Horwood's map of that year suggests that it is more likely to be Young's yard with the 'inland' vessel beyond also be in Young's other dock further round the point, though topography has been distorted to fit it in. The Dutch elements may be a compliment to Peter Everitt Mestaer, whose yard was to the right (west) of Young's, where the moored ship is alongside, and whose name suggests Dutch background. If this interpretation is right the buildings and stacked timber are likely to be those of Thompson's yard beyond Young's. In the early 18th century ribbon development along the Thames linked Deptford to Rotherhithe and London. Daniel Defoe commented in 1724 that 'the docks and building yards on the riverside between the town of Deptford and the street of Redriff or Rotherhithe are effectually joined and building daily increased'. Despite this evidence the painting is curiously emptied of bustle and human activity. Whitcombe was born in London in about 1752 and painted ship portraits, battle scenes, harbour views and ships in storms. Although his output was vast, little is known about him. He produced a large number of subjects from the French Revolutionary and Napoleonic Wars, 1793-1815, and exhibited at the Royal Academy between 1783 and 1824. His depiction of ships implies specific knowledge of life at sea, although he probably spent most of his career in London. Many of his works were engraved and they included 50 plates to James Jenkins's account of 'The Naval Achievements of Great Britain', published in 1817. The painting is signed and dated in the lower left corner, 'Thos. Whitcombe 1792'. "
    Every little bit helps.
    Bruce
  7. 2 hours ago, Bob Blarney said:
    I think that this is not possible on a bandsaw that a hobbyist could afford, and likely not possible on a bandsaw at all. It would be necessary to rough cut, and work it down further from there.  For final thicknessing, I think a handplane fixture might be better than a sanding fixture.
    Ouch. I will see what happens when I crank up the bandsaw in anger next week. The fact that I am looking for planks 3 to 10mm wide from the holly, not an entire leaf of veneer, will hopefully let me get a usable result. The variables of blade properties still trouble me but I suppose I should wait for the first cuts instead of trying to solve all mysteries in advance.
    Thanks,
    Bruce
  8. 51 minutes ago, Bob Blarney said:
    ... if the blade is in good condition and the saw is set up properly.
    Bob, many thanks. I have recieved contradictory advice on what blade to use so if I can ask one more question: narrow or wide, maximum teeth or ????....
    The goal is to produce thin strips, 6 to 10 thou thick, from holly and fruit woods. There are other pieces in other woods as well but I suspect these thin pieces will reveal my ignorance. I have previously only used a largefr bandsaw to cut metal and it didn't take long for me to realise that a small saw for wood ain't the same. Any pointers welcome.
    Thanks,
    Bruce
    EDIT: by the time I posted this you had posted the video, thanks, I will watch it now!
  9. 19 minutes ago, Bob Blarney said:
    All that said, when ripping thin slices with full-sized saws, e.g. cutting 1/8" wide strips from a 4" wide board, the fence should never be fixed at 1/8" from the blade and then the thin slices ripped from the wide stock board.  If done that way, then the thin slice may become trapped, grabbed by the blade and flung back as a spear at the operator.  A much safer practice is to place a stop block on the other side of the blade, at 1/8" from the blade.  Then the stock is placed against the fence, and the fence is adjusted so as to abut the stock against the stop block.  Then a slice is ripped away, and then the fence is readjusted for each successive cut, again abutting the wide stock against the stop block.
    Bob,
    Many thanks. I take it the same basic idea works for producing thin strips on a small bandsaw? I am about to make my first attempt.
    Bruce
  10. Thanks for the comments. I have always believed it is Beagle although the picture does not carry any notation. Also, I am grateful for the comments on her rig as I am far from competent to speak on the subject (but had hoped it was 'barque').
    Her flags make the numeric '638' or '631': does this mean something I should know about Beagle?
    Now to tackle the foxing...
    Thanks again,
    Bruce
  11. Hello Jaager,
    Thanks, humidity and mould with holly is also a problem here although I have heard from someone who knows about tonewoods that for some reason holly is slightly less problematic here than in North America. There are contradictory accounts of the best way to handle the holly once it is cut but all seem to agree that speed is important.
    All my holly was cut from my own garden, and the oldest (and largest) pieces are from the winter of 2013. I don't have kiln facilities and I did not know at the time about the need for quickly sealing the ends, but to my surprise the wood seems to have survived in good shape. I will post after the experiments, and I predict it will be 'boast or toast': don't see any middle ground.
  12. 2 hours ago, vulcanbomber said:
     Does anyone know where I can get holly strip wood from in the UK?
    Keep your fingers crossed for me: in the next week or so I am making my first attempt at sawing up some holly logs that have been seasoning for a few years. If it goes according to plan I will have more than I could ever use.
    What do you need?
