Everything posted by tlevine
Half Hull Planking Kit
tlevine replied to DGraley's topic in Building, Framing, Planking and plating a ships hull and deck
You mentioned the same issue in another thread. It was suggested that you post pictures of your problem. If you think there is a discrepancy, please post pictures so that it can be addressed. Better yet, start a build log. -
It is hard to go wrong with anything from Vanguard. Harpy is a nice looking ship.
- 6 replies
- Maristella Models
- vanguard models
Looks very nice. Looking forward to seeing the final product.
- 47 replies
Final planking.
tlevine replied to serpe's topic in Building, Framing, Planking and plating a ships hull and deck
I would apply the finishing wood last. That way it will cover up any dings that occur along the way. -
Keel klamper alternative
tlevine replied to zamboknee's topic in Modeling tools and Workshop Equipment
Another place to look is the Half Hull Planking Project. This was designed for novice modelers. -
The first post is the hardest. Welcome to MSW! -
I have no experience with this wood. How hard is it? I would probably use it for things like hatch covers rather than pillars.
- 969 replies
- hahn
- oliver cromwell
At the top of the deck plan there is the comment "the ticked lines and those in green are proposed alterations, the others are as she is now". Also, look where the magazine lantern is in location to the faint word "magazine".
- 969 replies
- hahn
- oliver cromwell
Period Scale Model Masting and Rigging Tables
tlevine replied to DaveBaxt's topic in Masting, rigging and sails
The updated version has been added to the Resources section. -
Beginner - Rigging Tools
tlevine replied to nheather's topic in Modeling tools and Workshop Equipment
I find size 10 crochet hooks to be very useful with rigging. Readily found in sewing stores and Amazon. -
Take a look at the build log for the NRG rigging kit. The second fanciest tool is a fan showing the distance between ratlines. The two things you need to acquire are information about which lines are served and a serving machine. Of the ones commercially available today, Syren's is the best by far. -
Like your taste in moral support. I would suggest going low tech... Hold the material in your hand and shape it with a file.
- 257 replies
- pegasus
- Swan-class
I use warm Sparex prior to blackening. I typically let it soak for 5-10 minutes and then dip the part in water before blackening. Keep in mind that you need to use copper or wood tongs to remove the parts from the Sparex.
- 257 replies
- pegasus
- Swan-class
Problems with blackening brass
tlevine replied to Desertanimal's topic in Metal Work, Soldering and Metal Fittings
I put everything that needs blackening in the Sparex. Mix up a batch, keep a lid on the pot and plug it in whenever you need it. Just remember, copper tongs are required to remove anything from it.
