tlevine
Everything posted by tlevine
  1. You mentioned the same issue in another thread. It was suggested that you post pictures of your problem. If you think there is a discrepancy, please post pictures so that it can be addressed. Better yet, start a build log.
  2. Please post a picture of what you are talking about. Frame 4a does not sit higher than frame 5.
  3. The rigging kit is currently unavailable. The cost of materials made it cost prohibitive. However, very soon you will be able to buy a modified practicum complete with all of the frame drawings so you can source your own materials.
  4. You could also simulate the bolts or nails with copper wire.
  5. It is hard to go wrong with anything from Vanguard. Harpy is a nice looking ship.
  6. Sorry for the late reply. I have the plans and can photograph them and send them to you if you would like. They say Copyright 1971.
  7. I would apply the finishing wood last. That way it will cover up any dings that occur along the way.
  8. Another place to look is the Half Hull Planking Project. This was designed for novice modelers.
  9. The first post is the hardest. Welcome to MSW!
  10. I have no experience with this wood. How hard is it? I would probably use it for things like hatch covers rather than pillars.
  11. At the top of the deck plan there is the comment "the ticked lines and those in green are proposed alterations, the others are as she is now". Also, look where the magazine lantern is in location to the faint word "magazine".
  12. The updated version has been added to the Resources section.
  13. I use Danish Oil for all of my models. My Hannah was made from pear (not swiss pear). It darkened the wood slightly but brought out the character of the grain.
  14. I find size 10 crochet hooks to be very useful with rigging. Readily found in sewing stores and Amazon.
  15. Take a look at the build log for the NRG rigging kit. The second fanciest tool is a fan showing the distance between ratlines. The two things you need to acquire are information about which lines are served and a serving machine. Of the ones commercially available today, Syren's is the best by far.
  16. First, welcome to MSW. What is your interest? Kits come with sufficient materials to make the boat. As a novice, learn the skills first, then concern yourself with the "best" materials. That is a concern for kit bashers and scratch builders.
  17. Like your taste in moral support. I would suggest going low tech... Hold the material in your hand and shape it with a file.
  18. I use warm Sparex prior to blackening. I typically let it soak for 5-10 minutes and then dip the part in water before blackening. Keep in mind that you need to use copper or wood tongs to remove the parts from the Sparex.
  19. I put everything that needs blackening in the Sparex. Mix up a batch, keep a lid on the pot and plug it in whenever you need it. Just remember, copper tongs are required to remove anything from it.
