Everything posted by tlevine
Welcome back! For templates I will use a combination of taping small pieces of paper together for one side and inserting the paper between the frames for the unplanked side. Still requires some tweaking, but it compensates for the thickness of the planking and any asymetry between port and starboard.
- 969 replies
- hahn
- oliver cromwell
Masts are not the same diameter or shape from the mast step to the masthead. The Royal Navy had exact specifications for every section of the masts and yards and their rigging. Real masts were made up from multiple pieces of wood. This increased their strength and allowed the use of smaller diameter trees. My mast was made from a square poplar dowel purchased at a big box home improvement store. The mast head is square and the rest of the mast is initially round. To transform a square dowel into a round mast, the dowel will first be shaped into a regular octagon (all sides the same size). The instructions will go into detail on how to do this and will also include a scale template of the mast shape. It is easier to shape the mast if you have extra wood on both ends. I cut the dowel approximately 2” longer than the length of the mast. For the kit, glue 1-2 inches of scrap wood, the same or smaller diameter than the dowel, on both ends. The dowel was sanded down to just fit into the slot in the backbone. I used a level to make sure it was vertical. The dowel was removed and I drew the centerline on all four faces. Then, using the centerline as a guide, the templates were tack-glued to two adjacent sides of the dowel and the outline of the template was drawn onto the dowel. The templates were removed and I marked the transition from the round lower part of the mast to the square masthead with a few turns of masking tape to prevent damaging the masthead. I shaped the dowel below the masking tape to match the outside edge of the template with a chisel. The quarters were marked on all four faces of the dowel. The 7:10:7 ratio was drawn in at the quarters and a few other locations. I took the measurements directly from the template. Lines were drawn connecting those marks from the bottom of the mast up to the masking tape. You can see the marks in the photo. The wood outside those lines was removed with a chisel. Two very important things to keep in mind: your tool must be sharp and, as much as possible, the wood should be removed going with the grain. I rotate the dowel frequently, rather than finish one edge at a time. When using wood without discernable grain, it can be difficult to see the edge of the octagon. So when I am getting close to the lines, I run a pencil along the edge. You can see how well the jig holds the mast securely. And here is the final result. You can see how the tape protected the masthead. Now that the lower part of the mast has been shaped, it was time to start shaping the mast head. On the actual mast, the sides of the mast head are cut down, leaving the full thickness fore and aft. Then, after the cheeks are installed on the sides of the mast, the mast head is built back up to a square shape. The next photos show the mast head before and after the wood had been removed from the port and starboard faces. On the fore and aft sides of the mast head, I removed the wood outside the pencil lines, continuing the taper of the lower part of the mast. The next two pictures show the mast head marked out and tapered. Compare the appearance of the fore/aft faces versus the port/starboard ones. You will also notice that I have started to flatten the sides of the mast in preparation for the cheeks. Tapering the mast head was done with the Byrnes sander. Otherwise, this was all done with hand tools.
- 80 replies
- rigging/masts
- NRG
The lower mast and trestle trees must be made before installing the lower deadeyes. There are many ways to make masts and yards, including using a round dowel approximately the right diameter, turning a wood blank on a lathe or chucking a dowel into a drill and sanding it down to the correct dimensions. A fourth technique will be shown here. The only tools required are a caliper, a sharp chisel or plane and sandpaper. A jig is needed to hold the wood during the shaping process. The picture below shows two types of jigs. The top two homemade jigs only differ in the diameter and length of wood they can hold. The lower jig was made by Hobbymill, which is no longer in business. It is a single jig with multiple sized slots. I prefer the security of the single size jig. With either type of jig, the final diameter of the mast or yard must be greater than the height of the V-slot on the jig. The practicum will give instructions for making the jig. Before going any further, a few terms need to be defined. The part of the mast above the trestle trees is called the mast head. Below the trestle trees, the mast is divided into “quarters”, starting at the mast step in the hold. “Cheeks” (not illustrated) run on either side of the mast below the mast head and provide additional strength to the mast. The “hounds” are the upper parts of the cheeks. Later era ships have a “fish”, similar to the cheek but located on the fore side of the mast. The relative length and shape of these pieces vary by size and type of ship, country and era.
- 80 replies
- rigging/masts
- NRG
This ship’s main mast channels are 13’ long, 18” wide and 4” thick. They are made by laminating three layers of 1/32” sheet together. The middle layer’s grain is oriented 90 degrees to the outer layers for added strength. I weighted the channel down while it was drying to prevent warpage. In actual practice, there would be a slight taper of the channel from the hull to its outer edge, but for this project I ignored that. The fore end of the channel is located just behind the aft side of the mast. There are recesses cut into the fore and aft ends of the channel. The deadeye strops fit into mortises cut into the channel and a decorative strip holds everything in place. The channel template shows the locations of the deadeye strop mortices. The location of the fore end of the channel was marked on the hull. It is 2.5 feet below the rail and runs parallel to the wale. Templates were used to get the exact shape. I used the template from making the cap rail as a starting point and modified it to exactly fit the shape of the hull. The openings for the deadeye strops were made by cutting shallow grooves into the channel and connecting them with a 2 mm chisel. A #11 blade will also work. The location of frames 4 and 6 were marked on the inner edge of the channel and 22-gauge brass wires were inserted at those spots for strength. The fore and aft edges were rounded over but the long outer edge was kept sharp. You may have noticed that the deadeyes are not evenly spaced. On the actual ship, a gunport was located between the third and fourth deadeyes. I decided to keep things simple and not model the gunport. If you want, the spacing between frames 5 and 6 will allow you to add one.With the channel installed, a clear finish was applied to the exterior of the hull. After the finish dried, I sanded the long outer edge of the channel to remove the finish. This will help adhesion when the decorative strip is added after the deadeyes are installed.
- 80 replies
- rigging/masts
- NRG
The bit pins are 9” square posts. The crosspiece is 8’ x 10” x 3” and connects the two pins. It is morticed into the pins 3’ above the deck. Shape the ends of the crosspiece as seen in the picture. I raided my scrap box again for these pieces but the kit will contain the correct thickness of basswood to construct them. I used the previously drilled pilot holes to locate the centers of the bitt pins and lightly traced the outline of the bitt pin onto the deck. A series of holes was drilled inside the outline and they were connected with a #11 blade. They were enlarged with files until the openings were just large enough to allow the bit pin to pass through them. They will not be permanently installed until later to make installing the mast easier. This is how the model looks with everything temporarily installed. Other than installing the channels, the hull is complete. Next, the wale was painted. The hull planking was masked off above and below the wale. I used three coats of artist’s acrylic paint diluted 1:3 paint to water, sanding with 400 grit sandpaper between coats. I remove the tape as soon as the last coat has been applied to prevent paint adhering to the tape.
- 80 replies
- rigging/masts
- NRG
As I mentioned before, the bit pins will be glued to the “B” spacers. I measured and marked two feet (½” scale) aft from the aft surface of Frame 4 and nine inches (3/16” scale) inboard from the spacers. These are the centers of the bit pins. Small pilot holes were drilled up through the deck. I planked the inner bulwarks, starting at the waterway, using ten-inch-wide planks. I applied a clear finish at this point. The top of the bulwarks was sanded flat in preparation for installing the cap rail. Simply turn the model upside down and sand the bulwark the way you did the base. This also gives a fresh surface to glue the top rail onto. Templates were made to determine the shape of the rail. This is how I made these. Masking tape was run along the upper edge of the hull planking to prevent marking the wood. The model was turned upside down and, hugging the side of the ship, a line was drawn along the top of the hull. Don’t forget to mark fore and aft, port and starboard. The rail is 12” wide with a 1” overhang inboard and outboard. I drew lines 1” (0.02”) outboard and 11” (0.23”) inboard of the original line. The picture shows the templated line and the overhangs. I cut out the templates with a lot of extra paper on either side of them because long, narrow pieces of paper are prone to warping. They were glued to the 1/32” wood sheet. I use either Elmer’s glue stick or glue spray that is not water based (3M-45) to help prevent warping. Both of these adhesives can be removed with isopropanol and scraping. This is another opportunity to check out your scrap pile for a piece of contrasting color wood. Cut out the rails and mark the undersurface with the side and orientation before removing the template. Remove the template and round over the edges. If you want a contrasting color for the rails, paint or stain them before installing.
- 80 replies
- rigging/masts
- NRG
Next up was the deck planking. I marked the center line on the top of the frames and installed “B” spacers between Frames 4 and 5. These will be used later to secure the bit pins. This ship has a king plank on either side of the midline, which is wider than the regular planking, 12” instead of 10”. I shortened the mast partners so the planks would land on Frame 4. Just like I did for the hull planking, I used a pencil on one edge to simulate caulking and, because of the camber, sanded a bevel into the lower edge of the other side of the planks for a tight fit. A row of 10.5” planking was installed on either side of the king planks. The rest of the planks will be 10” but this allowed the edges of these planks to be aligned with the outer edge of the partners. I removed the partner to prevent it from getting damaged. This is why it was only tack glued. I used a four-step butt joint pattern for the rest of the deck planking. The rest of the planking was installed, tapering the outermost rows to fit against the waterway.
- 80 replies
- rigging/masts
- NRG
The next stage of construction was fitting out the mast partners, inner bulwarks, and deck. On a real ship, the mast partners were made up from several pieces of wood. For simplicity, I made the mast partners from single piece of cherry from my scrap box. In the kit, it is made from two pieces of 1/32” basswood, with the two pieces oriented 90 degrees to each other for strength. It measures 5’6” x 4’ x 3”. The center of the mast is located 6” forward of the center point of the partners, to allow enough room for four eyebolts aft for securing the truss pendants and lifts. It is not 100% historically accurate but compromises had to be made during kit design. The mast is 17.5” in diameter at the partners and is raked aft so the opening will be oval, not round, with the long axis fore and aft. I began by drilling a hole smaller than the final dimension. It will be finessed later. Remember, you can always remove more wood...you can't put it back. Then the edges and corners were rounded over. The waterway was made from two pieces of wood laminated together. Because of the amount of hull curvature, I prefer to make a template and cut the outline of the bulwark onto a sheet of wood rather than edge-bend. The template is very simple: a piece of paper which is gradually trimmed to the correct shape. You only need one template since the two sides are mirror images of each other. The outboard edge of the waterway was traced onto the 1/32” basswood sheet and cut. Using a compass, a line was the drawn 10” inboard and the waterway was cut out. I prefer to make all my marks on the undersurface of the wood, where they will not be seen. All four surfaces were sanded smooth, keeping the edges sharp. Using the same template, I drew the outboard line on a second piece of basswood and cut it out. A second line was drawn 4” inboard. This was cut out and sanded but the upper-inner edge was rounded over. The pictures show both pieces of the waterway. The first layer of the waterway was installed and because a template was used, it fits perfectly and without tension. After the first piece was dry, the second narrow piece was added next to the bulwark, rounded over edge inboard.
- 80 replies
- rigging/masts
- NRG
Thanks everyone. When starting this project I wavered between a dummy hull and a simple POB cross section. One of the advantages to this approach is that it results in a nice desktop model. The compromise is that certain lines, like the stays, are omitted. It is time to plank the hull. The kit contains enough 1/32” basswood sheet to plank the hull and deck. I began the planking at the top of the bulwark extensions. This made them less susceptible to breakage. There are five rows of planking, followed by two rows of double-thick planks for the wale. Below the wale, the rest of the planking is the same thickness as the upper part of the hull. All the planks are the same ten-inch width. The thin basswood can easily be cut with a #11 blade and straight edge. No spiling necessary! I put a slight bevel on the long edge of one side of each plank to get a tight fit between the planks and rubbed a pencil along the other edge to simulate caulking. The picture shows the hull planked to the top of the wale. The wale is made from two rows of double-layer planking and will be painted black later. I painted the edges of both layers with an archival ink marker before installing them. After the first layer was installed, the hull was sanded fair. For the second layer of the wale, the exposed outer edges were slightly rounded over before painting the edges. The second layer of the wale was glued to the first layer and the surface was sanded smooth. I prefer not to paint the wale until the rest of the hull is completed to prevent damage. The rest of the planking below the wale was installed. Because some of the plank ends did not land on a bulkhead, it was necessary to glue a scrap of wood on the inner side of the plank to secure it to the plank above. In this picture, the first two rows lower planks have been installed. After the last row of planking had been installed, I removed most of the wood below the bulkheads by shaving it down with a razor blade. When most of the wood was removed, the model was put on top of a sheet of sandpaper and the bottom was sanded flat by moving the whole model back and forth. In this picture, the wale has been dyed with a coat of archival ink so you can see the difference in thickness between the regular planks and the wale.
- 80 replies
- rigging/masts
- NRG
The NRG is an educational organization, dedicated to providing our members with the knowledge to improve the quality of their model ship building. One of the most common problems model builders have is rigging their model. Kit instructions are poor. Often, the materials provided in the kit are improperly sized or the cheapest that the manufacturer could obtain. We all know that blocks are not square! I wanted to develop a project whose purpose would be to teach ship modelers how to mast and rig a ship without having to build a complete hull. This model is a 1:48 scale cross-section at the level of the main mast of a late 18th century British sloop of war, Swallow 1779. To keep the size of the model manageable and eliminate the need for a building board, the hull is cut off just above the waterline. For the same reason, only the center portion of the lower yard and the lower part of the topmast are constructed. Also, because this is a cross-section, certain lines, such as the stays and backstays, are not included. My emphasis will be on demonstrating techniques to improve your rigging skills. Skills that can be used on your next project. As this was developed as a teaching aid, certain shortcuts and compromises to historical accuracy were taken. Wherever possible, I have used measurements provided by the plans and such authorities as Steel and Lees. I apologize in advance to the master modelers who might criticize my shortcuts. I have kept the use of power tools to a minimum. The only thing that is outside the normal collection of hand tools is a serving machine. The Guild hopes to begin selling this kit in the next few months. The kit contains all the materials required to complete the model. But I always keep my scrap box nearby for those times when a piece of a contrasting color wood is desirable. I will mention those times as the build log progresses. Also, the build log is made up from the best photographs taken from three builds of this model. A sharp eye will notice some differences in the wood color because of that. The hull is constructed in typical plank on bulkhead style. There is a notched spine and notched bulkheads. The laser cut sheet of one-eighth inch basswood ply also contains a template for the top and four types of spacers, A through D. The spine and the frames are assembled as seen below. Frame 1 is installed with the printing facing aft. This gave me the option of painting the exposed bulkhead after construction was completed. The mast fits in the slanted slot between Frames 3 and 4. To keep the mast vertical, support spacers are glued on both sides of the spine. They will be sanded flush to the spine when the hull is faired. To prevent the hull from twisting and to strengthen it, spacers are placed between each frame. The three aft spacers are “B”, the next one is “C” and the two foremost ones are “D”. They are placed close to the edge of the frame for maximum stability. The laser char only needs to be removed from the fore and aft sides so that their surfaces are flat. If too much wood is sanded off, I glue strips of paper onto the edge as a filler to prevent distorting the hull. The hull and deck were faired so there are smooth curves fore to aft. I used a sanding block for this. I did not fair the bulwark extensions (the thin strips of wood above the deck) to prevent them from breaking off. This model has a significant camber to the deck. Sanding sticks help getting into the corners. You can see that the mast supports have been sanded down to match the height of the deck. Next up is planking the hull.
- 80 replies
- rigging/masts
- NRG
I hope you enjoy it, Mark. Last Fall I had a group of six modelers who I assisted with the kit, getting together for a half-day, every other week. It was a lot of fun for all of us.
- 11 replies
- half hull
- half hull planking project
Everybody has their own preferred techniques. If I were designing this today, I know I would do certain things differently. We never stop learning and honing our skills.
- 47 replies
ancre Le Gros Ventre by ChrisLBren - 1/36
tlevine replied to ChrisLBren's topic in - Build logs for subjects built 1751 - 1800
Sometimes we get lost between strict historical accuracy and common sense. You are showing the latter. A much smarter choice. -
Go for the toughie. Right now, your carpenter juices are flowing. Frames become monotonous very quickly. -
Good luck with #2. Instead of a sanding wheel, I would suggest a sanding disc. This will prevent you from digging into the wood. They come in coarse and fine grits.
- 47 replies
Use this hull as a teaching aid to learn how to plank a hull better. Without seeing the bulkheads, I am guessing a bit but most likely the hull wasn't faired enough at the bow. Because of the curvature, it is necessary to bevel one side of the plank to achieve a tight fit. The hull planking does not appear to be laid out in belts and spiled. Use this as an opportunity. Strip the planking. Fair the hull better. Take a look a the Half Hull Planking project in my signature. This will explain how to lay out planking belts and spile the planks. Since you stopped Cheerful when you needed a drop plank, the project will show you how to do that and how to add a plank at the stern (if that is necessary).
For this being your first wood ship model, you are doing a great job. The questions you are asking are even better. Regarding coppering... The plate sizes in AOTS are correct. I would suggest using copper tape instead of the Amati plates. The tape is self-adhesive and much thinner, making it easier to apply and more to scale. It's also cheaper. You can either apply it as individual plates or make a jig which shows the plate edges and apply it a row at a time. Check out Amazon.
- 90 replies
