Posts posted by drobinson02199
I have now finished the circular stairways, and I learned a lot.
I did the first one on the left all the way through, to see what I'd learn before tackling the second, and I learned a lot.
- The manual says to space the stairs 2mm apart -- and aside from the ambiguity of that instruction, it leads to treads that are too short. See the top tread on the left. So I started just eyeballing the tread spacing, leaving as little as possible while still providing support. The right hand straight portion is about 3mm longer than the left one, and looks better.
- I didn't soak the left hand curved railing long enough, and it broke and I lost the short piece down the drain. So I had to make railings for that as you can see on the left, second picture. They won't show much as they are on the inside. On the second one, I soaked it, then ran under hot water while bending, and then put the bent piece inside a toilet paper tube overnight.
- I didn't soak and bend the curved railing before painting on the first one (left), and you can see the break where it slants down. On the right, I soaked and bent before painting and it has a nice continuity where it bends down.
I was initially disappointed that the curved railing was plywood vs. something nicer, but I used a paint color called nutmeg brown, and when it's varnished it actually has a real wood look, so that came out OK.
Need to be careful to watch the orientation of the spirals on both stairs and railings. They go in different directions, and I almost muffed that.
I'll send another picture later when these fully dry and I've mounted them on the boat.
Regards,
David
Chris:
It's Krylon Fusion spray -- Satin Burgundy. I originally got it to paint the large plastic hull of the Mt. Washington, and this was the only non-gloss red that Fusion had (wanted Fusion for plastic bonding). But I really liked the color -- a maroon red and more subtle than regular red. It adheres to anything -- these wheels are metal.
Regards,
David
- John Allen, jbford, clearway and 2 others
- 5
- clearway, popeye the sailor, reklein and 1 other
- 4
Scott:
Yes -- now that I've mounted it I can see that most of the herringbone I worked so hard on will be hidden. I think the next deck is also herringbone, and more of that will show.
Reminds me of the Revenge. There are multiple decks inside the hull that I planked -- never to see the light of day.
Regards,
David
Stateroom level done now. What you see isn't glued down yet, but even when it is, there will be more gaps where the sides meet the deck than I'd like. Fortunately, all of that will be pretty much hidden by the railing..
The instructions say to mount the compartment and then install doors and windows, but I did the doors and windows before mounting, and I think it would be lots more trouble to do it the other way.
The grating shown isn't varnished yet (I'll do it when I break out the varnish again), but I didn't paint it. I have that same grating in another AL boat (Sanson Tug) and it varnishes to a nice brown.
Regards,
David
Chris:
For the deck planking, I'm just using the kit basswood, finished with at least two coats of clear satin poly. When I get inspired, I sometimes do a third coat.
I think the wood that's going to make this model look really good is the Sapelli, which is liberally used on the model. It varnishes to a deep reddish brown that is very rich looking.
Regards,
David
- John Allen, S.Coleman, Robin Lous and 1 other
- 4
Chris:
No problem at all. Your deck looks gorgeous. What wood is it?
Regards,
David
The first level structures are complete and mounted on the deck. A few construction comments:
- I noted above my use of wire mesh vs. acetate on the doors. Antony UK -- thanks for the wire straightening tip. Worked great and the other 3 doors look much better.
- Re the horizontal windows you see in the detail picture: I aligned the two long pieces and drilled them together before mounting them. That gave me aligned vertical holes for the pins.
- The doorknobs on the small doors are actually leftover bollards from the Revenge that I cut off. The instructions seemed to call for the same thing as is on the hinged doors, and I thought that would look off on these, so I improvised.
- Re the hinged doors: the instructions actually call for creating working hinges by folding over the hinge you see and using two, with a pin. I tried it and couldn't get it right, so since I don't care about working doors I just used 1/2 hinge as you see, and it looks fine to me.
The rear structure for the paddlewheels isn't varnished yet, and I want to put nails in for looks.
I've started on the second deck with the herringbone pattern. Mindful of S. Coleman's comments on his experience, I took a lot of measurements and pulled some old trig out of dusty memory. Have laid a few planks, and so far so good. Fingers crossed.
Regards,
David
- zappto, popeye the sailor, reklein and 2 others
- 5
Antony:
Thanks for the tip on straightening.
I thought about painting the bars black, but even though it's not probably historically accurate (or even good modeling technique), I like the look of a bit of brass on these models. In the pictures in the manual, the hinges on the double doors in the boiler room are left unpainted brass -- so I figured I can leave these brass as well.
Regards,
David
For the engine room doors, the kit calls for acetate windows, scored then painted and wiped off (so I assume the black paint stays in the scored lines but wipes off the rest).
Acetate for model windows and I have never gotten along well. I seem to get it scratched or smudged or dirty, and then over time it collects dust.
So instead, I used some leftover wire from an earlier model to make barred windows. Back and front shown below. It turned out as I had hoped, and I like the look. I know that the wires aren't perfectly straight (hard to get that from an old coil), but from a normal viewing distance I think it will be OK.
Regards,
David
- popeye the sailor, Robin Lous, UdoK and 2 others
- 5
Antony:
I hadn't thought of the height vs. draft -- in the Navy they taught us the "center of buoyancy" vs. "center of mass". Get the center of mass above the center of buoyancy and she flips over. Looking at this hull and the superstructure, they must have just had tons of lead ballast in that hull to keep the center of mass low. Makes sense -- shallow draft for the river.
Regards,
David
This kit requires some self-defense. When I started building the deck structures , I noticed that the forward one didn't fit the tab slots in the main deck. So before I finished gluing it, I looked at the alignment of the deck structure tabs to the second deck. It turns out that the first and second deck tab slots are out of line. You can see it in the pic below. What I'll need to do is sand that tab down so the forward structure can lie flush, with the rear lower tab engaged. When the rear structure is mounted and the forward one lies as you see it, the second deck fits perfectly (see picture).
I'm not sure how AL got this wrong. While I'm on the subject of the kit, I've had to carefully inventory all of my wood, because AL doesn't provide much if any spare wood, and I needed to make sure I had enough. I'm short of one of the wood types, but I have spares from other kits I have finished so I think I'm OK. But the wood quality and quantities in this kit are nowhere near what I had in the Amati Revenge. On the other hand, the kit didn't cost much.
So a heads up on this to others who may build this, and I will continue to look ahead to ensure fit as I build this.
Regards,
David
I have now completed the hull planking. Pictures after the first coat of varnish are below.
I think I'm going to like this boat and like building it, but I have to say that I'm not completely happy with how the walnut hull turned out. The wood Artesania Latina provides for this is flimsy, and chips easily. More comments on the kit itself in the next post.
- John Allen, popeye the sailor, UdoK and 2 others
- 5
Chris:
Thanks for this. I have a real weakness for the look of a natural varnish on the hull. If you look at my Revenge, just completed, you'll see that I didn't paint the bottom half of the hull white (as specified) because I love the natural look. I'm reminded of a post I read a while back that said "It's a model ship, not a piano", but I'm still a sucker for that look.
Thanks,
David
Chris:
The deck pattern was like that in the instructions. They called for 10 cm strips staggered. I staggered them, but instead of a 5 cm offset I ended up with 4 and 6, which I continued. I say "ended up" because it started with a measurement error, and so I just continued it. Looks OK to my eye -- but I tend to forgive myself a lot when I mess up.
At least one of the upper decks calls for a herringbone pattern.
I've started the hull planking, and it's actually kind of tricky. Unlike sailing ship hulls which have a continuous vertical curve, the sides and bottom form a right angle, and the trick is to get that transition without leaving any space or a rough looking corner. I've done one side and the approach I used was to plank the side first with an overhang past the bottom, then lay in bottom strips against the overhang and sand down the overhang. Looks good -- pics will follow when I finish and get the first coat of varnish on.
Regards,
David
I have finished planking the main deck and have mounted it to the hull. Will wait on penciling in nailheads until I finish hull planking and varnish all of this first assembly.
It will be interesting to see how the hull planking works. I have rounded the corners where the bottom meets the side bulkhead, and maybe with some steam I can curl the planks around that to create a smooth transition. That's what the pictures in the manual look like (sort of -- it's hard to tell).
Regards,
David
Chris:
The main deck, which is the largest outside dimension of the boat, is 25" long by 5" wide. The hull is a bit shorter and narrower. There is, however, a boom that hangs off the bow, and I don't have a fix on how much total length that would add.
The box says almost 26" wide by a bit over 5" wide by almost 12" high.
Regards,
David
Here's the finished hull with side bulkheads. I fitted the deck (not shown) before attaching the bulkheads, as it's easier at that point to sand down the frames and make sure the tabs fit properly, and the deck seats properly. It also helps with positioning the slanted piece in the stern.
Regards,
David
- popeye the sailor, AntonyUK, zappto and 1 other
- 4
Also, the labeling of frames 4 and 5 is reversed on the laser cut key sheet. This becomes obvious if you are assembling the bottom board at the same time as the false keel and frames.
Regards,
David
- popeye the sailor and zappto
- 2
Well, day 1 of the build and I've already made my first doofus move. I wasn't being careful and had the plywood sheet flipped over relative to the key sheet, and took the wrong frames out and glued them to the fore part of the false keel -- using CA glue. Fortunately, discovered the mistake about 30 minutes in and was just barely able to knock the frames off -- but not before the last "knock" broke the false keel into two pieces as shown in the first pic.
The fix was to assemble the two halves of the false keel, the frames, and the bottom board simultaneously -- so that the bottom board aligned the two halves and also created structural strength. All fine again.
On reflection, assembling frames, false keel and bottom board at the same time is the way to go, so that the frames can be properly aligned (and necessary tab sanding done as you go), but with other ships I've built it was false keel and frames first, so that was the reflex. Need to slow down and look ahead.
Regards,
David
- Zarkon, AntonyUK, popeye the sailor and 3 others
- 6
King of the Mississippi by drobinson02199 - FINISHED -- Artesania Latina - 1:80
in - Kit build logs for subjects built from 1851 - 1900
And the curved stairs now mounted on the boat.
