king derelict
Members-
Everything posted by king derelict
You need lots of fine filament to print that one 😄. That is Gracie my Maine Coon mix adopted from the local shelter when she was four months old.
- 460 replies
- Finished
- Flower-class
Thank you for the support Lou. I have found the process to be harder than I expected but I have learnt a lot as it progressed. Overall it is still enjoyable but there have been some frustrating moments with teh printer and working around the generic nature of the model. The next phase should be less fraught and thus more enjoyable as teh detail builds up. Alan
- 460 replies
- Finished
- Flower-class
I have found the wooden decks to be quite nerve wracking to install. I have only installed them on bare plastic because I was worried they might lift off paint - I'm not sure how valid a concern that is. So far it has gone well. I tried to be careful fitting it over the deck fittings and using that to position the wooden deck and I found the deck settled down into the correct position - they are astonishingly well cut. Alan
I seem to have had a lot of distractions in the real world lately so although progress has been made here it has been in such small steps I would have been embarrassed to publish them. A lot of the issues have been with the impacts of Omichron on my trip to see my father in the UK. I should have been in transit right now but I could not get tested in time to meet the latest UK pre-departure test requirements, so I cancelled everything late last night. We last saw the Vickers in its base colour. Masks were added ready for the green sections of the paint scheme. Card and blue tack were used on the hull and blue tack alone on the turrets. I used a tip from @Landlubber Mike and drilled a small hole in the underside of the hull to receive a cocktail stick as a handle for painting. It worked so much better than a blob of blue tack which for me had a habit of falling off during air brushing. Thanks Mike. I forgot to photograph the application of the green paint, so we move straight onto more masking for the final colour. The results are shown below A gloss coat was applied and then black washes to bring up the panel lines and details of the running gear. Detail parts were painted and a buff coat was lightly air brushed, concentrating on the lower parts of the model to get a dusty effect. Finally a dull coat was sprayed on and the small amount of rust and parking lot damage was added. No decals supplied or shown on the box art so I think this is finished Hopefully this is not a huge fox paw but it didn't seem worth making a separate log for a related and also simple kit that followed exactly the same process. While waiting for paint to dry etc I built the First t Fight Panzer III. Again not a lot of parts - assembly took about two hours going slow. Instructions are on the bottom of the box but the box art is actually more useful. A set of (three) decals are supplied. Detail is very nice for a simple kit. The road wheels on the tracks have sprues joining them and I nearly missed them but once found they were easy to cut away and clean up Black primer added, grey coat and then a gloss coat. Decals applied, dust air brushed as with the Vickers and some minor wear and tear. I also drilled out the holes in the front sprocket wheel which I thought made it a bit nicer. So now I'm thinking about the next project; something a little more substantial while I take a rest from the Flower corvette. I'm thinking of another Flyhawk model With a wooden deck and some PE this appeals I'm also intrigued by this interesting model and haven't tried a Roden kit yet so would welcome any thoughts. Thanks for looking in and indulging me in these little tanks Alan
It has been a while since the last update. The real world has been intruding a bit and I've also been spending a lot of time working on teh final layout of the ship. I had decided earlier to move the funnel back to nearer its position on the real modified corvettes. This had the knock-on effect of shortening the distance between the funnel and the aft gun bandstand. The deck aft of the engine room is also too spacious. It was the only place on the ship where the whole crew could gather but it wasn't that big. So I felt that the only solution was to lengthen the engine room which would also address the other problems. I implemented this by cutting back into the aft deck and printing a second copy of the forward parts of the port and starboard engine room walls and cutting about one and a half panels from the new pieces and joining them to the front of the engine room walls. After cutting the parts I put the new port piece on the starboard wall and vice versa on the other side. This kept the flow of whole panels with the half panel out of sight under the upper deck. The engine room was reassembled The modified engine room was dry fitted to determine the make-up piece of decking forward of the bridge. The new deck piece was cut from a sheet of styrene (and I have to say it was pleasure to work with after the PLA parts) and is test fitted. The revised engine room has had the ventilators and the skylights added and then a first coat of primer. It now needs a little filler before moving on to the paint coats. The recessed area on the side decks will take the wooden decking. I think this is the end of the major decisions on the layout of the model and now each deck section can be worked on to add detail and paint. This should all be enjoyable after the rather unwieldy activity getting the elements of the model to come together. Much as I am continuing to be impressed by the potential of the concept of a printed ship there are a couple of issues that I find difficult. The PLA material is horrible to work with. It is very hard and cutting and sanding it is hard work. Filing seems to be a bit easier but modifying parts is tedious I find the epoxy glue is messy and difficult to use with precision. That probably mainly me being clumsy. It is also not a great choice for some of the thinner areas or where there is flexibility. The glue sets very rigid and if the part is flexed it just cracks back apart. I now roughen each part (the texture from the printing is not adequate and clean with alcohol before gluing and get rather better results. I would probably do better and get stronger and cleaner joints with the appropriate solvent, but the fumes worry me. Its all a learning experience. Thanks for looking in. I may take a break having reached what feels like a milestone to me and then come back to tackle the deck sections as mini kits after Christmas. Alan
- 460 replies
- Finished
- Flower-class
I'm enjoying looking at the build on my big laptop screen. The detail is very good and your PE is very well done. Its starting to get busy and its going to be a spectacular model Alan
As far as i could see the spring providing the tension in the extruder gear and roller was fully extended so at its softest grip. The new one definitely is. A friend suggested that it could have been a soft gear so we will see how this one holds up. The fact that there are so few upgraded gears out there might suggest that wear is not a serious issue. Alan
- 460 replies
- Finished
- Flower-class
Thanks Craig Its good to be moving forward again Alan
- 460 replies
- Finished
- Flower-class
Thanks Mike It got very close. I was trying to decide between buying a whole new machine or dumping the Ender and the part-built corvette in the bin. Its good to have found a clear solution - and for $20 Alan
- 460 replies
- Finished
- Flower-class
Thanks for the kind comments, Lou It's not really visible in my photos of the model but you can see it in OCs photo of the real thing. There is a metal flap that hinges down leaving a slit for the driver to see through. I hadn't realised how limited visibility was in a locked down tank even relatively recently. I was reading about the Glosters at the Imjin. They were supported by a couple of Centurions which were operating with all hatches closed and they managed to get themselves stuck in ditches and the like a few times because they couldn't see well enough to avoid them Alan
I painted the matt varnish onto the Whippet and then touched up the rusty exhausts and the machine guns which had been dulled down too much by the dust layer. I think that finishes this one. I would like to get another kit and attempt a diorama based on the photo that Bruce provided. I think it would make an interesting scene. Thank you all for looking in and providing help and comments Alan
I air brushed the matt coat and tidied up a few details and installed the ditching beam and chains. I think this is complete. Its been a lot of fun and I am tempted to get another one and make a small base / diorama to show it rearing up on the lip of a trench - and then I could get a bit wild with the mud effects. Thanks for looking and commenting Alan And to show the Mark IV and the Whippet with the Renault and the AV7
Thank you, Andrew, I'm glad you have found it useful. My intention was to try to share lessons as I learnt from my mistakes. Out of the chaos I have developed a bed levelling routine that works for me and which I check regularly. As a result of the extruder gear issue, I will be checking the filament extrusion rate if prints start to lose quality. I'm trying to knock down the unknowns in printing. Alan
- 460 replies
- Finished
- Flower-class
