king derelict
Posts posted by king derelict
  1. Weathering continues on the hull. I added the light rust washes to the dark rust at the panel joints and below the scuppers (may have overdone that). The coloured images I have don't show any significant rust around the portholes which slightly surprised me but I have left it off. This may be a bit too heavy in places but I wanted to get an Atlantic convoy look. Those little ships really took a pounding out there.
    I added rust to the bridge supports and started on the bandstand and 2 pounder gun tub supports. I;m not sure whether to add a light touch to the ventilator stacks otherwise I plan to leave the superstructure relatively clean.
    I have rigging thread arriving tomorrow and I'm trying to work out a rigging plan. As in everything else it looks like every Flower was different.
    Thanks for looking in
    Alan
  2. 17 hours ago, lmagna said:
    I think that if I was sharing my model sailing space with Alligators then I would want much more than a few pea sized depth charges! Unless they were nuclear! I think I saw somewhere on YouTube where some guy was playing Catch-me-if-you-can like in a bull fight with his Go-fast electric boat while filming it with a drone. The Gator came close several times and it looked like the boat was going to be a goner. Your Corvette may have a longer lifespan if you keep in on the shelf!
    I think it might look a bit like a duck from below and if you are an alligator, you can generally afford to bite it and see what you got
    Alan
  3. The anchor chain arrived this weekend and i think it looks the part. The proportions are good and it does have stud links
    I gave it a base paint of flat brown and then dry brushed a dark blue over it. A rust wash finishes the chain
    I used some thin styrene rod to create the antenna loops (I assume these are the DF loops - I'm not knowledgeable in this area) and also made up some speaking tubes for the bridge. I'm trying to make it look a little less empty. I still need to fiddle with teh pelorus
    The big moment arrived this afternoon. Weathering. I started with some thin lines of dark rust at the panel lines and then added light rust and washed that out. I'm going to be working this up a little at a time. Its a bit beyond the tiny dabs that finish a 1/700 destroyer build and I'm keen not to mess it up too much. I'm working with the few colour images I can find.
    Thank you all for looking in and for the likes
    Alan
  4. On 8/3/2022 at 8:41 PM, lmagna said:
    Great looking build. It has been following your learning curve and progress. It would have been nice to see it as an RC ship but that's just me. You are doing fantastically.
    I suspect that in real life what guns were put on in the small calibers was just as you have done, what was available on that day and what the Capitan was able to steal.😁:cheers:
    Thank you for the kind words Lou. Much appreciated. You are right I should have made it an RC model but I have never tried anything RC and the printer seemed like enough of a challenge. The beauty of the virtual kit is that I still have the files, the printer and the license to make as many kits as I want.  So its probable there will be a sister Flower some day in the next year or so on the lake behind my house depth charging the alligators.
    Especially as the printing shouldn't be the exercise in patience that it was first time round.
    You are right about the small arms configurations. Oerlikons were in short supply and some corvettes never got beyond Lewis guns; I think captains grabbed anything they could get their hands on. Those little ships must have felt very vulnerable under air attack.
    Alan
  5. The Eduard Lewis guns arrived and are very nice although my PE skills have been atrophying and it took longer than it should to put them together.
    They now have a primer coat and hoping not to break them before installing them
    The question of the Lewis gun configuration is a bit vexed. It seems that single and twin Lewis gns were mounted, either with or without shields. The picture below is the one I am using as my guide for my interpretation.
    1278108807_96d18236e0ddebbfc5fe25b54aba16f6(2).jpg.aa913f7e3c3732cbb7444fb64bb41f25.jpg
    The image shows the Lewis gun firing and looks like a single with a shield
    Later photos show twin Lewis with shields
    I suspect the twin gun installation was the most frequent but I am going to use the singles that I have. I'm not sure about the shield yet; I'll see how some styrene sheet looks.
    The reprinted boats were air brushed for the man ropes and bottom boards. Still not perfect' the texture of the print is too rough in places. Its better than my hand painting so we will move forward and weather the bottom boards
    The boats need oars and tiller adding and then rigged with the davits. The hull weathering is next and I need to work out what rigging I am going to add.
    Thank you for looking in and responding. Its been a long journey from unpacking the Ender printer and switching it on for the first time.
    Alan
  6. I'm slowly working away at the details> added handrails to the ladders and Aldis lamps to the bridge wings.
    I'm starting to dabble with weathering. I am not using my usual black washes; The lines left by the filament on some parts take up the wash and it looks ugly. I bought this Life Color set of washes a while ago and didn't like them for the usual 1/700 stuff. It goes on as a dark grey but dries very light. The remover can be used to tone down the effect or blend it back.
    I think it might work to break up some of the areas that look like big white slabs. I have read that the Atlantic storms took areas of the paint off the hull so it may get used there too.
    I painted the smaller smoke floats and added them to the depth charge rails
    I decided that my shaky free hand painting was going to spoil the reprinted rafts so I am masking them for air brushing. Its a bit tedious especially as the tape does not adhere well to the printed surface. It will need a coat of clear to seal it before using the air brush.
    So - this is where I am now. Coming together.
    I'm trying to work up the courage to start slapping the rust on the hull and parts of the superstructure tomorrow
    Alan
  7. 5 hours ago, Kevin-the-lubber said:
    You’re very welcome, they don’t look too bad either. I wondered afterwards if it might have been better to just have small pilot holes in the drum, and drill them out later.
    Thank you Kevin
    They are really nice little prints and the holes come out very well. I much prefer them to opening out pilot holes. I printed them at 20mm high and the row of holes is quite intricate but still came out nicely.
    Many Thanks
    Alan
  8. 16 hours ago, Nirvana said:
    Alan, use hardened steel nozzle they are better and long lasting.
    Thank you Per. I looked at steel nozzles a while back and they all seemed to get rotten reviews citing dimensional problems. I checked again and things seem much better now so I ordered a set. Thanks for the help
    Alan
