Tim Moore
Members-
Everything posted by Tim Moore
Interesting! So this model building is definitely in your blood. Before ships I started out with all sorts of planes as well. Did one or two of the rubber powered Guillows, and then a massive u control flying wing with a 0.35 gas engine which I struggled to get off the ground. Then I got cocky and scratch built a smaller plane of my own design, which strangely flew better than any of the kits. After that I decided to quit while I was ahead, called it a day on planes and started shipbuilding.
The kit has tissue for covering the frames, which you would then cover with dope. I decided to try covering with a wood skin instead, to make a better display model. I flew the one I made according to kit directions many years ago with the rubber apparatus. This one will just be for display but it is still very light - the plywood skin on the wings is only 1/32” basswood. You’d need an engine to get it up I imagine.
Thanks guys for all the great comments and likes. Finished all the wing underside details. Fashioned some wing fairings from thin balsa and will eventually perfect it with a little sanding and touch of filler. The engine exhaust is a combination of plastic from kit and some aluminium tubing. Was hoping to find a nice aftermarket prop to put on it but with everything locked down here that doesn’t seem possible so I laminated a few pieces of wood and just did a hand carved job instead. This is quite a fun build and it’s a decent sized bird.
My son gave me this throwback kit for my birthday, one I had built and flown many, many years ago. So before I get cracking on finishing the last bits of rigging on HMS Bounty I thought I’d do this as a holiday project. Decided to employ my wooden ship skills such as they are by modifying the kit so it will make a reasonable display model to hang in the new workshop. Its a simple kit so I’ll just summarize the process so far. The laser cutting is exceptional and putting together the basic frames is straightforward. You’d normally now just cover this with tissue. Instead I inserted 150 pieces of balsa into the framework and then applied a thin watered down layer of latex wood filler and lightly sanded to give a final form, sort of like a clay model. For the wing, I covered the frame with 1/16 balsa underneath and 1/32 basswood topsides. I’ve nested wheel assemblies into the wing so it will look right flying off the ceiling. I ditched the tail assemblies in the kit and formed a more functional rudder and stabilizer from 1/4” balsa. So now I have the basic form of the Spit, and will work on incorporating more detail before painting.
Thanks Yves...yes so fragile. Possibly insane but this is how I decided to cover the fuselage in order to retain the right proportions.....use the framework as a basic form and then fill with balsa I had left over from my Miss Severn. Seems like a lot of work but really after a thousand ratline knots on the Bounty it’s really nothing to write home about. My plan is to use a light skim of body filler over the lot and then lightly sand everything to a final form. I’d like to use this side project to hone my paint skills for my next boat model - maybe invest in an airbrush and all that paraphernalia if it is worth it - something Ive never tried and know nothing about.
- 171 replies
- artesania latina
- bounty
Thanks Yves, yes the Fifie is on deck, been doing some research into these class of boats just to settle on a colour scheme for it. Slight delay while I finished off a new coffee table for the living room...which is now done. I’ve decided to first do a Guillows 403 Spitfire model which my son had given it to me for my birthday last Christmas, for something different around the holidays. Think I built one of these about 50 years ago! Kit is slightly different now with all the frames beautifully laser cut as opposed to having to cut them out from a printed sheet. So fragile as compared to boat modeling material, will have to take care and not be too ham fisted with my work. Isn’t too complicated so shouldn’t take long. Just a display model to hang in here I think. Vaguely recall destroying the last one in a rubber power misadventure. Think I will upgrade it a bit - cover with balsa as opposed to tissue, and hope I can find some upgrades for a proper propeller and wheels etc.. if anybody has done this and happens to know a source for this please do pass on.
- 171 replies
- artesania latina
- bounty
Ok after a long hiatus working on various construction projects I’m about to start up again finishing the Bounty here in my new cabin. First step is to figure out exactly where I left off and get back up to speed on the final rigging. And find myself a chair.
- 171 replies
- artesania latina
- bounty
A Model Builder’s Cabin
Tim Moore replied to Tim Moore's topic in Modeling tools and Workshop Equipment
Thanks guys for the kind comments. Yes I think both of us will be happy in our own workspace since we are together every hour of the day right now! The drafting table is actually my wife’s old drawing board. She thought it was a good fit in there and she was bang on. Presently looking for a recycled drafting stool to go with it. Funny you mention the barn conversion Barkeater - I’m about to start constructing a workshop in a barn for a friend here, just working out a plan for partitioning it off and a scheme for introducing natural light which I think is key to a satisfactory creative space. -
I was sharing a studio (converted garage) with the admiral who is a potter, but we found that it didn’t really work to best effect for both of us. Serious pottery is a pretty messy business and she needed the extra space I was taking up as her business grew. I was relegated to the basement last year. So after I got back this fall from my latest construction gig up north I set to building a small model workshop for myself just out back, which I’m just finishing. The cabin is a compact 10x14 and is fully insulated and heated with a small 240v system. It houses an electrical sub panel for my level 2 car charging power unit, and I extended the roof to create a carport. This will be my light duty workshop for model building and assorted projects. I’m an architect and builder so my main power equipment (compressors, saws, planers etc) is located in another space. I created one long wall hung 14’ bench on the one side, and the other houses various tables I use. I’ve yet to install the flooring and all my small modeling tools but you get the idea. Shortly I’ll be setting up here to finish the final rigging stage of my Bounty, and then move on to my next victim.
HMS Bounty by Artesania Latina problem/question
Tim Moore replied to LyleK1's topic in Wood ship model kits
You’re very welcome. Looking good - nice work on planking. Your building board looks pro. -
Hi Lyle - it goes under the deck at the stern. See photo 24 in the booklet if you have one. It is misnumbered on the index sheet and is actually part #170. tim -
Hi Reneke sorry for delay in responding...yes I definitely have a fix having needed to do it myself earlier in this build. Rather than go to all the trouble of sanding and refinishing I just mixed some of my ebony and chestnut stains with the varnish until I got the darker tone I wanted and put on another coat. It worked well.
- 171 replies
- artesania latina
- bounty
Hi Reneke - thank you for the kind remarks! Hope the rest of the build is satisfying. I’ve been immersed in a couple of building projects for many months so the Bounty has been waiting patiently for me to finish her. I converted our garage into a studio where I could work on ship modeling a few years ago, but my wife’s pottery business has really taken off so she now needs the whole space. I am presently building my own workshop on our property and as soon as it’s done I’ll be back in business. Should be back at work on Bounty before winter In my new space and will resume my log to completion.
- 171 replies
- artesania latina
- bounty
kit review 1:32 Fifie – The Scottish Motor Fishing Vessel by Amati
Tim Moore replied to James H's topic in REVIEWS: Model kits
I purchased the kit after reading your review...it’ll be my next project after I finish the Bounty rigging. -
Hi Geehard - I’m just finishing up an AL Bounty - where are you at & what do you need to know?
Hi Yves, yes that is the Billing’s Calypso up there... good eye.
- 171 replies
- artesania latina
- bounty
Lower foremast yard is hoisted. Messed up the chain (actually rope) length slightly as it’s a complicated loop assembly that had to be pre made. The end result is just that the lanyards between loops are a bit short. I’ll get the mainmast right, decide whether to fix this later.
- 171 replies
- artesania latina
- bounty
Thanks! I use CA, find it’s very effective tool, faster and less messy if used sparingly. I find the carpenters glue tends to leave more residue but do use that sometimes.
- 171 replies
- artesania latina
- bounty
Hi. I just use thread. My block tying routine (illustrated below) is: 1. Rub thread with beeswax 2. loop around block and tie knot at bottom 3. stick the block in vice and twirl thread a few times if you need the block to stand off yard or mast. Rub a drop of glue on thread to fix it. 4. tie the open ends of thread around yard or mast, fix with glue and trim
- 171 replies
- artesania latina
- bounty
The lower yard on the foremast showing scope of all the gear that must be attached. This isn’t quite finished yet, still needs the foot ropes and parrel assembly and some final tidying up.
- 171 replies
- artesania latina
- bounty
Yes my plan at the moment is to do sails, unless it ends up looking too cluttered.
- 171 replies
- artesania latina
- bounty
Thanks Patrick and Sam for the kind comments. The first two yards have been hoisted in place, using the parrels and without need for any temporary pinning. Man there is a ton of rigging on this puppy. Ropes everywhere. Nice to have such a great hobby for these strange days.
- 171 replies
- artesania latina
- bounty
Working on the yards. The hoops for attaching the booms to the lower yards in the kit were unusable, so am fashioning something from slices of aluminium tube, brass wire and a dab of Ca. Should look acceptable all painted up with gunmetal.
- 171 replies
- artesania latina
- bounty
